Undergrad How can an object tip and slip at the same time?
  • Thread starter Thread starter Conductivity
    Slip Time
The discussion focuses on the conditions under which an object can tip and slip simultaneously. Tipping occurs when the critical force (P critical) is less than the static friction force (Us N), while slipping happens when P critical exceeds Us N. The conversation explores the scenario where P critical equals Us N, suggesting that any slight increase in force could lead to both tipping and slipping. The mathematical relationship for tipping involves the object's height and length, indicating that the static friction coefficient must equal the ratio of half the base length to the height. Overall, the participants seek to understand the dynamics of tipping and slipping under varying forces.
Conductivity
The conditions are for tipping and slipping. Tipping: If P critical < Us N then it tips
Slipping: If P critical > Us N then it slips
What if we have P critical = Us N. Any increase will make it slide and tip...?
If we took a rectangular shape object with Height h and length L so half its length is b. We get that if we want the object to tip if p is acting at the highest point we get, P*h =w b. If we want P at this point to equal the static friction then, P = Us N, wb/h = Us W So Us must equal b/h
I take it you've never been ice skating :smile:
Or bowling.
Likes phinds
Or watching cars skid and roll.
Conductivity said:
The conditions are for tipping and slipping. Tipping: If P critical < Us N then it tips Slipping: If P critical > Us N then it slips
Cite your source please. And check to see that it says that when the object starts tipping that it stops slipping.
When sliding over a level surface? When the kinetic friction coefficient is greater than: horizontal_COM_to_base_edge_distance / vertical_COM_position.
It is just my college book, It didn't mention that.
I just wanted to know how the object will behave when it is about to tip and slip and you increase the force by a tiny amount. How the math will work out?
I do not have a good working knowledge of physics yet. I tried to piece this together but after researching this, I couldn’t figure out the correct laws of physics to combine to develop a formula to answer this question. Ex. 1 - A moving object impacts a static object at a constant velocity. Ex. 2 - A moving object impacts a static object at the same velocity but is accelerating at the moment of impact. Assuming the mass of the objects is the same and the velocity at the moment of impact...
