How do E[X] and E[|X|] relate?
  • Context: Undergrad
  • Thread starter Thread starter MidgetDwarf
The discussion revolves around the relationship between the expected values E[X] and E[|X|] in the context of probability theory, particularly focusing on the Cauchy distribution and its moments. Participants explore the implications of divergence in these expected values, the conditions under which they exist, and the mathematical reasoning behind their relationships.
  • Some participants discuss the divergence of E[|X|] implying the divergence of E[X], suggesting that if E[|X|] is infinite or undefined, then E[X] must also diverge.
  • Others argue that the relationship between E[X] and E[|X|] may depend on the type of integral used, noting that this relationship holds under Lebesgue integration but not necessarily under Riemann integration.
  • A participant introduces the decomposition of E into its positive and negative parts, questioning whether a requirement exists for the cardinality or density of these parts to maintain the relationship between E[X] and E[|X|].
  • Some participants express uncertainty regarding the higher-order moments E[X^n] for n > 1, suggesting that restrictions on the values of X might affect their existence.
  • One participant presents a contraposition argument, asserting that if E[X] converges, then E[|X|] must also converge, providing a mathematical expression to support this claim.
  • Another participant discusses the divergence of integrals for the Cauchy density, particularly for n ≥ 2, and how this affects the overall divergence of the expected values.
Participants express a mix of agreement and disagreement regarding the implications of divergence between E[X] and E[|X|]. While some support the idea that divergence in one implies divergence in the other, others highlight the complexity and conditions under which these relationships hold, indicating that the discussion remains unresolved.
Limitations include the dependence on the type of integral used (Lebesgue vs. Riemann) and the assumptions regarding the behavior of the integrals involved. The discussion also touches on the need for further clarification on the conditions under which higher-order moments exist.
MidgetDwarf
TL;DR
For expectations of random variables. Relationship between E[X] n E[|X|]?
Greetings,
I am studying probability theory [non-measure theory] from a textbook.
I stumbled to the topic stating that Cauchy Distribution has no moments.
It was not proved, and I tried working it via direct calculation of the improper integral of E[X^n] for the case n=1.
Anyhow, I wanted to generalize this without success. I stumbled upon this thread here:
I really enjoyed the proof given StoneTemplePython. However, I am unsure of the following:
Why does E[|x|] diverges implies E[x] diverges?I believe this is the crux of the poof. Since it assumes, in my understanding, that having shown E[|X|] diverges, then applying the comparison test for improper integrals in the last line of that thread, then E[|X|^n] diverges.
How does this relate to E[X^n]?
. My hunch tells me that it has something to do with f is integrable iff |f| is integrable, and how we can decompose |f| into the positive and negative parts of f?
My knowledge of Measure Theory is very poor. So hopefully someone here can why.
Integral for even n diverges clearly to plus infinite. Integral for odd n is zero for integrand [-L,L]. However we do not have such a constraint thus the integral diverges plus or minus.
FactChecker said:
Let ##X_-## and ##X_+## denote the negative and positive parts of ##X##. Then ##E[X]=E[X_+]+E[X_-]## and ##E[|X|]=E[X_+]-E[X_-]##. If ##E[|X|]## is infinite or undefined, then one or both of ##E[X_+]## and ##E[X_-]## are infinite, so ##E[X]=E[X_+]+E[X_-]## also diverges.
I'm not sure about the higher orders, ##E[X^n]## for ##n\gt 1##. If ##X## is restricted to ##|X| \lt 1##, then those moments may exist.
Thank you fact checker!
I now understand that the proof given was using the measure theory [lebesgue integral] formulation of probability.
the decomposition of E into its positive and negative parts comfirmed my hunch.
from my understanding, E[|X|] exists iff E[X] does using lebesgue integral. Since it comes from the fact that f is integrable iff |f| is integrable.
This is not necessarily true under the Reimann Integral. Ie., E[X] finite does not imply E[|X]|] is finite.
For this to hold true it seems to me there also needs to be a requirement along the lines that ##X_+## has same "cardinality" or "density" as ##X_-##?
E.g. for a finite sequence of ##N = P + M## numbers, ##P## non-negative and ##M## negative, I would expect the relation to be ##N E[X] = P E[X_+] + M E[X_-]##.
I wouldn't say that necessarily depends on the type of integral. Lebesgue integration allows you to talk about integration in a more general context, but it is easy to use this with either integral method. That being said, I do not know what treacherous details would be required in a formal proof.
Yes, it is a simple step in that direction.
That may be true. I am too rusty on this to say. It would depend on how the limits are defined. I would say that if ##E[|X|]## is infinite, with both positive and negative parts infinite, then the value of ##E[X]## depends on how limits are taken.
I will have to leave this discussion for those who are more knowledgeable.
The contraposition: "E[ X ] converges thus E[ |X| ] converges" seems easier to handle.
$$ E[|x|]:=\int_{-\infty}^{+\infty} f(x)|x| dx = -\int_{-\infty}^{0} f(x)x dx + \int_{0}^{+\infty} f(x)x dx = E[x]-2 \int_{-\infty}^{0} f(x)x dx $$
As a finite value cannot be divided into two infinites, ##\int_{-\infty}^{0} f(x)x dx## is finite thus E[|x|] is finite.
Notice that the integral $$\int_0^1 f(x)dx$$ converges for the Cauchy density. Now, for x larger than 1 $$1+x^2 < 2x^2$$ so $$\frac 1 {1+x^2} > \frac 1 {2x^2}$$
This means that for ##n \ge 2## you have $$\frac{x^n}{1+x^2} > \frac{x^n}{2x^2} = \frac{x^{n-2}}{2}$$, so ## n - 2 \ge 0##, and since $$\int_1^{\infty} x^k dx$$ diverges when ##k \ge 0## you've shown $$\int_0^{\infty} x^n f(x) dx$$ diverges for ##n \ge 2##.
For the integral over the negative portion of the number line apply that sort of argument to ##|x|^n##.
Of course since $$\int_{-\infty}^{\infty} f(x) dx$$ is defined as $$\int_{-\infty}^{0} f(x) dx + \int_{0}^{\infty} f(x) dx$$ (I could have used any number other than $0$), since the integral over the positive portion diverges the entire integral diverges.
