Bhisma Thapa
- 3
To be more specific, if i have to heat water 300l of water in one hour. What should the power of a heating coil?
To calculate the power required for a heating coil to heat 300 liters of water from room temperature to boiling within one hour, one must consider the energy loss due to heat dissipation and the insulation of the container. A specific calculator available at this link can assist in determining the necessary energy and power. Additionally, safety precautions are paramount when using a pressurized electrical cooker, as improper handling can lead to dangerous situations.
PREREQUISITESEngineers, appliance designers, safety inspectors, and anyone involved in the design or operation of heating systems, particularly in pressurized cooking applications.
Welcome to the PF.Bhisma Thapa said:To be more specific, if i have to heat water 300l of water in one hour. What should the power of a heating coil?
Starting temp will be at room temperature.I need it for boiling.berkeman said:Welcome to the PF.
What are the starting and final temperatures? Do you need to boil it, or just heat it to a warmer temperature?
This calculator will help you figure out how much energy and power are required to heat your water from room temperature to just short of boiling:Bhisma Thapa said:Starting temp will be at room temperature.I need it for boiling.
Power is the rate of energy flow. You must deliver energy at a rate greater than the heat loss by all processes over all temperatures.Bhisma Thapa said:What should the power of a heating coil?
Thanks.berkeman said:This calculator will help you figure out how much energy and power are required to heat your water from room temperature to just short of boiling:
https://bloglocation.com/art/water-heating-calculator-for-time-energy-power
After that, it depends on whether you want to actually boil off the water, or keep it boiling for some period of time. Also, unless your container is perfectly insulated, you will lose some energy to the surroundings...
Can you say more about the application?
Bhisma Thapa said:It will be used like a pressurized electrical cooker.
Agreed.anorlunda said:Be careful and very vigilant about safety. It takes only one mistake to turn a pressure cooker into a bomb able to kill everyone in the room.
