What are the Appropriate Orifice Sizes for Uniform Exit Temperatures?
The discussion focuses on determining appropriate orifice sizes for achieving uniform exit temperatures of 140°F from four heating components (50W, 500W, 1000W, and 300W) in a cabinet at a 70°F ambient temperature and sea level pressure. Key principles include conservation of mass and heat transfer calculations, specifically using the equation Q = mdot * cp * dt, where Q represents the power output of the heater. To solve for the orifice size, one must first establish the mass flow rate (mdot) based on the known parameters and then calculate the required area and diameter for the orifice.
  • Understanding of heat transfer principles, specifically Q = mdot * cp * dt
  • Knowledge of fluid dynamics, including mass flow rate calculations
  • Familiarity with control volume analysis in thermal systems
  • Basic concepts of orifice flow and area calculations
  • Learn about conservation of mass in fluid systems
  • Study heat transfer methods in enclosed spaces
  • Research orifice flow equations and their applications
  • Explore how to calculate flow rates and velocities in thermal systems
Engineers, HVAC professionals, and anyone involved in thermal system design and optimization will benefit from this discussion, particularly those focused on achieving specific temperature outputs in controlled environments.
elmandilon11
I need help, hope somebody can give me a hint
Determine the appropiate orifice sizes for uniform exit temperatures of 140F from the four units in 70F ambient/ sea level pressure? Components (50W, 500W, 1000W and 300W)
Thank you
you are going to have to be a little more specific here. Internal flow, external flow, modes of heat transfer? you clearly must be confused, you need to learn how to ask the right questions
Sorry,
I do have a problem. It is a cabinet, it has 4 components. Each component has has an inlet an an exit orifice where the air passes through. I would like to determine the orifice size for uniform exit temperatures of 140F from the four components in 70F ambient at sea level pressure.
Am I correct in saying that the air is heated inside the compartment? I will assume that I am. for started let's make a control volume. Say we make a control volume around one compartment. We know by conservation of mass that mdotin=mdotout, and that Q=mdot*cp*dt, where dt=To-Ti. So if we say that Q is the power given off by the heater inside the compartment (which is given in the problem) then we have everything we need to solve the problem.
remember that mdot=(rho)(A)(V), you know rho given the 1 atm at 70
you know Ti=70
To=140
Given Q
Solve for mdot
But you need to know a flow rate to know a velocity at which the air is entering the compartment so you can solve for area and then diameter.
I may have miss understood your question but if you are given a flow rate or velocity then follow these steps.
  • · Replies 21 ·
9K
