How can an equation produce the iconic Gateway Arch using a catenary curve?
  • Thread starter Thread starter turnip
    Formula
A catenary curve can represent the Gateway Arch using the equation y = a/2 (e^(x/a) + e^(-x/a)), where 'a' is a constant. To derive the specific equation for the arch, one must consider the dimensions: the arch is 630 feet high and 630 feet long. The challenge lies in determining the value of 'a' by substituting the known coordinates into the equation. A suggested approach involves solving the equation a + 630 = a/2 (e^(-315/a) + e^(315/a)) numerically for 'a'. This allows for adjustments to fit the arch's shape and orientation.
turnip
A catenary curve can be described by the following function:
y= a/2 (ex/a + e -x/a)
where a is a non-zero constant
By selecting sutable axes, devise an equation that will produce the gateway arch.
Right next to the question is a graph of an arch that is 630 feet high (on the y axis) and 630 feet long (on the x axis).
I have no idea where to start. I was thinking that I could substitute the x and y values in of 630 to find the a value and thus the normal function (since its constant). But then why not just ask for that? Why go and say devise an equation, i don't follow.
Please, I would really appreciate someone getting me started on this!
Mathematics news on Phys.org
here's what i could get:
y = a(e^x/a + e^-x/a)/2
630 x2 = a(e^630/a + e^-630/a)
1260/a = e^630/a + e^-630/a
ln 1260/a = 630/a -630/a = 630 - 630/a
then that would mean 0/a which is infinity (iam getting the idea that isn't the answer)
where am i going wrong?
You aren't describing the graph sufficiently. What is the value of y when x= 0? You say it is "630 feet long (on the x axis)". Is the y value when x= 630 the same as when x= 0? And you say that it is "630 feet high (on the y axis). For what x is that? 630/2= 315?
I have just been given this exact question to complete as part of an assignment.
Any hints or ideas how to devise a formula for the Gateway Arch.
Im a bit stuck.
Thanks.
You said there was a picture- we do not have the picture.
Not unless you can answer my questions.
Im a bit stuck.
Thanks.
Without the diagram we have to make a few assumptions but I'll bite.
Assume that the equation is valid over the full arch and that you can shift it up or down by an arbitrary amount. Initially I'll take "a" positive and make an upside-down arch, but you can flip it later by negating "a".
Clearly y() has even symmetry and it's min is at x=0.
The min is y(0) = a so to fit the requirements we want y(+/- 315) = a + 630.
So all you need to do is solve the following transcendental equation numerically for "a",
a + 630 = a/2 ( exp(-315/a) + exp(+315/a) )
Flip it upside-down and shift it up or down as required.
Seemingly by some mathematical coincidence, a hexagon of sides 2,2,7,7, 11, and 11 can be inscribed in a circle of radius 7. The other day I saw a math problem on line, which they said came from a Polish Olympiad, where you compute the length x of the 3rd side which is the same as the radius, so that the sides of length 2,x, and 11 are inscribed on the arc of a semi-circle. The law of cosines applied twice gives the answer for x of exactly 7, but the arithmetic is so complex that the...
Thread 'Video on imaginary numbers and some queries'
Hi, I was watching the following video. I found some points confusing. Could you please help me to understand the gaps? Thanks, in advance! Question 1: Around 4:22, the video says the following. So for those mathematicians, negative numbers didn't exist. You could subtract, that is find the difference between two positive quantities, but you couldn't have a negative answer or negative coefficients. Mathematicians were so averse to negative numbers that there was no single quadratic...
Thread 'Unit Circle Double Angle Derivations'
Here I made a terrible mistake of assuming this to be an equilateral triangle and set 2sinx=1 => x=pi/6. Although this did derive the double angle formulas it also led into a terrible mess trying to find all the combinations of sides. I must have been tired and just assumed 6x=180 and 2sinx=1. By that time, I was so mindset that I nearly scolded a person for even saying 90-x. I wonder if this is a case of biased observation that seeks to dis credit me like Jesus of Nazareth since in reality...
