Help Verifying Schrodinger's equation in different potentials
The discussion revolves around verifying Schrödinger's equation in different potential regions, specifically focusing on wave functions and probability currents in quantum mechanics. The original poster attempts to analyze a scenario involving three regions with varying potentials and to understand the implications of wave behavior at boundaries.
  • Exploratory, Assumption checking, Mathematical reasoning
  • Participants discuss the formulation of wave functions in different regions and the interpretation of reflected and transmitted waves at potential discontinuities. There are questions about the normalization of wave functions and the calculation of probability currents. Some participants suggest simplifying the problem by dropping time dependence and focusing on the time-independent Schrödinger equation.
The discussion is ongoing, with participants providing insights on boundary conditions and the mathematical expressions for probability currents. There is recognition of the need to apply boundary conditions correctly, and some participants express confusion regarding the normalization process and how to reconcile their results with those found in reference materials.
Participants are working under the constraints of homework guidelines, which may limit the information they can share or the methods they can use. There is also an emphasis on ensuring continuity of wave functions across boundaries, which is a critical aspect of the problem being discussed.
ja07019
I am asked to find the probability current density. The set up is one dimensional along the z-axis and it goes as follows: for z>0, V=0 which has the solution of the time independent SE. For 0<=z<d, V= Constant, which has the solution of the time dependent SE. In addition to V being nonzero, V> E, the energy of the electron. For z>d, then V=0 which is once again the time independent SE. I need verification on the equations I will be using. In addition I amy
Schrodinger's Wave equation
There are 3 regions, to which I split the function as follows. I can derive the solutions myself. However I need to verify whether I am using them properly.
There are two principles/ideas that I am not sure if I am misinterpreting.
1) Anytime a wave is incident on a discontinuity(such as when a light ray enters a water, there is a transmitted wave and a reflected wave.
2) Tunneling is the phenomena when an electron can appear on the other side of a potential barrier and still have the same energy as before.In the first region where z>0 and V=0, I have ##exp(-i \frac{E}{ \hbar }t) \left[ Aexp(ik_1z) + Bexp(-ik_1z) \right]##
where ##k_1^2= \frac{2mE}{\hbar ^2}## . E is the energy of the electron. The ##+i_k1z## term represents a wave traveling in the +z direction and the ##-k_1z## term represents the wave reflected at z=0.
In region 2, 0<=z<d and V=V. Here I have ##exp(-i \frac{E}{ \hbar }t) \left[ Cexp(ik_2^{'}z) + Dexp(ik_2^{'}z) \right]## where ##(k_2^{'})^2 = \frac{2mE}{ \hbar ^2}(E-V)## . Let ##k_2=\frac{2m}{ \hbar^2}(V−E)## and thus ##(k_2^{'})^2 = -k_2^2##. Which leads to ##k_2^{'}=ik_2##.
So in effect this is the actual wave equation in Region 2, ##exp(-i \frac{E}{ \hbar }t) \left[ Cexp(-k_2z) + Dexp(k_2z) \right]##.
So here I am saying that there is a wave moving in the +z direction, and because of the discontinuity at z=d, there is a reflected wave.
Finally in region 3 I have ##exp(-i \frac{E}{ \hbar }t)Fexp(ik_3z)##.
Since there are no more discontinuities in front of region 3, there is no reflected wave. In addition I am saying that because the electron has the same energy as before crossing the potential barrier, then k3=k_i and thus I can simply find that. So I end up with ##exp(-i \frac{E}{ \hbar }t)Fexp(ik_1z)##.
I am unsure about how to find the probability current of the transmitted current. My issue here is that I end up with the constant C. I am unsure about how to normalize the wavefunctions here.
Please use LaTeX to write your equations. They are very hard to read. If you don't know how to use LaTeX, click on the LaTeX Guide link lower left, above "Attach files".
Sorry about that. I have made those edits.
Thank you for the edits.
Do yourself a favor and drop the time dependence, i.e. solve the TISE. Then you will have
\psi(z) =
\begin{cases}
Ae^{ik_1z}+Be^{-ik_1z} & z \leq 0 \\
Ce^{k_2z}+De^{-k_2z} & 0 \leq z \leq d \\
Fe^{ik_1z} & z \geq d
\end{cases} $$
Note that the term ##Ae^{ik_1z}## is the incident wave on the barrier. At the first boundary ##z=0##, the fraction of the wave that is reflected is what counts not the value of ##B## by itself. So set ##A=1##, apply the 4 boundary conditions and then use the expressions for the probability current.
Thank you for the response. I have been trying to figure this out but I can't seem to get the answer the book gets. Here is my work for the Probability Current
In region 3,
##J_3 \propto \psi_3^{*} \frac{d \psi}{dz}-\psi_3 \frac{d \psi_3^{*}}{dz}##
## = Fexp(-ik_1z)(ik_1)Fexp(ik_1z)-Fexp(ik_1z)(-ik_1)Fexp(-ik_1z) = ik_1F^2--ik_1F^2 = 2ik_1F^2##
In region 1,
##J_1 \propto \psi_1^{*} \frac{d \psi_1}{dz}-\psi_1 \frac{d \psi_1^{*}}{dz}##
## = Aexp(-ik_1z)(ik_1)Aexp(ik_1z)-Aexp(ik_1z)(-ik_1)Aexp(-ik_1z) = ik_1A^2--ik_1A^2 = 2ik_1A^2##
Note here I use only the transmitted wave and not the Transmitted+Reflected Wave Function. Doing so would lead to,
##J_1^{'} = [Aexp(-ik_1z)+Bexp(ik_1z)][ik_1Aexp(ik_1z)+-ik_1Bexp(-ik_1z)] - [Aexp(ik_1z)+Bexp(-ik_1z)][-ik_1Aexp(-ik_1z)+ik_1Bexp(ik_1z)] = ik_1A^2exp(ik_1z-ik_1z)-ik_1ABexp(-2ik_1z)+ik_1ABexp(2ik_1z)-ik_1B^2exp(ik_1z-ik_1z)-[-ik_1A^2exp(ik_1z-ik_1z)+ik_1ABexp(2ik_1z)-ik_1ABexp(-2ik_1z)+ik_1B^2exp(ik_1z-ik_1z)] = ik_1A^2--ik_1A^2-ik_1ABexp(-2ik_1)+ik_1ABexp(-2ik_1)+ik_1ABexp(2ik_1z)-ik_1ABexp(2ik_1z)-ik_1B^2+-ik_1B^2 = 2ik_1(A^2-B^2)##
For continuity I have,
##\psi_1(0,t) = \psi_2(0,t)##
##Aexp(ik_1*0)+Bexp(-ik_1(0)) = Cexp(k_z*0)+Dexp(-k_2*0) = A+B = C+D##
##\frac{d \psi_1(0,t)}{dz} = \frac{d \psi_2(0,t)}{dz}##
##ik_1Aexp(ik_1*0)+-ik_1Bexp(-ik_1(0)) = k_2Cexp(k_z*0)+-k_2Dexp(-k_2*0) = ik_1A-ik_1B = k_2C+-k_2B##
##\psi_3(d,t) = \psi_2(d,t)##
##Fexp(ik_1d) = Cexp(k_2d)+Dexp(-k_2d)##
##\frac{d \psi_3(d,t)}{dz} = \frac{d \psi_2(d,t)}{dz}##
##ik_1Fexp(ik_1d) = k_2Cexp(k_2d)+-k_2Dexp(-k_2d) ##
I just can't see how the book arrives at their answer of
##\frac{J_3}{J_1} = [cosh^2(k_2d)+\frac{1}{4}(\frac{k_2}{k_1} - \frac{k_1}{k_2})^2sinh^2(k_2d)]^-1##
Looking at the ##\frac{J_3}{J_1}##, it seems like both regions should have continuity satisfied via exponential's but only Region 3 has these continuities. Setting ##A=1##, I still have to deal with B.
  • · Replies 22 ·
