Help with something to do with angular stuff?
  • Thread starter paradoxical
    Angular
6 replies · 2K views · last reply
paradoxical
A copper block rests 39.0 cm from the center of a steel turntable. The coefficient of static friction between the block and the surface is 0.34. The turntable starts from rest and rotates with a constant angular acceleration of 0.50 rad/s2. After what time interval will the block start to slip on the turntable? (Hint: The normal force in this case equals the weight of the block.)
I seriously have no idea which formulas to use...Thanks!
Solved...thanks
Do you know how to calculate the centrifugal force on a rotating object?
I only know how to do centripetal forces...
Actually hold on...maybe
I have down the formula:
force that maintains circular motion=mrw^2
If there was a way to find angular displacement, that would be helpful.
If you're trying to confuse the poor lad, that's not very nice. Centrifugal force, as I'm sure you know, is a fictional force, which means, for the purposes of this thread, that it doesn't exist.
Ok...I'm trying to calculate what Fs is now...thanks!
