Hermitian operators, matrices and basis
The discussion revolves around the properties of Hermitian operators and their representation as matrices, particularly in relation to different bases. Participants explore the conditions under which Hermitian operators can be represented by diagonal matrices and the implications of these representations in finite and infinite-dimensional vector spaces.
  • Some participants propose that Hermitian operators can be represented by diagonal matrices in a basis of their eigenvectors, with the diagonal elements corresponding to the eigenvalues.
  • Others argue that while diagonal representation is possible in the eigenvector basis, the eigenvalues can be arranged in various orders on the diagonal.
  • A later reply questions the feasibility of representing operators in infinite-dimensional vector spaces as matrices, suggesting that this may not always be possible.
  • Another participant notes that if the basis vectors in an infinite-dimensional space can be ordered in a specific way, it may be possible to represent the operator as a matrix, but this depends on the nature of the basis.
Participants generally agree that Hermitian operators can be represented by diagonal matrices in the eigenvector basis, but there is disagreement regarding the representation in infinite-dimensional spaces and the ordering of eigenvalues.
Limitations include the assumptions about the dimensionality of the vector space and the nature of the basis vectors, which affect the representation of operators as matrices.
Trixie Mattel
Hello, I would just like some help clearing up some pretty basic things about hermitian operators and matricies.
I am aware that operators can be represented by matricies. And I think I am right in saying that depending on the basis used the matrices will look different, but all our valid representations of the operator.
As I understand it, there exists a basis where hermitian operators can be represented by a diagonal matrix
Is the only basis that this can occur in the basis of the eigenvectors of the hermitian operators. And the diagonal matrix elements of the hermitian operators are the eigenvalues of the operator??
In summary I am asking, is the only basis in which a hermitian operator is represented by a diagonal basis the basis of the eigenvectors? And for the diagonal matrix are the elements the eigenvalues of the operator?Thank you
Given any basis [itex]|\psi_j\rangle[/itex], you can use that basis to represent arbitrary states as column matrices. Letting [itex]\mathcal{R}(|\psi\rangle)[/itex] mean the matrix representation of [itex]|\psi\rangle[/itex], we can choose [itex]\mathcal{R}[/itex] so that:
[itex]\mathcal{R}(|\psi_1\rangle) = \left( \begin{array} \\ 1 \\ 0 \\ . \\ . \\ . \end{array} \right)[/itex]
[itex]\mathcal{R}(|\psi_2\rangle) = \left( \begin{array} \\ 0 \\ 1 \\ . \\ . \\ . \end{array} \right)[/itex]
[itex]\mathcal{R}(|\psi_3\rangle) = \left( \begin{array} \\ 0 \\ 0 \\ 1 \\ 0 \\ . \\ . \\ . \end{array} \right)[/itex]
To say that an operator [itex]\hat{O}[/itex] is diagonal in this basis is to say that its representation is given by:
[itex]\mathcal{R}(\hat{O}) = \left( \begin{array} \\ \lambda_1 & 0 & ... \\ 0 & \lambda_2 & 0 & ... \\ 0 & 0 & \lambda_3 & ... \\ . \\ . \\ . \end{array} \right)[/itex]
Yes, [itex]\lambda_1, \lambda_2, ...[/itex] are the eigenvalues of [itex]\hat{O}[/itex] and [itex]|\psi_j\rangle[/itex] are the eigenvectors.
Yes, but note that you can put the eigenvalues to many different orders on the diagonal, in which case different unit vectors of Rn correspond to the values. Also, an operator can be defined on an infinite-dimensional vector space, in which case you can't write it as a matrix.
Why not?
PeroK said:
Why not?
Well, you can do it if the basis vectors can be ordered in such a way that there's some obvious pattern in the matrix elements, but think about a vector space that has a basis with the same cardinality as the set of real numbers.
Got it, thank you!
