How can I create a matrix with two columns in Matlab using a modular operation?
  • Context: MATLAB
  • Thread starter Thread starter confused_engineer
    Matlab Program
7 replies · 2K views
confused_engineer
Hello everyone.
I am trying to create a matrix in Matlab with two columns which should look like as follow:
0 1 2 3 4 5 6 7 8 9 0 1 2 3 4 5 6 7 8 9...
0 0 0 0 0 0 0 0 0 0 1 1 1 1 1 1 1 1 1 1...
Has anyone programed something like this before?
confused_engineer said:
Hello everyone.
That would be two rows, as written. Does this help?
https://www.mathworks.com/help/matlab/learn_matlab/matrices-and-arrays.html
You could create a vector of numbers say 0:100
And then make a new vector of numbers using the module 10 operation or functional give you the 0:9 cycle.
Similarly you could integer divide each number in the first array and then integer multiply by 10
Matlab may have a function to do that something like floor.
The following isn't MATLAB code, but it might serve as pseudocode that can help you out.
C:
int arr[2][100];  // Arrays are declared differently in matlab
// Fill the first row (arr[0][ ... ]) with the repeating cycle of digits 0, 1, 2, ..., 9
// Fill the second row (arr[1][ ...]) with the tens' digits.
for (int j = 0; j< 100; j++)
   arr[0][j] = j % 10;
   arr[1][j] = j / 10;
The C expression j % 10 evaluates to the remainder when j is divided by 10. For example, 3 % 10 is 3, and 25 % 10 is 5. In matlab, there is a mod() function. mod(18, 10) would evaluate to 8.
The C expression j / 10 uses the feature in C and languages based on C of integer division, which is distinct from floating point division. For example 18 /10 is 1 (not 1.8). In matlab, I believe that idivide(j, 10) would be the MATLAB equivalent. (I don't have matlab.)
I think that I have it.
Thanks for the help, you have helped me a big deal.
Matlab is an interesting tool. Cool but not quite as revolutionary as IBM’s APL for expressiveness in working with arrays of numbers.
This produces your array in MATLAB.
One fairly straightforward Matlab-style approach is:
Code:
>> A = 0:20
A =
     0     1     2     3     4     5     6     7     8     9    10    11    12    13    14    15    16    17    18    19    20
>> A = [mod(A,10); fix(A/10)]
A =
     0     1     2     3     4     5     6     7     8     9     0     1     2     3     4     5     6     7     8     9     0
     0     0     0     0     0     0     0     0     0     0     1     1     1     1     1     1     1     1     1     1     2
