Geometrical Proof for Euclidian Triangle Circle Property
  • Level: Undergrad
  • Thread starter Phrak
    Proof
Phrak
No, this isn't a homework problem.
Given any triangle with a fixed length for one edge, and a fixed internal angle for the opposite vertex, the vertex will lay on a circle, where the other edges are allowed to vary in length. But I can't seem to construct a geometrical proof. Any takers? It's deceptively simple.
Hi Phrak! :smile:
The angle to the circumcentre is fixed (it's double the given angle, and you can prove it using isoceles triangles), and the circumcentre lies on a fixed line. :wink:
tiny-tim said:
Hi Phrak! :smile:
And I was just bemoaning the fact that no one responded. :smile: But wait. What's a circumcentre, and what angle from whence and to where?
I think most PF members don't like "real" geometry! :biggrin:
he he :smile:
The circumcentre is the centre of the circumcircle, which is the circle which goes through all three vertices of a triangle, and the angle is the angle subtended by the original line at the circumcentre. :wink:
:cool: join CAMREG … the CAMpaign for REal Geometry!​
So true. Parallel lines that meet a a point. Hubris!
I can't imagine how you know all this. Way classical education? I had one Euclidean geometry class in High School, sans circumcentres.
If I understand you correctly, I draw the pependicular bisectors through the remaining two sides. These will meet at an angle alpha=180-beta at the circumcentre I should expect alpha to be constant as much as beta is expected to be constant. But I can prove alpha is constant using isosoles triangles, right?
Phrak said:
I can't imagine how you know all this. Classical education? I had one Euclidean geometry class in High School, sans circumcentres.
ooh, I'm sorry, Phrak :redface: …
i hadn't realized so little classical geometry is taught nowadays …
ok, it's best to introduce this idea the other away round, by starting with a circle, and seeing what happens inside it …
one of the most useful circle theorems is that a fixed chord AB subtends the same angle ACB at any point C on the circumference on the smaller arc, and 180º minus that angle on the larger arc, and that the angle AOB subtended at the centre is twice the latter angle …
to prove that, let O be the centre of the circle, and let the line CO (with C on the larger arc) poke a little beyond O to Q …
then OAC and OBC are isoceles triangles ('cos it's a circle! :wink:)
and so you can prove that AOQ = 2ACO and QOB = 2OCB …
and then for your problem, simply do the same proof "backwards" :smile:​
No problem at all. Though it's been a while since high school for me. The classical studies are more common in the UK than the US, that makes the difference.
And thanks for the proof. :smile:
