How can i find out the density of 5M NaOH
  • Thread starter Thread starter microbus65
    Density
The density of a 5M NaOH solution is approximately 1.182 g/mL at 25°C, as reported by Sigma Aldrich. To calculate this density, one must consider the mass of NaOH and water, accounting for the dilution volume. Using density tables from reliable sources, such as the CRC Handbook, is essential for accurate results, as simple calculations can lead to significant errors. For instance, estimates for similar solutions can vary widely, highlighting the importance of precise measurements and resources.
  • Understanding of molarity and solution preparation
  • Familiarity with density calculations
  • Knowledge of the CRC Handbook or similar reference materials
  • Basic laboratory skills for weighing and measuring liquids
  • Research density tables in the CRC Handbook for various chemical solutions
  • Learn about the conversion between molarity (M) and weight/weight percentage (%)
  • Explore concentration calculators that include built-in density tables
  • Study the impact of dilution volume (DV) on density calculations
Chemistry students, laboratory technicians, and professionals involved in chemical solution preparation and density measurement will benefit from this discussion.
microbus65
how can i find out the density of 5M NaOH
If you are in a course, you will learn this. Chemistry is a laboratory course. Density is a ratio of mass to volume. Do you have a 5 M solution of NaOH?
Otherwise, look in a handbook.
Work out how many moles of NaOH in a litre,
Work out the mass of 1 mole of NaOH, add to the mass of 1litre of water.
Thats the density (approximately - doesn't take into account the volume of the added NaOH)
In general - this is wrong. With such approximations you never know what the error is - and it can be everything. For ammonia you will estimate that 5M solution is around 1.085 g/mL, while in reality it is 0.963 g/mL. For sulfuric acid your estimate will be 1.49 g/mL - compare it to the real value of 1.29 g/mL. That means -11% and +16% errors.
The only correct approach is to use density tables from some handbook, like CRC handbook for example. There are short density tables on my site. Note, that in many hanbooks density tables contain only densities of solutions of given % w/w concentration, so you have to convert between M and %. That's not a simple one step operation, as to convert you have to know density first. So, you either do it iteratively (assume some density, convert, check new density in tables, use it to convert and so on, depending on the accuracy you need one or two iterations will be most likely enough) or you prepare M vs density table (that makes sense if you will be doing conversions often) or you look for some concentration calculator with built in density tables, that does conversion for you automatically :wink:
I would suggest a simple weighing trial however the basic solution may scratch the glassware ; simply measure out a certain volume of the solution and then weigh it however be sure to tare the measuring apparatus.
It is 1.182 g/mL at 25oC according to Sigma Aldrich.
Let's see what the error would be assuming no DV of mixing.
The density of solid NaOH is 1.829 (according to Wiki). We need 5*40.00 g for 5 moles which will be diluted with sufficient water to form 1 L. Assuming no DV of mixing, we will add 200.0 g or 109.4 mL (200.0 g/1.829 g/cm^3) to 890.6 mL of water (1000 mL - 109.4mL). This will give us the 1L we need and will weigh 1090.6 g for a density of 1.091. The relative percent mixing error is 100* (1.091 g/mL - 1.182 g/mL) / 1.182 g/mL = -7.699%
That's a little too much error for my liking.
  • · Replies 23 ·
