Is there a limit to how high a mountain can be due to gravity?
  • Context: High School
  • Thread starter Thread starter ravachol
The discussion centers on the theoretical limit of mountain height due to gravitational forces, with a focus on the compressive yield strength of rock materials. The tallest known mountain, Mauna Kea, reaches approximately 9,700 meters, while Mars' Olympus Mons stands at about 27,000 meters, illustrating the impact of lower gravity on mountain height. Participants suggest calculating the pressure at the base of a mountain using the density of rock and comparing it to its compressive yield strength. The conversation also highlights the role of surrounding rock in supporting mountain structures, indicating that gentle slopes may allow for greater heights.
  • Understanding of compressive yield strength of rocks
  • Knowledge of geological principles related to mountain formation
  • Familiarity with pressure calculations in physics
  • Basic concepts of gravity and its effects on geological structures
  • Research the compressive yield strength of various rock types
  • Learn about geological processes that affect mountain formation
  • Study pressure calculation methods in geology
  • Investigate the impact of slope angles on mountain stability
Geologists, physicists, and anyone interested in the mechanics of mountain formation and the effects of gravity on geological structures.
ravachol
i've read sth like there cannot be a mountain higher than 15000 meters because of the gravity. this was like a do you know statements in magazines.
is there anyone knows sth about that
Try to calculate the pressure at the base of a mountain. Assume a column of material as high as your mountain.
The tallest mountain we know of is Hawaii's Mauna Kea at ~9700 meters. Of course, about 5000 of those meters are under the Pacific Ocean. Mars' largest mountain comes in at 27000 meters, which does roughly scale with the difference in gravity. Of course, we're not considering the effects of erosion (or really any geologic principles).
The approximation suggested seems correct. Using the density of a particular rock, calculate the pressure at the bottom of a column and compare that to the known compressive yield strength of that particular rock.
But when we think about a column of rock, when the material at the bottom breaks, it has somewhere to go. It ejects material sideways. In a mountain, the column is surrounded by other rocks, thus helping to hold it up since any broken material has nowhere to go. I suppose if the mountain were large enough the sideways force could break the rock at the outer regions of the base of the mountain, where the columns would be of much reduced height. Or is this not a consideration, or maybe it wouldn't change the estimate by much? I'd just think that a mountain with a gentle slope on it's sides could rise much higher than a mountain with a steep slope, for the reason described above. Given a sufficiently gentle slope, I'd expect the height to be nearly unlimited, unless the compression turned everything to liquid.
  • · Replies 17 ·
  • · Replies 27 ·
