How Can Pi Be Approximated Using a Coin and a Grid?
  • Thread starter Thread starter themadhatter1
24 replies · 7K views
themadhatter1
I found this interesting problem in my textbook. I have heard of Buffon's needle experiment which estimates pi through probability. This problem came from a pre-calc book out of the probability section. The problem seams similar to Buffon's needle in that d is the diameter of the coin as well as the distance in between each square. However, this is a coin and a grid, not parallel lines and a needle. I'm not sure whether the question is asking for an analytical solution to b or an actual experiment. Can it be determined analytically?
The probability for hitting a vertex would be the same for any d value chosen. I believe it would be much more likely to hit a vertex than to land exactly in between two parallel lines. Does finding the probability involve the area taken up if a coin were placed in each square grid, and the free space left?
It's asking you to do an experiment, but you also need the analytical solution to know how to get the estimate for pi.
Think about where the center of the coin can land so that the coin will cover a corner.
It doesn't need to land exactly in between two parallel lines
As an example I made a picture
http://img138.imageshack.us/img138/7943/circleinsquare.png
As for how to go about solving the probability exactly, vela has good advice
Would this be true?: If you were to inscribe a circle of d diameter inside a square with sides length d, the center of a coin with diameter d tracing the circumference the circle would touch a corner at every position on the circle except when the coin is situated at angles 0,90,180,360 on the d diameter circle.
If I understand what you're saying, the answer is yes. In the four cases you mentioned, the coin would intersect with two corners simultaneously.
It does not matter if the circle lands on a gridline. What matters is when the circle lands on TWO gridlines simultaneously. (i.e. it will be covering a vertex where two lines intersect).
That is the crux of the experiment.
When you say a corner do you mean an intersection of only 2 lines or an intersection of 2 or more lines?
O I see. I was considering each side of the square to be a line, but your considering the movement across the grid in the x and y directions as a whole to be lines.
Ok, so I thought I'd make some pictures to illustrate my thinking.
You can have intersection like this...
You can move that circle anywhere on the x-axis and it will cover 2 intersecting lines. You can also have the same thing but on the y-axis and moving that up and down anywhere will cover 2 intersecting lines with every possible placement along that axis.
Then you can move the circle just a little bit in the x any y directions and it won't cover 2 intersecting lines
Then you can move the circle diagonally and it will intersect.
Am I making this more complicated than it is? Because is seams like there is a whole lot of possibilities for when it is touching and when it isn't.
Concentrate on the middle intersection in your pictures. Where does the center of the circle have to be in relation to it for it to lie within the circle?
well if you drew a circle of d diameter around the center intersection
and had another circle of d diameter trace around the circle with it's center point, it would always touch the center point on the intersection no matter where along the circle it is.
That's good. Now, given a square, where can the center be in that square so that the circle hits one of the corners of the square?
It would look like this.
The center of the circle would be able to travel along thoes lines and hit an intersection. In fact the only place it won't hit an intersection is in the center area in the square. If the center of the circle is in that center area it won't touch an intersection. Would you need to find the area of the center area verses the area of the outside parts and set up a ratio.
Well you can calculate the inside area to be [tex]d^2-\frac{(\frac{1}{2}d)^{2}\pi}{4}[/tex]
so would the ratio of hits covering a vertex to hits not covering a vertex be [tex]\frac{(\frac{1}{2}d)^2\pi}{d^2-\frac{(\frac{1}{2}d)^{2}\pi}{4}}[/tex] for the probability of where it would land
Man... you need ∏ to calculate the probability for an experiment designed to approximate ∏?
For any square that the centre of the coin lands in randomly, it must be within distance d or less with any of the four surrounding vertices. The area is therefore [itex]d^2 \frac{\pi }{4}.[/itex] The total area of a square is [itex]d^2[/itex]
There is a [itex]\frac{\pi}{4}[/itex] chance that it will cover a vertex. Do the experiment 100 times and you'll most likely get [itex]\approx \frac{\pi}{4}[/itex]
The probability of it landing on a vertex will be the area where it will land on the vertex divided by the area of the whole square. What you have isn't quite right.
Once you know the probability of it landing on a vertex, drop a coin 100 times. If it lands on a vertex 75% of the time, you can set your expression for the probability to be equal to .75. Since you know d also, the only thing left to do is solve for pi
Almost. Your second term is the area of only one of the quarter circles.
Of course. Pi has to appear in the result otherwise you can't solve for it.
oops. What I meant to say was.
[tex] d^2-(\frac{1}{2}d)^{2}\pi[/tex]
So the ratio would be
[tex] \frac{(\frac{1}{2}d)^2\pi}{d^2-(\frac{1}{2}d)^{2}\pi}[/tex]
So If we say that d=1 we would have
[tex]\frac{\frac{\pi}{4}}{1-\frac{\pi}{4}}[/tex]
That would work out to be about 3.66, which obviously can't be a probability.
Sure you can have a numerical probability, a 1/4 chance is the same as '.25' or for that matter 25%. Why my particular probability is wrong I'm not sure.
Gregg said:
themadhatter1, read post #14. What do you think of that?
I'm not sure how you got [tex]d^{2}\frac{\pi}{4}[/tex] from just knowing that "For any square that the centre of the coin lands in randomly, it must be within distance d or less with any of the four surrounding vertices."
A probability can't exceed 1.
Reread post #15.
Reread post #15.
Oh. Ok I see.
[tex] <br /> \frac{d^2-(\frac{1}{2}d)^{2}\pi}{d^2}<br /> [/tex]
so set d=1 and you'd get
[tex]\frac{1-\frac{1}{4}\pi}{1}[/tex]
so what does that tell me 21.4% of the time it will land hitting a vertex. That doesn't make much sense since the area for it to land hitting a vertex is bigger than the area it will land not hitting a vertex.
themadhatter1 said:
Oh. Ok I see.
You calculated the probability of it not hitting a vertex, because you have the area where it can land and not hit a vertex in the numerator
Arrgg. I can't believe I did that. *slaps forehead*
Ok
so
[tex]\frac{1}{4}\pi[/tex]
is the projected probability it should land hitting a vertex. So the closer my actual experiment probability comes out to %78.54 the more accurate my approximation of pi will be. All I would need to do is calculate the percentage I get from my experiment for the probability it should land on a vertex and set the ratio equal to that to solve for pi.
It's not that you need to know it to solve it, it's that it needs to be in there, because that's the variable you're solving for. Eventually, your equation will boil down to nothing but a bunch of numbers and one unknown variable (pi):
pi = (an expression of variables)
when you plug your numbers into your variables, you'll get
pi = (an expression of numbers) which reduces to (one number)
pi = number
