How can Laurent series be applied to complex analysis problems?
4 replies · 3K views · last reply
d3nat
Laurent series
##f(z) = sinh(z)## around origin
##sinh(z +\frac{1}{z}) = \sum_{-infty}^\infty A_nz^n##
where
##A_n = \frac{1}{2\pi i} \oint \frac{sinh(z'+\frac{1}{z'})}{z'^{n+1}} d'##
Let c = unit circle, ##z'=e^{i \theta}##
## dz' = ie^{i\theta} d\theta##
using Euler relationships
## = \frac{1}{2\pi i} i \oint \frac{sinh(e^{i\theta}+e^{-i\theta}}{(e^{i\theta})^{n+1}} d\theta'##
Cancel out the ##e^{i\theta}## on top and bottom
## = \frac{1}{2\pi} \oint \frac{sinh(2cos\theta)}{e^{in\theta}} d\theta##
## = \frac{1}{2\pi} \int_0^{2\pi} sinh(2cos\theta) e^{-in\theta} d\theta##
##e^{-in\theta} = cos(n\theta)-isin(n\theta)##
Then I said that only the ## cos(n\theta) ## part mattered because I stated the bounds of the integral were from ##0 to 2\pi##
## = \frac{1}{2\pi} \int_0^{2\pi} sinh(2cos\theta) cos(n\theta) d\theta##
However, I've tried many ways of simplifying this and I can't get an answer. Any suggestions? I'm so stumped... :/
prove contour integral
##\int_0^{2\pi} \frac\{sin^2{\theta)}{a+bcos(\theta)} d\theta = \frac{2\pi}{b^2} [a-(a^2-b^2)^{frac{1}{2}}]##
## d\theta = \frac{-i dz}{z}##
## sin^2(\theta) = \frac{-1}{4}(z^2+\frac{1}{z^2}-2)##
## cos(\theta) = \frac{1}{2}(z+\frac{1}{z})##
Subst. all in and assuming unit circle:
## = -i \oint \frac{dz}{z} \frac{\frac{-1}{4}(z^2+\frac{1}{z^2}-2)}{a+ \frac{b}{2}(z+\frac{1}{z})} dz##
rearranging
## = \frac{i}{2} \oint \frac{dz}{z} \frac{(z^2+\frac{1}{z^2}-2)}{bz^2+2az+b} dz##
Then I solved this using the quadratic equations, so I had two roots (for the denominator)
I know I have to use residue theory, but I've never had to do it with something in the numerator. Is it still the same method? I'm confused...
d3nat said:
Laurent series
where
rearranging
I don't get where you are going here. sinh(z) has a Taylor series around z=0. It's (e^z-e^(-z))/2. There are no negative powers of z at all.
I mean, yah, I can solve it with a Taylor series, but I wasn't sure how to solve using a Laurent series, which is what the problem asks.
A Laurent series is just a Taylor series possibly includes term of negative degree. sinh(z) doesn't have any. The Taylor series is the same as the Laurent series.
Ohhh. Well then, I feel dumb.
My professor made them out to be completely different, so I thought it was two different methods of solving.
Thanks!
