Glass beads bouncing on a balance pan
9 replies · 2K views · last reply
toboldlygo
[/B]
A stream of elastic glass beads, each with a mass of 0.53 g, comes out of a horizontal tube at a rate of 99 per second. The beads fall a distance of 0.49 m to a balance pan and bounce back to their original height. How much mass must be placed in the other pan of the balance to keep the pointer at zero?
impulse = force * Δp ==> F = mΔv/Δt
conservation of energy: potential energy = kinetic energy ==> mgh = 0.5mv2
I think I'm supposed to find the velocity of the initial and final moments (when the beads exit the tube, and as they hit the pan, respectively), then use that to find the force (using the impulse equation), and then find mass from that.
So, I set mgh = 0.5mv2, and using the velocity that I obtained, I solved for F (I used 1/99 as Δt), and then I divided that number by 9.81 m/s/s to get my answer. I don't know where I'm going wrong, though. Any help would be much appreciated!
That sounds ok, so please post your detailed working.
(I suspect you used the wrong value for Δv.)
Here's my work. I've attached it to the reply.
My suspicion is confirmed.
What happens to the bead after it hits the pan?
After it hits the pan, the beads bounce back up to their original height. But how does that factor into the velocity? The velocity of the bead is 3.1006 m/s before it hits the pan, and then zero when it does. Isn't that a change of 3.1006 m/s?
If its velocity is zero after hitting the pan, how does it regain its original height?
It couldn't, if its velocity were zero. Does that mean it hits the pan with twice the velocity? There can't be zero change in velocity, could there? I know what you're saying now, but I don't know how I would factor that into a solution.
Velocity and momentum are vectors; signs matter. If the velocity before impact is -x (up positive) what will it be after bouncing? What is the difference of the two?
Oh, that makes sense! So if I were to subtract initial from final, I'd get x-(-x), which is just 2x, right? Or did I completely miss the mark?
That's it.
