Given a logistic function, calculate the constant
  • Context: MHB
  • Thread starter Thread starter docbrown1
    Constant Function
The discussion revolves around calculating the constant B in a logistic function given the condition f(0)=5. The context is primarily mathematical reasoning related to the evaluation of a specific function.
  • Homework-related, Mathematical reasoning
  • One participant presents the logistic function f(t)= (20)/ 1+Be^-1/2t and requests help in calculating B.
  • Another participant confirms the equation format and provides a mathematical representation.
  • There is a suggestion to substitute t=0 and f(t)=5 into the equation to find B.
  • A later reply indicates that after substitution, B is found to be 3, with an expression of satisfaction regarding this result.
  • Another participant agrees with the calculation of B being 3, affirming the correctness of the result.
Participants appear to agree on the calculation process and the resulting value of B as 3, although the initial steps and assumptions are not fully detailed or universally acknowledged.
There may be missing assumptions regarding the interpretation of the function and the conditions under which B is calculated, as well as potential ambiguities in the function's notation.
docbrown1
Please help!
calculate the constant B if f(0)=5
docbrown said:
Please help!
Hi docbrown, (Wave)
Welcome to MHB!
Is this the equation you wrote? $$f(t)=\frac{20}{1+Be^{-.5t}}$$
Jameson said:
Hi docbrown, (Wave)
Welcome to MHB!
Yes!
Is this your function?
$\displaystyle f(t)= \frac{20}{ 1+Be^\frac{-1}{2t}}$
Ok, then what we need to do is plug in $t=0$ and $f(t)=5$. What does our equation become when we plug in those two values?
From there we need to simplify but that will come after the above part. :)
I was that easy! Thank you very much! B=3 ! :)
Yep that looks correct. Well done. :)
  • · Replies 17 ·
