How do I prove the following: lim x^2 + x - 12 = 7x-> 3
  • Thread starter Thread starter powp
The discussion focuses on proving the limit of the function (x^2 + x - 12)/(x - 3) as x approaches 3 equals 7. Participants analyze the epsilon-delta definition of limits, with Peter initially struggling with the proof and Edwin providing guidance. The key conclusion is that by manipulating the expression to show |x - 3| < ε, one can establish the limit. The correct approach involves recognizing that the limit simplifies to |x - 3|, allowing for δ = ε to satisfy the proof.
  • Epsilon-delta definition of limits
  • Basic algebraic manipulation of rational functions
  • Understanding of limits in calculus
  • Familiarity with formal proofs in mathematics
  • Study the epsilon-delta definition of limits in detail
  • Practice algebraic manipulation of limits with various functions
  • Learn about formal proof techniques in calculus
  • Explore historical examples of limit proofs, such as those by Gauss
Students of calculus, mathematics educators, and anyone interested in mastering the formal proofs of limits and their applications in analysis.
powp
x-> 3 ------------
x-3
here is my solution so far but think it is wrong
Given E > 0 and D > 0 such that
|x^2 + x - 12 |
|------------ - 7| < E whenever 0 < |x-3| < D
| x-3 |
|(x-3)(x+4) |
| x-3 |
|x + 4 - 7| < E
|x - 3| < E
Not sure where to go from here or if I am even close.
Thanks
Peter
PS I am new to proofs
I'll give it a try, but I've never really taken a formal proofs class, so you might want to double check my results to make sure that it is accurate.
-(x^2 + x - 12)/(x-3) < D < (x^2 +x - 12)/(x - 3)
-(x^2 + x -12) > D(x-3) > (x^2 + x - 12)
let u = D(x-3)
(u/D) = x - 3
(u/D) + 3 = x
So as x approaches 3, (u/D) must approach 0, which would only occur if u approaches 0.
D((u/D+3) - 3) = D(u/D) = u, so the inequality above becomes:
-((u/D + 3)^2 + (u/D +3) -12) > u > ((u/D + 3)^2 + (u/D +3) -12)
-u(u + 7*D)/ D^2 > u > u(u+7*D)/D^2
divide through by u, and you get:
-(u + 7*D)/D^2 > 1 > (u + 7*D) / D^2
multiply through by D^2 and you get:
-(u +7*D) > D^2 > u + 7*D
-u - 7*D > D^2 > u + 7*D
letting u go to 0, as x approaches 3, we have:
-7*D> D^2 > 7*D
Now -7*D can not be negative as D^2 is a positive number, so D be negative, so dividing through by D yields:
-7< D < 7
So, D < |7|.
Now the question I have is, does this prove:
x-> 3 ------------
...x-3
Edwin, you forgot the "7" right from the start!
Peter, you are approaching it correctly. You want to show that for any positive \epsilonthere exist a \delta so that as long as 0<|x-3|< \delta.
|\frac{x^2+x-12}{x-3}-7|&lt; \epsilon.
Yes, doing the algebra, the left side of that is
|\frac{x^2+ x-12- 7x+21}{x-7}|= |\frac{x^2-6x+9}{x-3}|=|\frac{(x-3)^2}{x-3}|
(I just noticed that you factored and canceled before subtracting the 7! Easier your way but the same thing!)
and because 0< |x-3| that denominator is not 0 so this is equal to
|x-3|
so that your original expression reduces to
|x-3|&lt;\epsilon
It should be clear that taking \delta= \epsilon works nicely.
Thanks
Still trying to figure this whole thing out.
In my text it says that once I detemine the delta value I need to use it it the actual proof. doing the acutal proof just seems like do the reverse of what was done before. Is this correct?
How does this prove anything? I am a little confussed.
well, fundamentally when you work backwards through the proof on your "scrap paper" to find a delta value is "cheating". Thankfully we don't concern our selves with this little problem, as long as the formal proof holds.
As an example from math history, Gauss would pull extremely insightful delta vaules out of thin air to do proofs. In some cases it took over a hundred years for people to figure out where he got his delta values.
Cheers.
Oops! I forgot the 7. I just read a little more on formal definition of limits. Anyhow, I'll be taking some formal proof based classes shortly, so I'll keep an eye on these posts to see if I can pick up some tid-bits here and there.
Thanks!
Best Regards,
Edwin
