How Do Beam Forces and Support Reactions Relate in Equilibrium Analysis?
  • Thread starter sami23
    Equilibrium
1 reply · 6K views · last reply
sami23
As shown, a roller at point A and a pin at point B support a uniform beam that weighs 42.0 lb. The beam is subjected to the forces F1 = 21.0 lb and F2 = 22.0 lb. The dimensions are L1 = 1.30 ft and L2 = 8.00 ft. What are the magnitudes FA and FB of the reaction forces FA and FB at points A and B, respectively? The beam's height and width are negligible.
[tex]\Sigma[/tex]Fx = 0
[tex]\Sigma[/tex]Fy = 0
[tex]\Sigma[/tex]MA = 0
FA = sqrt{Ax^2 + Ay^2}
FB = sqrt{Bx^2 + By^2}
F1L1 + F2cos(15)*(L1+L2) = By(L1+L2)
21(1.3) + 22cos(15)(9.3) = 9.3By
By = 24.186 lb (upward)
Ay + By = -F1 -F2cos(15) - 42 = 0
Ay + 24.186 = -21 - 22cos(15) - 42
Ay = 108.47 lb (downward)
Ax + Bx = F2sin(15)= 0
Ax + Bx = 5.694 lb
How do I find the x components for A and B?
[tex]\theta[/tex] = tan-1(3/4) = 36.87[tex]\circ[/tex]
I'm not sure about my A and B components.
  • Free-body diagram of a horizontal beam on supports A (roller, inclined surface with 3-4-5 slope) and B (pin). Downward force F1 is applied at distance l1 from the left end, force F2 is applied at the right end at 15 degrees from vertical, and distance l2 spans from F1 to B.
You forgot to include the moment from the beams weight
you mean upward. The terms on the right should all be plus terms ( that is , if Q - P = 0, then +Q = +P) But first correct the error in the moment equation
Ax + Bx = 5.694 lb
Once you correctly solve for Ay, then Ax is related to Ay by the properties of the 3-4-5 triangle (the reaction at A must be perprendicular to the diagonal, since it is a roller support)
