How Accurate is Differential Approximation for Fourth Roots?
7 replies · 2K views · last reply
Karol
Approximate ##~\sqrt[4]{17}~## by use of differential
Differential: ##~dy=f(x)~dx##
$$y=\sqrt[4]{x},~~dy=\frac{1}{4}x^{-3/4}=\frac{1}{4\sqrt[4]{x^3}}$$
$$\sqrt[4]{16}=2,~~dx=1,~~dy=\frac{1}{4\sqrt[4]{x^2}}\cdot 1=0.149$$
$$\sqrt[4]{17}=2.031$$
The error is too big
Nevertheless, your result is correct.
If you want better accuracy you need to take additional, higher order terms (2nd derivatives, maybe 3rd derivatives,etc).
Here is how I would write things.
##f(x + \Delta x) \approx f(x) + df \approx f(x) + f'(x) \Delta x = x^{1/4} + \frac 1 4 x^{-3/4} \Delta x##
When ##x = 16## and ##\Delta x = 1##, we have
##\sqrt[4]{16 + 1} \approx 16^{1/4} + \frac 1 4 \frac 1 {16^{3/4}} \cdot 1 = 2 + \frac 1 32 = 2.03125##
By calculator, ##\sqrt[4]{17} \approx 2.03054##. Since ##\Delta x = 1## is relatively large in comparison to x = 17, the approximation using differentials isn't all that accurate. If ##\Delta x## were smaller, the approximation would be better.
Thank you Mark44
By the way, how do i copy your names here, i write them again. when i pause the mouse on your name it becomes a pointer and there is no option to copy
Karol said:
Thank you Mark44
Just hit the 'Reply' button on the lower right of the post. You may also hite the 'Quote' button , also on the lower right.
BTW, small mistake: dy=f'(x)dx , not dy=f(x)dx , unless f(x)=f'(x).
Thanks, but i mean i want to copy your name, WWGD, to here, instead of looking and typing it. i usually thank every one that answered my question
Maybe you can just use the 'Like' button as a means of thanking.
