How do I minimize a function with a constraint using Lagrange-Euler method?
To minimize a functional with a constraint using the Lagrange-Euler method, one must consider the functional defined by J(f) = ∫_a^b F(x, f(x)) dx, while ensuring that the constraint ∫_a^b G(t, f(t)) dt = M is satisfied. The discussion clarifies that F is a functional that maps a function to a real number, and the notation can be confusing as it sometimes includes an explicit variable. It is suggested to explore the isoperimetric problem and variational problems with subsidiary conditions for further understanding. A key approach involves introducing a Lagrange multiplier to incorporate the constraint into the minimization process. This method provides a structured way to address the minimization of functionals under constraints.
fery
I am working on a functional and I need to find its minimum, the conventional procedure is to use Lagrange-Euler method and find the minimum state of the function, but if I need to impose a constraint to the function, I don't know what I need to do
J=int(F(t, f(t), a, b)) minimize(f) and int(G(t, f(t), a, b))=M,
It should be very elementary, but I am confused about what I need to do.
Your help will be very appreciated.
Farshad
I don't understand your notation. See if I've guess the problem correctly:
J(f) is a linear functional defined by J(f) = \int_a^b F(x,f(x)) dx where F(x,y) is a given function of two variables. We wish to find the minimum value of J over all functions f that satisfy \int_a^b G(t,f(t)) = M where M is a given constant and G(x,y) is a given function of two variables.
All true but F(x,f(x)) is a functional not a function, which is mapping of a function to R. For minimization of the functional Euler-Lagrange is the conventional method, but when there is constraint (int(G(t,f(t),a,b)=M) I am not sure what should I do.
Farshad
Then I don't understand the notation F(x,f(x)). If F is a functional and f is a function then
F(f) is a real number correct? We don't need the argument 'x'.
For example, in the calculus of variations an arc length problem is to minimize the functional J given by
J[f] = \int_a^b \sqrt{1 + (f'(x))^2} dx
The expression \sqrt{1 + (f'(x))^2)} is a function not a functional.
I agree, the integrand does not return a number given a function. It returns an expression. You integrate and then you have a number.
You might look up the 'isoperimetric problem' which is an example, or 'variational problems with subsidiary conditions' more generally. Gelfand and Fomin's little book on the calculus of variations has a section on it.
that is, Given the functional:
<br /> J[y]=\int_a^b F(x,y,y&#039;)dx<br />
let the admissable curves satisfy the conditions:
<br /> y(a)=A,y(b)=B, K[y]=\int_a^b G(x,y,y&#039;)dx=M<br />
Where K[y] is another functional and let J[y] have an extremum for y=y(x). Then, if y=y(x) is not an extremal of K[y], there exists a constant \lambda such that y=y(x) is an extremal of the functional:
<br /> \int_a^b (F+\lambda G)dx<br />
That's from the text and probably is enough to get you started.
  • · Replies 17 ·
