Hot air balloon buoyancy problem
10 replies · 6K views · last reply
Jpyhsics
A hot-air balloon is initially floating (stationary) a few metres above the ground. The radius of the spherical balloon is 6.25 m, and the density of surrounding air is 1.29 kg m-3. "Ballast" is weight of negligible volume that can be dropped to make the balloon rise. How much weight would you have to drop overboard to make the balloon rise 105 m in 15.0 s? You may assume that the density of surrounding air remains constant.
Archimedes principle: Fb=rho*gV
Vsphere= 4/3*pi*r^3
Initially the hot air balloon is stationary so...
FB=Fg
ρgV=mg
m=1319.2...kg
FB=Fg=12941N
In the air...
a=2d/t^2=0.933...m/s^2
Fnet=FB-Fg
(1319-x)(0.93...)=12941-(1319-x)g
x=114.6 kg
but apparently this is wrong?...
Jpyhsics said:
Problem Statement: A hot-air balloon is initially floating (stationary) a few metres above the ground. The radius of the spherical balloon is 6.25 m, and the density of surrounding air is 1.29 kg m-3. "Ballast" is weight of negligible volume that can be dropped to make the balloon rise. How much weight would you have to drop overboard to make the balloon rise 105 m in 15.0 s? You may assume that the density of surrounding air remains constant.
Relevant Equations: Archimedes principle: Fb=rho*gV
Vsphere= 4/3*pi*r^3
FB=Fg
ρgV=mg
m=1319.2...kg
FB=Fg=12941N
In the air...
Fnet=FB-Fg
x=114.6 kg
Why do you think it is wrong?
I didn't calculate using the given values, but equations you have used seems to be correct.
Hint: your solution would be more readable if you work only with symbolic names for the quantities throughout your calculation, and put in the given values in the end.
I was marked wrong by the system.
haruspex said:
Do you know what the answer is claimed to be?
no...sadly
Try to enter the result with three digits .
So I figured out that they were asking for weight and not mass, but thanks everyone.
Yes, it was weight... It is easy to overlook.
The stated problem seems cringe-worthy. We are expected to have a 12 meter diameter balloon rising at an eventual rate of 14 meters per second under a force of a mere 1124 N while neglecting air resistance?
And neglecting the fact that for the balloon to deflect upwards, some volume of the surrounding air must deflect downward?
12 meter diameter is similar to that of a deployed parachute and 1124N is similar to the weight of a skydiver. The computed result might be good to one significant digit. Four is ludicrous.
