How can a function be analytic in the s-plane
  • Thread starter Thread starter mech-eng
    Function
The discussion revolves around the concept of analytic functions in the s-plane, particularly in the context of automatic control systems. Participants seek clarification on the definition and implications of a function being analytic, as well as the relationship between analytic functions and numerical or stochastic methods used in solving differential equations.
  • Some participants express confusion about what it means for a function to be analytic in the s-plane and request explanations.
  • One participant suggests that "analytic" refers to functions that have complex derivatives in the complex plane, noting that all polynomials are analytic everywhere except at the zeros of their denominators.
  • Another participant questions the meaning of a complex derivative and discusses its implications, including the existence of higher-order derivatives and power series expansions.
  • Some participants inquire whether the topic belongs to complex analysis and seek recommendations for relevant literature, expressing uncertainty about their background in real analysis.
  • There is a discussion about numeric and stochastic methods, with one participant explaining that not all differential equations have analytic solutions and describing how numerical methods involve computer simulations while stochastic methods account for uncertainty in models.
  • Participants note that the definitions of "nice" functions may need to be modified when dealing with functions that do not conform to typical rules.
Participants generally agree on the definition of analytic functions in relation to complex derivatives, but there is no consensus on the necessity of real analysis background or the best resources for learning about complex analysis in the context of control systems. The discussion also highlights differing views on the applicability of numeric and stochastic methods.
Some participants express uncertainty about their mathematical background, particularly in real analysis, which may affect their understanding of the topic. There are also unresolved questions regarding the definitions and implications of analytic functions and the methods used to solve differential equations.
mech-eng
Hi, I try to learn the subject of automatic control and there is an explanation which I cannot understand, probably because of background of mathematics. Here is the explanation. I would like to ask that how a function be analitc in the s-plane and would you like to explain it.
Source: Automatic Control Systems by Kuo
Thank you
mech-eng said:
View attachment 98948 Hi, I try to learn the subject of automatic control and there is an explanation which I cannot understand, probably because of background of mathematics. Here is the explanation. I would like to ask that how a function be analitc in the s-plane and would you like to explain it.
Thank you
Here is an article on the properties of analytic functions:
https://en.wikipedia.org/wiki/Analytic_function
I think analytic would be opposed to not solvable analytically, i.e. numeric or stochastic methods were used to arrive at a solution.
@jeff Resenbury
Can you please explain me what numeric or stochastic methods are used actually to solve it.
In this context "analytic" means that it has a complex derivative in the complex plane, s. All polynomials are analytic in the entire complex plane and the quotient of polynomials is analytic everywhere in the complex plane except at the zeros of the denominator. So the function G(s) in the OP is analytic everywhere for s in the complex plane except at s = 0, -1, and -3.
What does complex derivative refer to?
Thank you.
Thank you.
The derivative of a complex-valued function, f, of a complex variable, z, at point z0 is the complex number d, such that d = limz->z0( f(z)-f(z0 ) / (z-z0). The limit value, d, must be the same no matter what direction z approaches z0 from.
When a function, f, has this property at each point in an area, the consequences are profound: If it has one derivative, then it also has all higher order derivatives. It has a convergent power series expansion. It's integral also has very special properties. I am sure that you will see a lot of this as you continue your studies.
When a function, f, has this property, the consequences are profound. If it has one derivative, then is has all higher order derivatives. It has a convergent power series expansion. It's integral also has very special properties. I am sure that you will see a lot of this as you continue your studies.
Is this topic belong to Complex Analysis Theory? In which books and at which titles of those books I can find this topic? Even I do not know enough Real Analysis [Calculus], first should I learn Real Analysis?
Thank you.
Thank you.
Yes. It is complex analysis. Real analysis would emphasize things that will not help much. I would look for a book in control laws that will summarize the basic complex analysis that is needed to understand control laws. If you need more, you can just read sections of complex analysis books. And the complex analysis books should be for engineers, not mathematicians.
PS. If you mean calculus when you say "Real Analysis", you do need some understanding of introductory undergraduate calculus. A Real Analysis book is very different.
Not all differential equations have analytic solutions. When these problems need to be solved they are sometimes solved either numerically or stochastically.
To solve numerically, use a computer to solve small bits as if they were differential elements. Make sure to run an error analysis. An example would be weather modelling.
Stochastic modelling is sometimes done when the certainty of the model is in question. Insurance companies use them to set rates for example. Something like an accident rate might have a function found by curve fitting, but one can never tell if that function truly represents the data.
The point is that not all functions are "nice" for some value of nice. The definitions need to be abandoned or at least modified when a function is weird enough to not play by normal rules.
  • · Replies 33 ·
