Gravitational time dilation reason
41 replies · 7K views
WannabeNewton,
I got stuck early in your explanation i.e at:
The position of ##O'## will be given by ##z_{O'} = \frac{1}{2}gt^{2}## and the position of ##O## will be given by ##z_{O} = h + gt^{2}##.
Please explain this like I have no clue about physics at all.
If something is free-falling, does the length it falls equal 1/2gt^2. If so, why?
And why is it gt^2 for O?
Roger
Hi roger! For an object under the force ##mg##, the path in general is given by ##z(t) = z_0 + v_0 t + \frac{1}{2}gt^2## where ##z_0## is the initial position and ##v_0## is the initial velocity. This is gotten simply by solving Newton's 2nd law for ## m\ddot{x} = F = mg##. ##O'##s initial position is at the bottom so he has ##z_0 = 0## and he starts out at rest so ##v_0 = 0##. ##O## is at the top so his initial position is ##h## (the height of the rocket) and he also starts out at rest so ##v_0 = 0##.
Hi WannabeNewton!
Would you mind solving the differential equation for me also?
I think I can see that if you integrate x'' once you'll get vt and if you integrate it twice you'll get 1/2gt^2.
But it was such a long time since I worked with differential equations so I do not remember and I cannot see it clearly.
Hope you don't think I am lazy for asking this.
Roger
Hi WannabeNewton!
Solving...
[tex]mx''=F=mg[/tex]
[tex]x''=F/m=g[/tex]
[tex]x'=F/m(t+A)[/tex]
[tex]x=F/m(t^2/2+At+B)[/tex]
[tex]x(0)=F/m*B=x_0[/tex]
[tex]x'(o)=F/m*A=v_0[/tex]
Which leads to
[tex]x(t)=x_0+v_0t+1/2gt^2[/tex]
Thank you for not solving it for me!
I will not be that lazy again :)
Roger
Hi WannabeNewton!
The last part of this statement:
has to be wrong.
Because the change in z should be the same for both O and O', right?
By the way, shouldn't g be substituted for the more general a while the rocket is moving upwards?
Roger
No roger ##z_{O}## and ##z_{O'}## don't represent changes in ##z## in the manner of which you speak. They simply track the positions of ##O## and ##O'## respectively relative to the origin of the inertial frame (which is at ##z = 0##).
##g## is just a label here. It was chosen as the label because in this example the rocket is at rest on the Earth so via the equivalence principle it's acceleration is ##g##.
Hi WannabeNewton!
So zo-zo' should not equal h?
Do you mind explaining why?
Roger
What? Yes ##z_{O} - z_{O'} = h## but how does that relate to your statement in post #36? This represents the distance between the two observers, not the position of the individual observers themselves relative to the inertial frame.
Post #36:
[tex]z_0=h+gt^2[/tex]
and
[tex]z_0'=\frac{1}{2}gt^2[/tex]
then
[tex]z_0-z_0'=h+\frac{1}{2}gt^2[/tex]
which has to be wrong, right?
Roger
Oh sorry, there should be a ##\frac{1}{2}## in front of the ##gt^2## for ##z_{O}##. My bad, I totally missed that! Sorry I wrote that original post up in a haste, so I made some careless errors.
I knew it!
I knew I was right!
But don't feel sorry, I will get back to you with more questions to be sorry about ;)
Roger
