How Can We Prove Linear Dependence in Vector Spaces?
10 replies · 5K views
autre
I have to prove:
Let [itex]u_{1}[/itex] and [itex]u_{2}[/itex] be nonzero vectors in vector space [itex]U[/itex]. Show that {[itex]u_{1}[/itex],[itex]u_{2}[/itex]} is linearly dependent iff [itex]u_{1}[/itex] is a scalar multiple of [itex]u_{2}[/itex] or vice-versa.
My attempt at a proof:
([itex]\rightarrow[/itex]) Let {[itex]u_{1}[/itex],[itex]u_{2}[/itex]} be linearly dependent. Then, [itex]\alpha_{1}u_{1}+ \alpha_{2}u_{2}=0[/itex] where [itex]\alpha_{1} \not= \alpha_{2}[/itex]...I'm stuck here in this direction
([itex]\leftarrow[/itex]) Fairly trivial. Let and [itex]u_{1} = -u_{2}[/itex]. Then [itex]\alpha_{1}u_{1}+ \alpha_{2}u_{2}=0[/itex] but [itex]\alpha_{1} \not= \alpha_{2}[/itex].
Any ideas?
Look at the definition of linear dependence again. That's not what linear dependence tells you about the scalars. It tells you that [itex]\alpha_1[/itex] and [itex]\alpha_2[/itex] are not both...? Fixing this definition will also help finish the proof.
Maybe I'm missing something, but you can't just assume that [itex]u_1 = -u_2[/itex] to prove the reverse direction. You're only given that one is a scalar multiple of the other, so you only know [itex]u_1 = c u_2[/itex] for some scalar c.
"[itex]\rightarrow[/itex]"
looking at the definition, what is the condition on [itex]\alpha_{1}[/itex] and [itex]\alpha_{2}[/itex] for {[itex]u_{1}, u_{2}[/itex]} to be linearly dependent?
"[itex]\leftarrow[/itex]"
in this part you have to assume [itex]u_{1} = c u_{2}[/itex], perhaps the negative you put in your original will give you a hint as to what to do for the first part.
Thanks for the input guys.
([itex]\rightarrow[/itex]) Let {[itex]u_{1}[/itex],[itex]u_{2}[/itex]} be linearly dependent. Then, [itex]\alpha_{1}u_{1}+ \alpha_{2}u_{2}=0[/itex] where [itex]\alpha_{1}, \alpha_{2}[/itex] are not both [itex]0[/itex]. Therefore, if [itex]\alpha_{1}u_{1}+ \alpha_{2}u_{2}=0[/itex], [itex]\alpha_{1}u_{1} = -\alpha_{2}u_{2}[/itex]. Is that good?
For part 2:
([itex]\leftarrow[/itex]) Let and [itex]u_{1} = cu_{2}[/itex]. Why does that mean that the coefficients aren't both [itex]0[/itex]?
now you're getting somewhere for the "[itex]\rightarrow[/itex]" part.
so if [itex]\alpha_{1}u_{1} = -\alpha_{2}u{2}[/itex] where either [itex]\alpha_{1}[/itex] or [itex]\alpha_{2}[/itex] is non zero (or maybe both are non-zero), what can you do now that you couldn't before?
for the second part, you have to somehow relate [itex]u_{1} = c u_{2}[/itex] to your findings from part one.
If [itex]\alpha_{1}u_{1} = -\alpha_{2}u_{2}[/itex], then one is a scalar multiple of another as required by the direction, right? What more do I need to do?
I know it seems obvious, but you have to explicitly state:
assume one of [itex]\alpha_{1}, \alpha_{2}[/itex] is non zero (by the definition of linear dependance). for the sake of argument we take [itex]\alpha_{1}[/itex] to be the non zero coefficiant, and since it is non-zero we can divide both sides by that coefficiant.
which leads us to : [itex]u_{1} = \frac{-\alpha_{2}u_{2}}{\alpha_{1}}[/itex]. therefore if the set {[itex]u_{1}, u_{2}[/itex]} is linearly dependent, one must be a scalar multiple of the other as desired.
the "[itex]\leftarrow[/itex]" is just a reversal of "[itex]\rightarrow[/itex]"
its a lot more powerful to prove a set of [itex]n[/itex] elements than one of just 2, if you're looking for good practice i'd suggest trying that.
autre said:
For part 2:
So now you need to find scalars [itex]\alpha_1, \alpha_2[/itex] not both zero such that [itex]\alpha_1 u_1 + \alpha_2 u_2 =0[/itex]. Can you see a way to use the information [itex]u_1 = c u_2[/itex] to choose scalars so this is true? Try rearranging the equation in your post.
as gordonj005 pointed out, the proof of (→) breaks down into 2 cases.
you can avoid this difficulty by noting that, in point of fact:
[itex]\alpha_1u_1 = -\alpha_2u_2 \implies \alpha_1,\alpha_2 \neq 0[/itex] since, for example:
[itex]\alpha_1 = 0 \implies -\alpha_2u_2 = 0 \implies \alpha_2 = 0[/itex] since [itex]u_2 \neq 0[/itex].
so you are free to divide by α1 or α2.
you almost had the (←) in your first go-round. your mistake was this: assuming α1 = 1. just use "c" where c is the multiple of u1 that u2 is.
why do you know that c ≠ 0 (because u1 is _______)?
a non-zero vector! Just curious, how would I go about this part of the proof if it weren't specified that u1, u2 were nonzero vectors?
suppose u1 = 0. then {u1,u2} is linearly dependent no matter what u2 is:
au1 + 0u2 = 0, for any non-zero value of a.
the same goes if u2 = 0.
so the statement:{u1,u2} is linearly dependent iff u1 is a scalar multiple of u2 (and vice-versa), is no longer true.
however, in actual practice, no one ever tries to decide if the 0-vector is part of a basis, because including it automatically makes a set linearly dependent. so one just wants to decide if a set of non-zero vectors is linearly independent or not.
