Help with Inductance Homework: Calculate from 84V, 80kOhms & .5355mA
  • Thread starter Thread starter gmiller4th
    Inductance
The problem involves calculating the inductance of a circuit containing an inductor and a resistor connected to a battery. The circuit parameters include a voltage of 84V, a resistance of 80 k-Ohms, and a current of 0.5355 mA measured 0.8 milliseconds after the switch is closed.
  • Exploratory, Conceptual clarification, Mathematical reasoning, Problem interpretation, Assumption checking
  • Participants discuss the application of Kirchhoff's Voltage Law and the formulation of a differential equation for the circuit. There are attempts to clarify initial conditions and the role of the battery voltage in the calculations.
The discussion is ongoing, with participants providing guidance on formulating the differential equation and emphasizing the importance of initial conditions. There is recognition of the need to correctly identify the battery voltage in the context of the problem.
There is some uncertainty regarding the initial conditions of the circuit, specifically whether the inductor was connected to the battery before the switch was closed. This detail is noted as significant for solving the differential equation.
gmiller4th
A inductor that has a resistance of 80 k-Ohms is connected to an ideal battery of 84V. 0.8 milliseconds after the switch is thrown the current in the circuit is .5355 mA. Calculate the Inductance. answer in units of H.
V = L(I/t)?
Well at first I thought there was a voltage drop when the switch was thrown, I calculated that at 42.84V after the switch is thrown. But I have no idea if that's even right.
Any guidance or help will be greatly appreciated.
Try writing the differential equation for a battery, inductor, and resistor all in series, with current flow starting when a switch closes the circuit. Solve the differential equation and see if this does not get you going.
This is the only differential equation I know for an inductor in series with a resistor.
I'll keep trying and reading my book though, I've been working on this problem for the last two hours though :cry:
You have not included the battery. Don't you know Kirchoff's Voltage Law? Apply that for this case. You have part of the necessary expression here, but put it all together as a D.E. for the circuit.
Actually I believe he has his battery voltage right there as Vin.
First you got to specify your initial conditions more clearly. Was the inductor attached to the battery prior to t=0 or was the battery connected at t=0? Or was the battery disconnected at t=0?
This is important as it will define your initial conditions for the DE.
Thats it... Solve the DE and your job is done
Its not right when you don't recognize that Vin is the battery voltage. Until that point, it is wrong. (Battery voltages are usually denoted by those who recognize them as such, as E, rather than Vin.)
Fair enough
9K
9K
