How Can Laser Spot Move Faster Than Light?
The discussion revolves around the concept of whether a laser spot can move faster than the speed of light when aimed at a distant surface, specifically the moon. Participants explore the implications of laser beam direction changes, the nature of light spots, and the timing of photon travel.
  • Some participants argue that moving a laser pointer to create a new spot on the moon does not result in a spot moving faster than light, as there is always a delay due to the time it takes for photons to travel to the moon.
  • Others propose that the spots created by the laser are not the same, suggesting that the concept of a moving spot is a mental construct linking different photons hitting different locations.
  • A participant suggests that if the laser is turned off before aiming at a new location, the two spots could not be considered the same, reinforcing the idea that nothing is moving faster than light.
  • One participant introduces a hypothetical scenario where the average speed of the laser spot could be infinite if the laser is aimed at different points on the moon in rapid succession, raising questions about the definition of velocity in this context.
  • Another participant emphasizes that the only velocities that exist are those of the photons traveling and the rotation of the laser, arguing against the notion of a discrete velocity for the spot itself.
  • Some participants express understanding of the concept after discussing the timing of photon emissions and the lag between the previous and new positions of the spot.
Participants generally disagree on whether the laser spot can be considered to move faster than light, with multiple competing views on the nature of the spot and the implications of photon travel time. The discussion remains unresolved regarding the interpretation of the laser spot's movement.
Participants note that the discussion hinges on the definitions of velocity and the nature of light spots, with some suggesting that the perceived instantaneous movement of the spot does not imply actual faster-than-light travel.
AH_AHSAN
I have read this millions of time on internet that laser spot can move faster than light. but i can't understand how.
For example if we point our laser source towards moon then after 1.2 seconds our laser light reaches the surface of moon and creates a spot there, now if i move my laser source in order to move the spot on surface of moon then after moving my laser source the first photons again take 1.2 seconds to reach the moon so the laser spot on moon can only move after 1.2 seconds to the new location. so there will always be a lag between the previous and new position of the spot.
Now can some one explain me how it is possible to move the laser spot faster than light ?
I would be very thankful.
Laser spots do not move at all, two spots are not made of the same light.
If I shoot with a gun and make a hole somewhere and then move the gun slightly to the left and shoot again does the hole move?
The photons that are hitting the moon at one moment in time are not the same ones that are hitting a different part of the moon a short time later so nothing is moving faster than light. What if you turned the laser beam off just before you aimed it to a new location and then back on again, would you say the first spot on the moon was the same as the second spot at a different location and that it had traveled faster than light?
Nice analysis.
But it does not matter if they are made of same light or not, because even then it's not possible to move the spot of these new photons on the surface of the moon faster than light.
my question has nothing to do with the information i am just saying that it is absolutely not possible to make the spot of light appear at another location than the previous location faster than the speed of light.
If you are talking about how the spot on the moon appears to the person on Earth who is aiming the laser, then you are correct, because he has to wait not only for the laser beam to travel to the moon, but also for the image of the spot to get back to earth, so including this delay the spot will never appear to travel faster than light.
AH_AHSAN, would you agree that I can have a light bulb on Jupiter switch on then one second later have a light bulb on Mercury switch on? Has the light traveled faster than c?Obviously no. They're two separate lights.
Same with the laser. It shoots out some photons. They hit the Moon's left edge. You swing it around in one zillionth of a second to the right edge and some other photons hit there.
The two spots have nothing to do with each other. Nothing has traveled faster than c. The idea of "a spot of light" is entirely a construct of the person doing the observing, who supposes they are the same spot. They're not.
First of all to the title-question:
Velocity is defined as the first time-derivative of position. The position of the laser spot is the point where the laser beam hits a surface. If the absolute value of the velocity of the spot exceeds c than it is faster than light.
Imagine your laser hits the outer edge of the moon. Now you point to the laser within 0,0116 seconds to the center of the moon. 1.2 seconds later your laser will hit the edge and the center of the moon at almost the same time because the center of the moon is 0,0116 light seconds closer to your position. In this example the average speed of your laser spot is infinite and this is much faster than c. In this way you can "move" the spot with every speed you want.
Stop right there.
"The spot" has no velocity. "The spot" is not a discrete thing at all.
"The spot" is a construct of the mind, erroneously linking a bunch of impinging photons here with a bunch of impinging photons there.
The only velocities that exist are:
1] the velocity of the photons traveling from Earth to Moon.
2] the velocity of the laser's rotation.
That's it.
Thanks a lot guyz now i understand it.
I must be smoking some thing when i asked this.
the point i was missing is that just moving the laser pointer direction the spot on moon would not disappear simultaneously at that time because photon emitted just before changing the direction of source are still in the space and moving toward the moon and hence spot should be there still after 1.2 seconds of moving my laser pointer.
I have a feeling you all answer not the question that was asked, but the question you know answer to.
Laser sends photons continuously. When you are changing its direction it sends photons in every direction between the initial and final one. Yes, they will hit the Moon surface in 1.2 sec, but as they were sent all the time you will see all intermediate spots. Perhaps the image below will help you see what is happening.
Edit: I see you got it in the meantime, I spent way too much time preparing the image
Correct.
(However, that doesn't change the fact that, the psot on the right side of the Moon could still appear instantaneously (faster than light) after the spot on the left side of the Moon winked out.)
thanks a lot buddy for your effort.
DaveC426913 said:
Correct.
yes this is totally understandable to me now. thanks.
  • · Replies 28 ·
  • · Replies 40 ·
  • · Replies 21 ·
  • · Replies 20 ·
  • · Replies 50 ·
  • · Replies 50 ·
