- #1
lemma28
- 18
- 1
I know that with an Hermitian operator the expectation value can be found by calculating the (relative) probabilities of each eigenvalue: square modulus of the projection of the state-vector along the corresponding eigenvector.
The normalization of these values give the absolute probabilities.
Alternatively it's possible to calculate directly the expectation value by the compact formula <A>=<psi|A|psi>.
I got stumbled considering what adjustment to take in case of an operator that is not Hermitian.
In this case the eigenbasis is not orthonormal. But I feel that there should be some way to calculate the expectation value of the operator nonetheless.
Am I wrong? Or there's no meaningful way to define it in the non hermitian case?
If the procedure is more or less the same with some adaptation to make then:
Which projection to take? the components in the eigenbasis or the orthogonal projections of psi along the eigenvectors?
Is there an analog of the formula <A>=<psi|A|psi> that is correct in the non.orthonormal basis?
Any help appreciated
Thanks
Thanks
