How can I solve this exponential equation with variables in the exponent?
  • Context: Undergrad
  • Thread starter Thread starter chiako
The discussion revolves around solving the exponential equation 2^x + 3^x = 50. Participants explore various methods for finding the solution, including numerical approaches and transformations of the equation. The conversation includes attempts to derive a solution analytically and the challenges associated with doing so.
  • Homework-related
  • One participant expresses difficulty in solving the equation and seeks guidance on manipulating logarithms, particularly ln(2^x + 3^x).
  • Another participant suggests transforming the equation by expressing 3^x in terms of 2^x, leading to a new equation y + y^{\log_2(3)} = 50, but notes the lack of an algebraic solution.
  • Several participants propose using numerical methods, specifically Newton's method, to approximate the solution, with one participant detailing their iterative process and results.
  • There are discussions about the accuracy of calculations, with one participant realizing they were using the wrong logarithm base and correcting their approach.
  • Another participant introduces fixed point iteration as a method to solve the equation using a basic calculator, sharing their key presses and results.
  • Some participants emphasize the necessity of numerical solutions for this type of equation, while others question whether an analytical solution exists.
Participants generally agree that the equation cannot be solved explicitly and that numerical methods are required. However, there is some debate about the effectiveness of different numerical approaches and the accuracy of calculations.
Participants mention limitations in their calculators and the potential for errors in calculations, particularly regarding the use of logarithm bases. The discussion reflects a range of assumptions about the methods and their applicability to the problem.
Readers interested in numerical methods for solving equations, particularly in the context of exponential functions, as well as those seeking to understand the challenges of manipulating logarithmic expressions in mathematical problems.
chiako
Hello. This problem was presented to me and I can't figure out for the life of me how to solve it.
2^x + 3^x = 50
I know the answer is approximately 3.35, thanks to WolframAlpha, but I don't know of any steps to arrive at this.
ln(2^x + 3^x) = ln(50)
How do you solve for ln(a+b) in this regard when a and b have a variable as their exponent?
Using ln(a+b) = ln(a((b/a)+1) = ln(a) + ln((b/a)+1) just gets me running in circles.
Mathematics news on Phys.org
You might simplify the problem by doing
3^x=2^{\log_2(3)x}=(2^x)^{\log_2(3)}
Put in a dummy variable y=2^x, then your equation becomes
y+y^{\log_2(3)}=50
Sadly, I see no way of solving this equation algebraically. I think you'll be forced to apply numerical methods here...
try the identity a^x = e^[x*ln(a)] perhaps? would get everything to the same base.
It can not be solved explicitly
use Newtons approximation method where x_0 = 3
I have been trying to solve this all day on paper, going through step-by-step, but I am obviously doing it wrong.
f(x) = 2^x + 3^x - 50
f'(x) = 2^x \log(2) + 3^x \log(3)
x_0 = 3
x_{n+1} = x_0 - \frac{f(x_0)}{f'(x_0)}
x_1 = 3 - \frac{2^3 + 3^3 - 50}{2^3 \log(2) + 3^3 \log(3)} \approx 3.9810WRONG
x_2 = 3.9810 - \frac{2^{3.9810} + 3^{3.9810} - 50}{2^{3.9810} \log(2) + 3^{3.9810} \log(3)} \approx 2.9220 WRONG
x_3 = 2.9220 - \frac{2^{2.9220} + 3^{2.9220} - 50}{2^{2.9220} \log(2) + 3^{2.9220} \log(3)} \approx 4.1724 WRONG
As you can see, all I manage to do is get further and further AWAY from the approximate answer of 3.35. What did I do wrong when setting this up?
I have been using http://www.math.sc.edu/cgi-bin/sumcgi/Newton.pl to check my answers.
X[1] = 3.42075400369499
X[2] = 3.35520839663614
X[3] = 3.3528278249362
EDIT, with fixed calculator:
x_1 = 3 - \frac{2^3 + 3^3 - 50}{2^3 \log(2) + 3^3 \log(3)} \approx 3.4260
x_2 = 3.4260 - \frac{2^{3.4260} + 3^{3.4260} - 50}{2^{3.4260} \log(2) + 3^{3.4260} \log(3)} \approx 3.3555
x_3 = 3.3555 - \frac{2^{3.3555} + 3^{3.3555} - 50}{2^{3.3555} \log(2) + 3^{3.3555} \log(3)} \approx 3.3528
Seems like you need to check your calculator because I get that
x_0 = 3 and x_1 \, \approx \, 3.4260
I just tried this and got a good approximation after just two iterations
Regards.
Regards.
Derp. That was it. It was my calculator. Thank you! Then, I was doing it right all along. I just popped the corrected answer into each of those and came out with the proper answer. :)
You've been using log base 10, you need to use the natural logarithm, probably ln on your calculator.
It was actually a formatting error in my entry into the calculator. Thank you, though.
Fixed point iteration is sometimes useful when all you have at hand is a basic calculator scientific calculator. All you require is one that has an "ans" button (or equiv) and the ability to repeat the previous calculation (for example in my case each time I press "equals").
For example, on my cheap Casio (very basic scientific calc) the following key presses gets me the answer to 10 significant digits in about 20 seconds.
3.5 =
ln(50 - 2^ans)/ln 3 =
Gives the answer : 3.352823623
3.5 =
I wasn't so much concerned with doing the answer on the calculator, as to figuring out how the calculator arrived at that answer. I wanted to know the process behind it, which was arrived at with Netwon's Method. Thank you for the post, though.
Yeah it's all about recognizing that the equation requires a numerical solution and then using an appropriate numerical method. Newtons method was a good choice for a function like that which is easy to differentiate.
I only mentioned the "fixed point method" as a matter of passing interest. In general it's not a very good algorithm, slower to converge than Newtons method and doesn't always even converge (converges only when the abs value local gradient is less then one). It's one redeeming feature however is that the "programming" of the algorithm requires nothing more than repeating a single calculation and thus can be "programmed" on most non-programmable (that is, basic scientific) calculators.So just to make it clear what the calculator "keypresses" were doing in my previous post it was the following algorithm, with each iteration just involving pressing the calculator equals button.
Iterate x = \log_3(50 - 2^x) starting with x0 = 3.5.
x1 = \log_3(50 - 2^{3.5}) = 3.327
x2 = \log_3(50 - 2^{3.327}) = 3.357
x3 = \log_3(50 - 2^{3.357}) = 3.352
x4 = \log_3(50 - 2^{3.352}) = 3.353
and so on.
  • · Replies 16 ·
