Hexagonal Close Packing (Why do I get c/a = 3^1/2 ?)
  • Thread starter Thread starter WolfOfTheSteps
The discussion revolves around the calculation of the ratio c/a for the hexagonal close packed (HCP) unit cell, where c is the height of the cell and a is the length of the sides of the base. Participants explore the geometric relationships and mathematical derivations involved in this problem, expressing their attempts to reconcile their results with the expected value of approximately 1.6333.
  • Homework-related, Technical explanation, Debate/contested
  • The original poster (OP) calculates c/a = √3 (approximately 1.732) and questions the discrepancy with the expected value of 1.6333.
  • Some participants suggest that the height h may not be accurately represented as 4r and discuss the geometric configuration of the spheres in the HCP structure.
  • One participant proposes visualizing the arrangement of spheres as a pyramid to aid in understanding the height of the unit cell.
  • Another participant mentions the importance of correctly identifying the primitive cell and its relation to the spheres' arrangement, noting that it contains two sphere centers.
  • Several participants express frustration with the complexity of visualizing and solving crystal structure problems, indicating that misleading diagrams can complicate understanding.
  • A later reply introduces a different approach using the geometry of an equilateral triangle formed by adjacent atoms in the middle plane to derive the height of the unit cell.
  • One participant references an external resource that provides a clearer explanation of the tetrahedron height, suggesting it as a more straightforward method for solving the problem.
  • Another participant acknowledges that their previous understanding was incorrect and clarifies that the configuration they were considering was not appropriate for the problem.
  • One participant humorously notes that even after a long time without replies, they found the discussion helpful for their revision.
Participants express differing views on the correct calculation of c/a, with some arriving at √3 and others suggesting the expected value of 1.6333. The discussion remains unresolved, with multiple competing approaches and interpretations of the geometric relationships.
Participants mention potential misinterpretations of diagrams and the complexity of visualizing three-dimensional structures, indicating that assumptions about the geometry may not be universally agreed upon.
WolfOfTheSteps
Hexagonal Close Packing (Why do I get c/a = 3^1/2 ??)
For the hexagonal close packed unit cell, show that c/a = 1.6333. Where c is the height of the cell, and a is the length of the sides of the base. (See picture below)
http://img254.imageshack.us/img254/5609/hcpqr6.th.jpg
Note: There's a typo in the picture above: c = h^2 - a^2 should be c^2 = h^2 - a^2.
<br /> h = 4r , \ <br /> \\ a = 2r , \<br /> a^2 + c^2 = h^2 \Rightarrow c^2 = h^2 - a^2 = 16r^2 - 4r^2 = 12r^2 <br /> \Rightarrow c = 2 \sqrt{3}r \Rightarrow <br /> \frac{c}{a} = \frac{2 \sqrt{3}r}{2r} = \sqrt{3} \approx 1.732 \neq 1.633 <br />
Can someone at least give me a hint at what I did wrong? It just seems like I am certainly correct, unless the angle between a and c is not 90^o (which I really doubt)
Thanks!Tangential Latex Question: Does anyone know why \\ is not producing a new line for me? Thanks.
It is hard to tell from the picture but side labeled h is not 4r. The third layer is in the same spot except for that is translated vertically. The second layer fits in the valleys of the first layer. The points of contact of the sphere make the radii line not travel along one of the faces but into the hexagon. You can still have an h that is 4r but then you have to figure out what the bottum side of the triangle is and it can't just be 'a'. Three dimension stuff is hard to draw, describe and think about sometimes. Is my communication make sense to you?
I think I get the idea of what you're saying. I'll try it out and let you know if I get 1.633. Thanks.The thing I hate about these crystal problems is: How in the world could I ever figure this out for myself? All we are given is pictures of the unit cell, and if they are misleading, we're screwed. It's really frustrating. Never mind my rant. :)
You probably won't want to set h = 4r. I mean that isn't the easiest way. I was just trying to get you to realize that path of radii entered into the crystal unit. The way I solved was by visualizing four spheres making a pyramid. Then find the height of that period as function of the radius of the spheres. From there finding the height of the unit is easier.
I don't know what's going on. I tried to do a 4 sphere pyramid, and I still get c/a = \sqrt{3}. I'm about to give up. This is ridiculous.
I don't know what's going on. I tried to do a 4 sphere pyramid, and I still get c = \sqrt{3}. I'm about to give up. This is ridiculous.
the following link shows a better picture in my opinion
http://www.uncp.edu/home/mcclurem/lattice/hcp.htm
the first picture shows the just two layers. The third layer should stack right on top of the other layer. The conceptual point is that a pyramid is formed from three spheres on the bottum layer and one in the middle. The height of that pyramid is half the height of c. However just finding the height of that pyramid is hard. Another word for that type of pyramid is tetrahedron. If you have trouble solving the math for the height of tetrahedron I can assure there are derivations on the web. Keywords: tetrahedron height
It is a pretty difficult problem. Material science can be difficult. I was flipping through a book the other day on it and it had tensor calculus on it which I have know idea how to do. Some parts are fun and sometimes the math requires more time than it worth depending on the discipline type.
Sorry, to bring this up again, but I also get c/a = 3^1/2. When I draw it out I get a rhombus with side-lengths 2 and a diagonal of length 2. I get that c/a should be the length of the long diagonal divided by 2.
I realized that I was calculating the wrong thing because the primitive cell I used has its origin in the A layer, has two vectors the go to the same A layer, and then a third that goes to the next A layer. So, it basically skips the B layer. Can someone give me a description of the primitive cell that I should be using (I know this is hard!)?
I just solved it. One thing I was missing was that THE PRIMITIVE CELL ACTUALLY CONTAINS 2 SPHERE CENTERS. All of the lattice points will be on one of the two plane layers either A or B .
Also, the problem really does reduce to finding the height of a tetrahedron as NotMrX said. The MOST ESSENTIAL POINT IS THAT THE CONFIGURATION WE ARE INTERESTED IN IS NOT THE SAME AS http://www.soyouwanna.com/site/syws/shootpool/img/SHOOTPOOL_4-1.gif
That is where the sqrt(3) comes from and it is downright wrong.
its an entire year that no one has replied..
anyways, i had the same problem too...
but now its crystal clear for me ...
instead of solving with the diagram(of the HP cell) given by others, try this one,
http://mathworld.wolfram.com/HexagonalClosePacking.html
on the site they have proved it by using volume of a tetrahedron(scalar triple product).
but i proved it in a simpler way.
choose any 3 adjacent atoms from the middle plane. they form a equilateral triangle of side = 2r (r=radius of atom).
Any atom on the top(or bottom) plane is positioned directly above the centroid of the equilateral triangle formed by the atoms of the middle plane, it touches.
then consider the right triangle formed by one atom(say atom A) of the top plane, the centroid below it (in the middle plane) and one of the atoms of the middle plane touching atom A.
the distance between the atom A and the centroid = (height of hexagonal cell)/2
use pythagoras theorem in this triangle to find the height in terms of radius r.
I know its 2 years later, but i had the same problem as the OP. i just wanted you to know that even if no one else commented, your pun did brighten my revision session, thanks.
17K
23K
23K
17K
  • · Replies 19 ·
  • · Replies 93 ·
16K
24K
