MHB Proving Homomorphism in Commutative Subalgebras of Bounded Operators
  • Thread starter Thread starter Boromir
The discussion centers on proving the existence of a homomorphism in commutative unital subalgebras of bounded operators, specifically within the context of the spectral theorem. Participants confirm that if A is a self-adjoint commutative unital C*-algebra, then for any operator T in A, the spectrum of T corresponds to the range of the Gelfand transform. The Gelfand–Naimark theorem is pivotal, establishing an isometric isomorphism between A and the algebra of continuous functions on a compact Hausdorff space. This leads to the conclusion that homomorphisms from A to the scalars are represented as point evaluation functions on the spectrum.
  • Understanding of commutative unital C*-algebras
  • Familiarity with the spectral theorem
  • Knowledge of the Gelfand–Naimark theorem
  • Basic concepts of bounded operators on Hilbert spaces
  • Study the implications of the Gelfand–Naimark theorem in functional analysis
  • Explore the spectral theorem in detail, particularly its applications in operator theory
  • Investigate the properties of self-adjoint operators in C*-algebras
  • Learn about point evaluation functions and their role in homomorphisms
Mathematicians, particularly those specializing in functional analysis, operator theory, and algebra, will benefit from this discussion. It is also relevant for graduate students studying advanced topics in mathematics related to bounded operators and C*-algebras.
Boromir
Let A be a communitative unital subalgebra of B(H) (the set of bounded operators on a hilbert space). Let T be in A. Prove that for all x in the spectrum of T, there is a homomorphism h on A such that h(T)=x. Give the homomorphism explicity.
Hi Boromir, and welcome to MHB!
Can you give us some idea of what you know about such algebras? Is the algebra A supposed to be selfadjoint? If so, then the spectral theorem will apply. That might give you a handle on the problem.
Thanks for the welcome Opalg
I'm afraid I'm in the process of trying to prove the spectral theorem. I will give you more context. I'm trying to prove that for T in A, the spectrum of T is {h(T):h is a non-zero homomorphism A->C}. I have proved that h(T) is in the spectrum so now I need the reverse inclusion. That is, that every member of the spectrum is equal to h(T) for some (non-zero) homomorphism h. I don't want to go down the road of ideals as the proofs on the internet do as I'm specifically focusing on the space B(H).
Nearly forgot, the algebra is adjoint preserving
Do you think I am trying to 'square the circle' as in there needs to be an assumption of commutativity which is not present in B(H)?
The key to this is the commutative Gelfand–Naimark theorem.
The problem is unchanged if we replace $A$ by its closure (in the operator norm topology). So we may as well assume that $A$ is closed. Now that you have added the crucial information that $A$ is selfadjoint (i.e. closed under the adjoint operation), it follows that $A$ is a commutative unital C*-algebra. The G–N theorem then tells you that there is an isometric isomorphism $\phi:A\to C(X)$ from $A$ to the algebra of continuous functions on a compact Hausdorff space $X$ (the structure space or spectrum of $A$). It follows fairly easily that the spectrum of $T$ is equal to the range of the function $\phi(T)$. Also, the homomorphisms from $A$ to the scalars are exactly the point evaluation functions on $X$, in other words functions of the form $S\mapsto (\phi(S))(x)$ for $x\in X$ and $S\in A$. That is all you need to deduce the result.
On a separate but related note, why is A closed under inverses i.e. if T has an inverse, then the inverse is in A
That also comes from the G–N theorem. If $T$ has an inverse then its Gelfand transform $\phi(T)$ never takes the value $0$ and therefore has an inverse, namely the function $f(x) = 1/((\phi(T))(x))$. The inverse Gelfand transform $\phi^{-1}(f)$ belongs to $A$ and is equal to $T^{-1}$.
Taking as a concrete example the set of polynomials generated by T and it's adjoint, you are saying that the map $p(T,T^*)$->$p(x,x*)$ where x is any fixed member of the spectrum is a homomorphism? Does it preserve the 'multiplication? Well, given polynomials p,g, we have $p(g(T,T^*))$->$p(g(x,x*))$ but that does not equal $p(x,x*)$$g(x,x*)$ which is the multiplication in C. Or am I missing something?
The product of the polynomials $p(T,T^*)$ and $g(T,T^*)$ is $p(T,T^*)g(T,T^*)$, not $p(g(T,T^*))$.
Yes of course the operation is not composition of functions (polynomials) but composition of operators. Case closed.
  • · Replies 16 ·
