How can I search for a specific phrase in a sentence using FORTRAN?
  • Context: Fortran
  • Thread starter Thread starter manjurul
    Beginners Fortran
This discussion focuses on searching for specific phrases in a sentence using FORTRAN, particularly through the use of the READ and WRITE commands. The generalized form of the READ command is outlined as READ (unit, format) list, where 'unit' can range from 0-99 or be the star symbol '*'. The FORMAT statement is crucial for controlling output formatting, as demonstrated in the provided example code. The user seeks assistance in reading a sentence from a text file and determining the position of the phrase "good boy" within it.
  • Understanding of FORTRAN syntax and commands
  • Familiarity with FORMAT statements in FORTRAN
  • Basic knowledge of file I/O operations in FORTRAN
  • Experience with string manipulation in programming
  • Explore the use of FORTRAN string functions for searching substrings
  • Learn about file handling in FORTRAN for reading text files
  • Investigate advanced FORMAT statement options in FORTRAN
  • Study examples of character position retrieval in FORTRAN
This discussion is beneficial for FORTRAN programmers, particularly those involved in engineering and scientific applications, who need to manipulate strings and format output effectively.
manjurul
Most of the examples here are given from the following book,
Michael Kupferschmid, "Classical Fortran: Programming for Engineering and Scientific Applications", Taylor & Francis Group, 2009
The generalized form of READ command is as follows,
where, the value of 'unit' could be any value ranging from 0-99 or star symbol '*'. Both 5 or * means standard-in (usually keyboards). If the 'format' is *, then the format will be according to the compiler default. However if 'format' is not * , then it will refer the label of the FORMAT statement. Note that the FORMAT statement is used to specify exactly how the input/output will be. The 'list' is the list of variables to be read.
Any of the commands are used to read an input for variable A,
PHP:
READ (*,*) A
and
PHP:
READ *,A
are same commands. It means the program will take an input from standard-in (usually keyboard).
Technology news on Phys.org
For output the general forms are as follows,
WRITE (unit, format) listfor the details of 'unit', 'format' and 'list' see above.
HI,
I want to write some results in my fortran code. The way i want to get it written is the values should be written on the same line and NOT on the next line and so on...How can i achieve it bu using the write command?
Hi Nisha,
You need to use FORMAT statement and it is not difficult to do that.. you can see the following link to do that,
http://fortranmanjurul.blogspot.com/
also test the following code and see how FORMAT statement works
PHP:
         PROGRAM readonce
         REAL*8 X/1.23D0/, Y/53.0D0/
         J=37
         WRITE(6,10) J,X,Y
 10      FORMAT(1X,I3,T7,'X=',T9,F5.2,3X,T17,D8.2)
         STOP
         END PROGRAM readonce
Hope this solves your problem
I need to write a code which can read the following sentence from a text file,
"I know that he is a good boy!".
After reading it, the code has to search if the word "good boy" is there or not. Also the position number of "good boy" in the sentence (i.e. after how many character)
Kindly anyone help me
  • · Replies 22 ·
