Geotechnical: Prevent 500-Gallon Septic Tank Floating in Houston
  • Thread starter Thread starter Shackleford
To prevent a 500-gallon plastic septic tank from floating in Houston's groundwater, it is crucial to maintain the tank's capacity full to counteract buoyancy, especially if flooding is a risk. The tank should ideally be buried at least 4 feet below the surface to utilize earth cover, which helps resist flotation even when submerged. An engineering safety factor of at least 1.1 is recommended, calculated by comparing resisting forces to uplift forces. Resisting forces can be increased by adding more soil cover, constructing a concrete slab, or using deadmen and straps. Implementing helical anchors and straps can also enhance stability against flotation.
Shackleford
What capacity should be maintained to not float a 500-gallon plastic septic tank under groundwater-caused buoyancy? What other external installation steps should be taken to prevent floating. It rains a bit in Houston. Thanks.
If the tank is right at the ground surface, and flooding may occur to the ground surface, then it would need to be kept full to not float.
I assume the top of the tank is 4 feet or below below the ground, This Earth cover helps prevent flotation, even when entirely submerged. to determine likelihood of flotation, an engineering approach is to determine the safety factor; the resisting forces divided by the uplift forces. You would like to have a SF of at least 1.1 under worst conditions.
Uplift forces:
-tank outside vol x 62.4 pcf (if fully submerged)
Resisting forces:
-weight of soil over the tank (if submerged, effective soil unit weight is approx 100 pcf - 62.4 pcf)
-weight of tank & contents
To increase resisting forces, you could pile soil higher over the tank, construct a concrete slab over the tank, use concrete or other deadmen below/along tank with straps over the tank, etc. Helical anchors & straps another option.
What mathematics software should engineering students use? Is it correct that much of the engineering industry relies on MATLAB, making it the tool many graduates will encounter in professional settings? How does SageMath compare? It is a free package that supports both numerical and symbolic computation and can be installed on various platforms. Could it become more widely used because it is freely available? I am an academic who has taught engineering mathematics, and taught the...
  • · Replies 17 ·
  • · Replies 39 ·
15K
  • · Replies 19 ·
  • · Replies 19 ·
14K
9K
