How do I connect circuit elements in parallel using breadboards?
2 replies · 2K views
Benny
Hi, I have a question about 'breadboards.' These provide a means of wiring up a circuit. I'm a bit behind and I'm trying to figure out how to connect circuit elements in parallel using these boards.
I know that each row on the board represents a 'node' of a circuit so connecting circuit elements in series is not a problem because I can see how it's supposed to be done. But what's the difference between 'series' and 'parallel' connections on breadboards? Any help would be good thanks.
Too bad i can't physically show you, it would be a lot easier. t
Parallel is when they share the same two nodes and series is when they share a single node. If you want to connect an element in parallel, just put the same element above or below the first on the same columns. What you want to do is build the circuit exactly as you see it on the diagram.
Ok, I think I get what you're trying to illustrate. Thanks for your help.
