Help with geometry proofs for Monday exam
  • Thread starter Thread starter ccseagle
    Geometry Proofs
42 replies · 42K views · last reply
ccseagle
Geometry Proofs.. Help!
Please please someone help me! :eek: I have a Geometry Exam on Monday and I don't understand proofs one bit :cry: ! If someone could help me with a few proofs that would be so awesome!
Have you got any specific questions?
yeah, could you help me with this proof..
Given: B is between A and C; D is between C and E; and C is the midpoint of line BD and of line AE
Prove: line AB is congruent to line DE
Picture:
<--A---B---C---D---E-->
Picture:
Ok, I'll give a hint. You know that [tex]|\vec{AC}|=|\vec{CE}|[/tex] so start with this, then express both sides of the equation in terms of two new lengths. Have a go, and post your thoughts.
AB+BC= line AC
and
CD+CE = line CE
I don't know, am I even on the right track??
Yes, so now the equation becomes:[tex]|\vec{AC}|=|\vec{CE}| \Rightarrow<br /> |\vec{AB}|+|\vec{BC}|=|\vec{CD}|+|\vec{DE}|[/tex] Carry on with this.
Ok, my notation
means that the length of the line AC is equal to the length of the line CE (this is equivalent to the two lines being congruent).
We know that AC is congruent to CE, since C is the midpoint of AE. CAn you say anything similar regarding the lines BC and CD
WEll, C is the midpoint of BD, therefore BC and CD are congruent. Now look at the equation given in post #7. What does this tell you?
I don't think I understand.. Can you give me a hint??
Not without giving you the answer! Ok, here goes: The equation can be rearranged to give
[tex]|\vec{AB}|-|\vec{DE}| =|\vec{CD}|-|\vec{BC}|[/tex]
Now, since the BC and CD are congruent, what can say about the RHS of the equation? What does this then imply?
Right hand side. Ok, if two lines are congruent, then it means they have the same length. Let's call this length x. Then the RHS is x-x=...?
Well, [tex]|\vec{AB}|-|\vec{DE}| =|\vec{CD}|-|\vec{BC}|=0 \Rightarrow |\vec{AB}|=|\vec{DE}|[/tex]
And so, the lines AB and DE are congruent.
Ok, i think i get it.. Thanks.. Do you think you could help me with a couple more??
Maybe one, it's getting quite late. Post your attempt at a proof to the problem you post first though.
ok, thanks..
Given: angle 8 and angle 1 are supplementary
Prove: angle 4 is congruent to angle 6
Picture:
___________________________________________
-angle 1 is congruent to angle 3 because they are vertical angles
-angle 8 is congruent to angle 6 because they are vertical angles
-supplementary means that the sum of two angles equals 180 degrees
-angle 8 and angle 1 are congruent because of corresponding angles
Careful.. You said 8 and 1 were supplementary!
From what we are given, and your points in your previous post,
6=8=180-1
Now, since 1 and 2 are angles on a line, what can you say about 2 in terms of 1? how is 2 related to 4?
-angle 2 and angle 4 are vertical angles
-angle 2 and angle 1 is a linear pair
but also in my given it says that angle 1 and angle 8 are supplementary...
Yes, so 2=180-1 and 2=4. Put these into the eqn above
the equation in post #25??
and i don't understand wut u mean.. how do i put into the equation above??
