Hadamard and well-posed problems.
  • Context: Graduate
  • Thread starter Thread starter Kizaru
This discussion clarifies Hadamard's definition of well-posed problems, emphasizing the importance of uniqueness and continuous dependence on data. The properties outlined include that a solution must be unique and that it must depend continuously on the initial conditions. An example provided is the PDE y * uxx = x * uyy with specific boundary conditions, demonstrating that changing these conditions alters the solution, thus confirming the continuous dependence property. The participants agree that the solution's behavior aligns with Hadamard's criteria.
  • Understanding of partial differential equations (PDEs)
  • Familiarity with boundary value problems
  • Knowledge of mathematical topology related to continuity
  • Basic concepts of uniqueness in mathematical solutions
  • Research Hadamard's well-posed problem criteria in detail
  • Study the implications of uniqueness in solutions to PDEs
  • Explore continuous dependence in mathematical analysis
  • Examine examples of well-posed problems in differential equations
Mathematicians, students of applied mathematics, and researchers focusing on differential equations and mathematical modeling will benefit from this discussion.
Kizaru
Hadamard and "well-posed" problems.
I can't really find much clarification on Hadamard's definition of a well-posed problem.
My confusion comes from knowing exactly what is meant by the second and third properties:
2) The solution is unique
3) The solution depends continuously on the data, in some reasonable topology. http://en.wikipedia.org/wiki/Well-posed_problem"
For example, a solution would exist for a PDE y * uxx = x * uyy with u(0,y) = 2 and u(x,0) = 2 that is simply a constant. But is the solution, u=2, considered unique? Does the solution depend on the data?
Does the solution for u(x,y) fail property 3 because it no longer satisfies the PDE if the initial conditions are changed?
Edit: Maybe this belongs in the Differential Equations forum. Sorry. Can this be moved? Thanks.
Is there any other function of x and y that will satisfy those conditions? If not, then it is unique.
Well suppose the problem were exactly the same differential equation but u(0,y)= 3 and u(x,0)= 3. Then u(x,y)= 3 is a solution. Since changing the "data" changes the solution, yes, the solution depends on the data.
No, property 3 does not say that the solution must be independent of the initial conditions, it say it must depend on them continuously. suppose the intial conditions were u(x, 0)= 2+\delta, u(0, y)= 2+ \delta. Then [/itex]u(x,y)= 2+ \delta[/ itex] is obviously a solution. And, as \delta goes to 0, that solution goes to u(x,y)= 2. In that situation, the solution depends continuously on the initial values.
Okay, I will move it.
Thank you so much! It's much clearer than my professor's explanation :)
  • · Replies 36 ·
