Greatest even factor of 6m² + 4n² when GCD(m,n) = 2
  • Topic:
  • Thread starter Thread starter CharlesLin
    even Gcd
19 replies · 6K views
CharlesLin
this one got me thinking for a while it starts like this:
X=6m2+4n2
and Greatest Common Divisor(GCD) of (m,n)=2
what is the greatest EVEN number that must be a factor of X
I started this question by thinking what they asked, the gratest number that is a factor of X then I need to calculate X
I know that de GCD of m,n is 2, then I just have to find these two numbers, but the list of two numbers with 2 as a GCD start growing
(2,2)
(2,2)
(2,6)
(2,8)
(2,10)...
Therefore, I would like to know if you have a better way of finding "m" and "n", or how I can be sure that the a pair of those that I found is the correct.
Mathematics news on Phys.org
X=6m2+4n2
(2,2)
(2,2)
(2,6)
(2,8)
(2,10)...
gcd of m and n is 2. so we have m =2p and n = 2q with p and q are co-primes so they do not share a common factor. can you proceed from here
Ok following that hint that you gave me,
m=2p, n=2q
I try giving values to p and q. I toke in consideration that p and q are co-primes, in other words, they must consecutive.
p=2, q=3
x=6(16)+4(36)
x= 96+144
x=1050
then I have that 1050 is X but how can I know that the values that I chose for p and q are the appropiate?
If i continue form here knowing that the value of X=1050, I know that the gratest EVEN number that is a factor of 1050 ia 1050 Am I right? then 1050 is my answer!
m=2p, n=2q
p=2, q=3
x=6(16)+4(36)
x= 96+144
x=1050
you do not need x. you need to know the highest power of 2 that divides x.
further computation of x is incorrect. it is 240.
p and q need not be consecutive. That being said, try keeping the factor of 6m2 + 4n2 which is a power of 2 at a minimum. So you have m = 2p and n = 2q with p and q coprime odd numbers.
Erm... from the expression of x we can tell that x is even.
Isn't the greatest even factor of x then x itself? (Wondering)
Yes! I was thinking "minimum even factor of X".
- - - Updated - - -
Which would, of course, be 2. :o
ok, I feel more confused...
what I'm looking is X to be able to answer the question of What's the greatest EVEN number that is a factor of X.
the hint you gave me is that
I shoul find p and q which are co-primes but they aren't consecutive...
my question would be p=1 and q=3 could be a possibility?if so I would have X=168, however someone mentioned that I don't need to find X. I really don't understand why? and how do you know that p and q are co-prime and odd values?
If you use the hint provided by kaliprasad in his first post, you then obtain:
$$X=6\left(2p\right)^2+4\left(2q\right)^2=24p^2+16q^2$$
What do you get when you factor that?
well once you factor that expression...
$$8\left(3{x}^{2}+2{y}^{2}\right)$$
buth then, how do I know what is the answer?
Can you clarify the problem statement?
The greatest even factor (that is not necessarily prime) of X is X itself.
The greatest even prime factor is $2$.
We currently seem to be heading for the greatest power of $2$ that is a factor of X, but that is not what the problem statement is asking.
Yes, we get:
$$X=6\left(2p\right)^2+4\left(2q\right)^2=24p^2+16q^2=8\left(3p^2+2q^2\right)$$
Now, if we can find at least one ordered pair $(p,q)$ such that the factor $3p^2+2q^2$ is odd, then what may we conclude?
so we got to this point...
given this equation
$x=6{m}^{2}+4{n}^{2}$
what is the greatest even number that MUST be a Factor of X?
taking m=2p and n=2q
we have
$x=6{\left(2p\right)}^{2}+4{\left(2q\right)}^{2}$
x=$x=6{\left(2{p}^{2}\right)}+4{\left(4{q}^{2}\right)}$
$x=24{p}^{2}+16{q}^{2}$
$x=8\left(3{p}^{2}+2{q}^{2}\right)$
now I have to look for two numbers p and q that give me an odd number for $3{p}^{2}+2{q}^{2}$ is that right?
I choose p=1, q=3
but I still don't see the answer using (1,3) x=42 is this the answer?
What I was getting at is that if we can find a $(p,q)$ such that $3p^2+2q^2$ is odd (which you did, and in fact as long as $p$ is odd then $3p^2+2q^2$ will be odd) then we may conclude that the largest even number that will always be a factor of $X$ is $8$.
MarkFL said:
...the largest even number that will always be a factor of $X$ is $8$.
I think that should be: the largest power of 2 that is a factor of any $X$ is $8$.
The problem asked for the largest even factor of $X$...which does happen to be a power of 2 given that $\gcd(m,n)=\gcd(6,4)=2$. :)
thank you very much guys I think I almost got it.
so to find the greatest even number that must be a factor of X I don't need to fin X. Right?
then I don't need to find p and q. But then MarkFL how do you know that (m,n) is (6,4)=2
$X$ is given as a function of $m$ and $n$ and so it isn't one specific value, but varies according to the definition given.
We are told that $\gcd(m,n)=2$ and we can compute $\gcd(6,4)=2$ since the prime factorizations of these numbers are:
$$6=2\cdot3$$
$$4=2^2$$
and so we see the largest factor common to both is 2.
ok I understand,
but how do you know that (n,m) is 6,4 and no other number?
CharlesLin said:
ok I understand,
Sorry, I didn't mean to imply that $m$ and $n$ had any set values, I only meant:
$$\gcd(m,n)=2$$
and
$$\gcd(6,4)=2$$
