How does music manipulate our perception of ascending sequences?
  • Thread starter Thread starter Collin237
    perception
The discussion centers on the manipulation of musical perception in Beethoven's Piano Concerto No. 5, specifically the third movement's ascending phrases. Participants analyze the reprise of an ascending sequence that appears to ascend further without a corresponding transposition in subsequent sections. Key observations include the role of dynamics, instrument changes, and chord progressions, particularly the transition from F7 to Bb7, which contributes to the perceived elevation of pitch. The conversation highlights the complexities of musical structure and listener perception, emphasizing the impact of training and familiarity with musical keys.
  • Understanding of Beethoven's Piano Concerto No. 5, Op. 73
  • Knowledge of musical chord progressions, specifically F7 and Bb7
  • Familiarity with musical dynamics and instrumentation
  • Basic concepts of musical modulation and key signatures
  • Analyze the chord progressions in Beethoven's works, focusing on modulation techniques
  • Explore the concept of Shepherd tones and their effect on auditory perception
  • Study the role of dynamics in classical music, particularly in the works of Beethoven
  • Investigate the impact of instrument choice on musical interpretation and listener experience
Musicians, music theorists, and educators interested in the intricacies of classical music composition and the psychological effects of musical structure on perception.
Collin237
In Beethoven's Piano Concerto #5, third movement, the exposition contains an ascending phrase. When the exposition is reprised, the ascension goes up one extra time. And yet nothing after it seems to have been transposed to anything higher as a result. How is this possible? Where did the extra ascension go?
I don't know, but Beethoven made his own rules. The Emperor Concerto is one of his greatest, but also sometimes baffling works. I couldn't find any specific reference to a "missing ascension" in descriptions I read, but this one may give you some clues.
http://www.aspenmusicfestival.com/program_notes/view/beethoven-piano-concerto-no.-5-in-e-flat-op.-73-emperor
Here's a recording with sheet music, maybe you can figure it out. If you mean the reprise at 5:26, then it's actually the exact same line!
No, I mean where the section with the rising triples near 1:14 is reprised near 6:43.
The first time, there are accents on Fmsus4, Ab, and FMaj7, the latter of which marks the transition to falling triples. The second time however, the rising triples extend past the third accent, to a fourth accent on Fdim.
Does this have something to do with the symmetry of a dim chord (Fdim = Abdim)?
@Jonathan Scott may be able to help.
Jonathan Scott said:
For dynamics Beethoven had the advantage of technological advances, in that keyboard and string instruments became significantly more powerful and robust during his working lifetime, making the dimension of dynamics much more interesting, and I agree he exploited it well. Of course, he was also deaf, so appreciated the very loud bits!
I don't understand the question. That section starts in the same key of Eb in both versions (at bars 49 and 294 in my piano score), but the second version has two extra bars (at bar 304) which means that instead of ending on a F7 (not Fmaj7) chord it ends on a Bb7 chord. From that point onwards everything is the same as the first time but a fourth higher in pitch.
(In concert that's probably quite easy to remember, but when I've just played the first version in rehearsal, it's very easy to play the second version if one rehearses the same section again!)
[Edited to correct minor typo]
I was asking why it isn't obvious that the pitch is raised. Or is it just that I haven't been trained to hear it?
It's the same music but in a different key. If you're not normally aware of keys then you probably wouldn't notice. I started learning the piano when I was 5, so like many people who start their music young I have fairly reliable perfect pitch.
It's also different instruments (starts with horn instead of bassoon if I remember correctly).
So in the first case, it looks like the chords are
Ab, F7/A, Bb, F7/C
while in the second case, you have
Ab, F7/A, Bb, F7/C, Bb/D, Edim, Bb7/F
Perhaps one could write C7/E instead of Edim, but there is no C being played. Anyway, as you can see, the bass note rises by one step (either half or whole) for each new chord. The approach to the final chord is actually different, so it shouldn't feel like he's landed in the same place, but rather that he's extended the original line by an extra measure.
I haven't taken the time to listen, but if I had to guess, the first instance of this is meant to introduce a modulation in Bb major, whereas the second one is meant to stay in Eb major in preparation for the ending of the piece.
Ab, F7/A, Bb, F7/C
Yes, I agree with all of that.
The ear does funny things, Shepherd tones for example fool the ear and it is impossible to hear whether a following tone is higher or lower than a previous tone. notes are called tritones. Some musicians exploit this to create things like Bach's endlessly rising canon. If you play an ascending sequence and then drop one of the notes an octave in the next sequence, and if you pick the right note and placing, it sounds as if the sequence just goes up.
  • · Replies 72 ·
11K
  • · Replies 24 ·
