Gravitational Redshift: Will Two Lasers Operate Differently?
The discussion centers on the effects of gravitational redshift on the operation of two identical lasers placed at different altitudes—one at sea level and the other on a mountain. It concludes that while both lasers will operate at the same frequency when measured with identical local clocks, their frequencies will appear differently when measured from varying altitudes due to gravitational effects. Specifically, the mountain laser will exhibit a blueshift when observed from sea level and a redshift when observed from a higher altitude. The conversation also touches on the relationship between redshift and gravitational time dilation, confirming that both phenomena can be mathematically combined.
  • Understanding of gravitational redshift and blueshift
  • Familiarity with the principles of general relativity
  • Knowledge of laser operation and measurement techniques
  • Basic grasp of cosmological redshift factors
  • Study the principles of gravitational time dilation in detail
  • Learn about the mathematical formulation of redshift in astrophysics
  • Explore the implications of altitude on laser frequency measurements
  • Investigate the relationship between gravitational fields and light behavior
Physicists, astronomers, and students studying general relativity and cosmology, particularly those interested in the effects of gravity on light and time.
Torog
If we run two identical lasers and put one at sea level and one on top of a high mountain, will they operate at different frequencies?
They might depending on what altitude you're measuring their respective frequencies from. Measuring at an altitude different from the altitude of the respective laser will produce a red/blueshift. Measuring the frequency of the mountain laser from sea level will produce a blueshift, and measuring the frequency of the sea level laser from a higher altitude will produce a redshift.
Adding on to what @Drakkith said, if you measure their frequencies with identical local clocks they will read the same.
What if I use the lasers as clocks - measure the pulses, divide many times and put the data to a readout. Shouldn't the clock (laser) on the mountain be slower?
I do understand that light as it falls into a gravitational field it gains energy and moves to blue and the opposite happens as light has to work its way out of a gravitational field.
All of the above still applies. It will be slower than normal for any clock above it, faster for any clock below it, and unaltered for a clock right next to it.
Excuse me if I shift to cosmology. From what I understand the observed red shift of stars should come from three factors - according to the present model - First is a red shift given by the recession velocity (or general expansion of the Universe) second by the red shift caused by light having to make its way out of the gravitational field and third by the light having come from a star, quasar or other with a strong gravitational field where time and chemical processes run slower (redder) due to time being slower in the heavy gravitational field.
The second and third are the same.
We can combine redshift and gravitational time dilation like this:
$$ totalRedshift = \sqrt {redshift * gravitationalTimeDilation } $$
Or like this:
$$ totalRedshift = 0 * redshift + gravitationalTimeDilation $$
Or like this:
$$ totalRedshift = redshift + 0 * gravitationalTimeDilation $$That's a joke or something. But if we calculate the redshift factor and the gravitational time dilation factor, we always get the same number. So the formulas are correct, in a way.
