Has Zeilinger disproven DeBroglie-Bohm?
  • Context: Graduate
  • Thread starter Thread starter dipstik
46 replies · 13K views
ueit said:
On what basis do you find EPR correlations "peculiar"? Do you find, say, energy conervation a "peculiar" fact? I can, for example construct a very complicated experiment in which energy is transformed in different ways, using all kinds of devices including free-willed experimenters. Should I expect a violation of energy conservation because all those devices "seem unrelated" "for all practical purposes"? I believe not.
This is a poor analogy--there would be nothing in any classical experiment that would require the system being investigated to behave as if it "knew" in advance what choice of measurement an experimenter would make, and alter its behavior in anticipation, as would be required to explain EPR correlations in the superdeterminism explanation. In classical experiments we would expect complete statistical independence between the state of the system at moments before a measurement and the experimenter's choice of what measurement to perform (assuming the experiments were repeated multiple times and the experimenters made their choices each time on a whim), while the superdeterminism explanation is explicitly based on rejecting this sort of assumption of statistical independence.
cesiumfrog said:
It's currently the first link on http://faculty.washington.edu/jcramer/NLS/NL_signal.htm" .
I confirm that statement, but I still can't donwload it. You must be right, it must be my browser. My box is screwed up anyway; I've been lazily not handling it; looks like it's now becoming obstructive. Perhaps this will motivate me.
cesiumfrog said:
I'm not caching it locally, I even checked in IE (though I don't recommend you continue with that browser). Are you behind some kind of filter?
Thanks for checking. I don't prefer Internet Exploder; Firefox is going to be nice to get back to, once I get motivated.
JesseM said:
From reading the wikipedia article I get the impression that superdeterminism is basically the same as the notion of a "conspiracy" in the initial conditions of the universe, which ensures that the hidden-variables state in which two particles are created will always be correlated with the "choice" of measurements that the experiments decide to make on them. So, for example, in any trial where the experimenters were predetermined to measure the same spin axis, the particles would always be created with opposite spin states on that axis, but in trials where the experimenters were not predetermined to measure the same spin axis, the hidden spin states of the two particles on any given axis would not necessarily be opposite.
Since in a deterministic universe the state of an experimenter's brain which determines his "choice" of what to measure on a given trial can be influenced by a host of factors in his past which have nothing to do with the creation of the particle (what he had for lunch that day, for example), the only way for such correlations to exist would be to pick very special initial conditions of the universe--the correlations would not be explained by the laws of physics alone (unless this constraint on the initial conditions is itself somehow demanded by the laws of physics).
Yes, that's also how I see it.
ueit said:
No such assumption is being made. Superdeterminism assumes that any given state is uniquely determined by the previous state. In some circumstances this may imply "strong correlations between events which have a "long" causal link" in others not.
That's "normal" determinism.
No, because in this case, there is a clear and simple correlation at each step which is evident from the laws of nature. But the obscure correlation which needs to exist between the spins of the sent couples of particles, and the *choices* that the observers are making on each side, is NOT the consequence of a straightforward and obvious chain of cause-effect relationships, but must be due to very very peculiar "initial conditions" far far behind in time, as JesseM pointed out. In other words, this correlation doesn't follow from a straightforward application of the *laws of nature* as we know them, but rather from very very "improbable" initial conditions billions of years ago.
The difference between normal determinism and superdeterminism is that in normal determinism, we assume that all events which are not obviously related by a *rather straightforward* cause-effect relationship, can for all practical purposes be assumed to be statistically independent (even though one might expect *small* deviations from strict statistical independency, depending on the "cutoff" one places on the straightforwardness of the cause-effect relationships). In superdeterminism, we assume that arbitrarily strong correlations can exist for arbitrary long "chains of cause-effect", such as "emission of a pair of photons" and "brain of Alice to decide to put the analyser to 60 degrees".
As for EPR, if a particle is only emitted when a signal from a available absorber arrives at the source, the "freedom assumption" falls. It is simply irrelevant how the absorber looks like or how it moves. The only thing that matters is that the absorber's motion is predictable so that it can be "calculated" at the source.
Right, and if that motion is determined by choices of people, for instance, then in this "calculation" must also be included the entire dynamics of the brain of that person. This is where, in normal determinism, one considers the causal chain that makes "the source calculate" and the "brain think" too long to be statistically correlated.
Perhaps superdeterminism can be more natural if particles don't really exist. You can imagine that there exists some deterministic theory and to do statistical computations you need to introduce ghost fields and a ghost Lagrangian which takes the form of the Standard Model.
The analogy was only intended to show how weak the "seemingly unrelated" argument is. There is very little similarity between a piece of plutonium, a pendulum and a jumping monkey. Nevertheless, we see no problem with the energy conservation when all these systems are let to interact.
In an EPR experiment all the devices are made from the same quantum particles therefore they should all follow the same physical laws. From a microscopic point of view a brain is not much different from a piece of wood.
Yes, but whereas the conservation of energy is "traceable" in each of the interactions, superdeterministic correlations are by definition untraceable. You have no explanation of why the choice made by the brain of Alice has to be correlated with the emission of a photon pair in a PDC X-tal for instance. You just have to say that "these correlations have to be exactly like this and such" for the EPR correlations to emerge. There's no other explanation as that in the far past, both must have some common origin. The funny thing is that an obscure common origin in the past generates exactly these correlations, but BIG CHANGES in the present don't affect these correlations (if you let Alice's brain decide, or you let a random number generator decide, or a decaying radioactive substance, the correlations are always EXACTLY THE SAME).
With the conservation of energy, we know at each step, at each interaction, that there is conservation of energy (and can work this out in detail if we want to). So the causal link is clear. In superdeterminism, the link is not clear.
As I said, this is the basis of astrology. Given that, say, my love life, and the origin of the solar system have a common origin, it shouldn't be a surprise in superdeterminism that the constellation of the planets is strongly correlated with the ups and downs of my love life.
Arguing for "superdeterminism" on this basis is not sensible. There are specific useful theories - which make testable predictions - regarding conversation in interacting systems. That is good science.
On the other hand, superdeterminism in effect postulates that apparently non-interacting systems meet certain requirements - but those requirements are only apparent in very specific cases. There are no useful predictions, and entirely new science is required to explain why there are no other artifacts of superdeterminism. In other words, the cure is worse than the disease it was intended to solve.
No, "normal determinism" has the "freedom" assumption included. Drop that assumption and you get a nice, logically consistent determinism that is also called superdeterminism.
I've probably described my superdeterministic mechanism very badly because it has nothing to do with the fine tuning of initial conditions. I'll try to make it clearer with another analogy.
An experiment is performed to study molecular fluorescence. A solution containing a fluorescent molecule is prepared. A visible light detector is used. Now, let's assume that our detector contains the UV source inside it, without the knowledge of the experimenter. Also, the mechanism of this emission is not known. No one knows that a UV source is required because all detectors contain such a source, this source is always on, and the secret is carefully preserved.
The experiment intends to study how the intensity of the fluorescence radiation varies with the distance to the detector. Strangely enough, the intensity decreases much faster than in the case of "normal" radiation.
Obviously, the explanation for this result is that the fluorescence is caused by the detector itself, therefore moving the detector changes the source's intensity. The velocity with which the detector is moved is also important because of Doppler effect (the incoming UV radiation has a different energy). One can easily see that in this case, maintaining the assumption that the detector's state and the properties of the fluorescence emission are statistically independent gives nonsensical results.
Back to our EPR experiment, if the detector's presence is the direct cause of the emission of the entangled particles, as I propose (an idea also common to the Cramer's transactional interpretation) one has to drop the "freedom" assumption so Bell's theorem cannot be used to reject it.
Sure, in addition to the above mechanism an extrapolation mechanism is required to explain the delayed choice experiments, the source must adjust its emission to the future detector's state. Such a mechanism is known in GR where a body accelerates to the future locations of the other bodies. As JesseM pointed out in another discussion on this topic, the mechanism is not perfect as it works only for uniform and uniform accelerated motion. Nevertheless, it is good enough so that a non-local theory, Newtonian gravity is used for most practical applications like spaceships trajectory calculations and computer simulations of galactic motion.
I hope that the causal relationship detector-source is straightforward enough, in the light of the above proposed mechanism. The source reacts to the field produced by all particles around it, including those from Alice's brain. I see no problem with that.
Gravitationaly, the Earth accelerates towards the future position of the Sun, Mars, Jupiter, and so on. Now, if I take a bunch of asteroids and arrange them in the same way like the particles inside Alice's brain will you predict that Earth would simply stop following GR' s equations and start being confused about the strange structure near it?
It depends on what someone is testing. If a very delicate experiment is performed and the EM field produced by the brain matters, one cannot ignore it, even in classical determinism. I claim that this is the situation we have in QM. The difference is that one cannot eliminate the problem by increasing the source-detector distance, because not the intensity of the resultant EM field is important but the information exchanged at each particle's level during the interaction that precedes the emission of the entangled pair.
In the case of EPR I proposed a clear mechanism that relates the source emission with the detector's state. Their common origin at the Big-Bang is only a necessary condition in this case.
The negation of the "freedom" assumption does not come from the superdeterministic part of my idea (the GR-like extrapolation mechanism) but from the emitter-absorber theory at the basis of Cramer's transactional interpretation (TI). TI is a general interpretation, not specifically designed for EPR.
I don't understand your issue with the absence of predictions as we discuss various possible interpretations of the same formalism. AFAIK no extant QM interpretation is falsifiable so why should you ask this in the case of a hypothetical superdeterministic one?
ueit said:
in addition to [stimulation from the detector] an extrapolation mechanism is required to explain the delayed choice experiments, the source must adjust its emission to the future detector's state. Such a mechanism is known in GR [..] the Earth accelerates towards the future position of the Sun
Being a GR person, it took a long time to figure out what you are talking about. So that you know, it is not a GR effect, it is a SR effect that is best exhibited in classical EM. It is well known that in constant motion the (retarded) electric field lines of a charged particle already point to where the particle will be "now" (unless something has happened to the particle in the intervening time). I think if you understood the derivation of this fact better, you might realize what a stretch it is to relate this to backward causation.
You're conflating two different paths. Backward causality (a la Cramer's transactional interpretation, which alas has yet been demonstrated leading to little more than crackpottery) is a path that can explain QM even presuming that different elements are completely unconnected in the past (their future-interaction produces correlation), whereas super determinism (i.e., anything that completely hinges on elements still being correlated now due to interactions far back at the beginning of the universe) has no purpose for backward causation. Can I suggest you stick to just one interpretation at a time?
I think you aren't realizing the gigantic gap between the type of "extrapolation" seen in electromagnetism or GR (where in some circumstances objects will be pulled towards the current position of another object rather than its retarded position) and the type of extrapolation you're imaging where the particles can predict what the experimenters will later choose to measure. The first just involves extrapolating the position of a single object based on some derivative of its position--velocity, acceleration, whatever--whereas the type of extrapolation you're imagining would require some kind of computation of the nonlinear interactions of a vast number of particles in order to predict their future behavior from their past state. There's really no comparing the two, the existence of the first type of extrapolation can't be used to argue that the second type is at all plausible, and it's completely misleading to say that this fantastical second type is "GR-like extrapolation".
This is the sort of thing I'm talking about when I say you misunderstand the sort of extrapolation that occurs in theories like E&M or GR. In a situation with a large number of gravitating bodies of similar mass the Earth definitely would not act like it it knew the current position of each body in deciding how to move, because their current positions would depend on their mutual gravitational interactions rather than just extrapolating each one's velocity or acceleration individually.
You are treating the Big Bang singularity itself as if it can contain information which is accessible to any object that has the singularity in its past light cone (i.e the entire universe)? Because for any finite moment after the Big Bang, no matter how tiny the amount of time, there will be events at that moment which are in the past light cone of the moment where the experimenter makes a decision (and thus could deterministically influence the decision) but which are not in the past light cone of the creation of the entangled particles (so they wouldn't have that information available to 'extrapolate' with). If your argument depends on the singularity itself, does that mean you reject the notion that quantum gravity will do away with the infinities of GR, and believe there can be physically real singularities of infinite density where an infinite number of worldlines all converge?
I've chosen GR because in this case the extrapolation is much better than in the case of EM interaction. The source (Aberration and the Speed of Gravity, S. Carlip) is here:
http://arxiv.org/PS_cache/gr-qc/pdf/9909/9909087v2.pdf
Abstract
The observed absence of gravitational aberration requires that “Newtonian” gravity propagate at a speed cg > 2 × 10^10c. By evaluating the gravitational effect of an accelerating mass, I show that aberration in general relativity is almost exactly canceled by velocity-dependent interactions, permitting cg = c. This cancellation is dictated by conservation laws and the quadrupole nature of gravitational radiation.
As this article points out, gravity can be assumed, for all but some extreme situations (like binary pulsars) to propagate instantaneously. This works even for some types of accelerated motion (unlike EM interaction). Therefore we already have an example where a local theory "looks" non-local even if not exactly so.
The only part of TI that i find interesting is the idea that a particle is not emitted at random but only after a previous contact absorber-emitter. I do not entertain the idea of backward causality and in fact I am trying to replace it with a "normal" causal chain backed up by some "extrapolation" effects.
I see no reason to believe that regions "completely unconnected in the past" really exists. It depends on the assumptions one makes about the nature of big-bang. So, I am not sure that thinking about how such regions may interact is meaningful.
"All but some extreme situations" is completely wrong--at best the article says that constant acceleration can be extrapolated, but in any situation involving mutual gravitational interactions between multiple bodies (in situations where one body does not completely dominate like the Sun in our solar system) the sign of these interactions is that the acceleration of each body is changing in complicated ways (even the 3-body problem is too complicated for physicists to find an exact solution), you couldn't predict how anybody would move just by knowing its own position and derivatives of its position like velocity and acceleration. As I pointed out in my last post, your argument about QM assumes a completely un-GR-like form of "extrapolation" where the extremely complex interactions of all the particles in the experimenters' brains can somehow be predicted by particles before they happen.
A body accelerates as a result of its interactions with another bodies. If this acceleration is of a type that can be extrapolated, then the evolution of a system with a "vast number of particles" can be perfectly predicted. This might be not so in GR but I see no reason to force the dynamics of the quantum particles to be exactly like that in GR. One could restrict, for example, the types of motion a particle can have to the "predictable" ones.
The singularity means that the theory has failed do describe the studied phenomenon. I see the big-bang as a deterministic process in an eternal universe. For example, if there was a big-crunch before our big-bang, the particles must have been in connection to one another. This memory was not erased at big-bang.
Anyway, until a quantum theory of gravity is found we can only speculate about this. For the time being I know of no evidence that such disconnected regions exist and I am not sure how such a situation can be described by our theories. For example two charged particles in such a situation would not "feel" the EM force but they start "sensing" it as they come close to one another. Is such a process described by QM?
You can't extrapolate the motion of any single body in a 3-body problem (or N-body problem) if all you know is the body's own instantaneous position, velocity, and acceleration (or further derivatives of position). As far as I can tell GR's extrapolation is based solely on the body's own movements, there is no semblance whatsoever of extrapolating mutual interactions between bodies over time.
edit: Technically maybe if you knew the exact value for a near-infinite number of derivatives of position you could predict the motion in an N-body problem, because as long as position as a function of time is a real analytic function (no instantaneous changes in velocity, acceleration, or any other derivative of position) then the whole path is equivalent to an infinite Taylor series. However, since situations involving more than two bodies tend to be chaotic, there'll be sensitive dependence on initial conditions so if you use only a finite number of derivatives in the Taylor series, the predicted path will eventually diverge completely from the actual path. Carlip says here that electromagnetism can "extrapolate" constant-velocity motion because "the lowest-order radiation is dipole radiation", and GR can extrapolate some other types of motion like constant-acceleration because its lowest-order radiation is quadrupole, so you'd probably need some insanely complicated theory whose lowest-order radiation was "trillionpole" or "googolplexpole" or something in order for the theory to extrapolate motion due to mutual interactions or a three-body system for any significant length of time.
Both quantum field theory and classical electromagnetism have a light cone structure, particles can only be affected by things in their past light cone. "Disconnected" regions just mean that the past light cones of events in the two regions don't overlap (again, unless you treat the Big Bang singularity itself as an event which both light cones include).
There is no hypothetical superdeterministic particle theory, except perhaps in your imagination. Perhaps you would care to actually work out such a theory. Or do you consider that too trivial to bother with?
The problem with such a theory is that it would have a problem explaining why - if everything casually connects back to an earlier point in time - only the relative settings of separated measurement devices (themselves being macroscopic objects) are relevant to the observed outcomes. All other states of all other particles, measurement devices, ensembles, etc. all magically cancel out. And yet the individual results are still random! Further, the observed effect is noticed nowhere else.
It is these troubling details that cause me to have an issue with your off-the-cuff remarks.
