How do I simplify log₉(1/27)?
  • Thread starter matadorqk
    Logarithms
48 replies · 16K views · last reply
Thanks evrn!
Express as a single logarithm 2lnx + ln (x-1) - ln (x-2)
None used (Basic Algebra)
So, let's substitute ln for a, to make it simpler
2ax +a (x-1) - a (x-2)
2ax +ax - a - ax +2a
2ax - a +2a
2ax+a
2lnx+ln
ln (2x+1)
I think that's correct, I'd appreciate some re-check just in case though.
That's the last one, thanks everyone for the help!
2ax - a +2a
2ax+a
2lnx+ln
ln (2x+1)
You can't substitute for ln... ln is not a variable. it's a function... You could substitute for something like ln(a) which is a value, or ln(x)... but not just ln...
2lnx = ln(x^2)
ln(x-1) - ln(x-2) = ln[(x-1)/(x-2)]
ln(x^2) + ln[(x-1)/(x-2)] = ln[(x^3-x^2)/(x-2)]
Uh oh.. Ok let's restart again then.
So ln= [tex]log_{e}x[/tex]
Ok, ill go from there and get back to you
**Or take roco's idea, a head start :)
nooo!
rocophysics said:
nooo!
... I won't just copy it and not learn no worries.
A couple questions:
Is 2lnx=lnx^2 a formula or 'standard'?
Ohh wait, do you get that from the log formulas? That explains a lot!
So you are using [tex]\log_{a}x^y=y\log_{a}x[/tex]
And then you use [tex]\log_{a}(\frac{x}{y})=\log_{a}x-\log_{a}y[/tex]..
So that's how you do your first two steps. Then you insert [tex]lnx^2[/tex] into the ln (x-1) in a reverse distribution. I think I got that correctly, but is that as much as I can simplify?
Would [tex]\frac{\ln(x^3-x^2)}{x-2}[/tex] be the final answer? I stared at it for a while haha, can't find a way to simplify more.
A couple questions:
Careful. the entire fraction should be inside the ln...
Right!
[tex]ln(\frac{x^3-x^2}{x-2})[/tex]
matadorqk said:
Right!
That's the answer. I don't think you can simplify any more.
Well, not to take the risk, there's one more problem I did without consulting, so I rather check with you to see if I did it correct. This one I feel a bit more confident about, let's see how that goes:
1. Homework Statement
Solve for x: [tex]\log_{3}x + \log_{3}(x-2)=1[/tex]
2. Homework Equations
#1[tex]\log_{a}x+\log_{a}y=\log_{a}xy[/tex]
#2[tex]y=\log_{b}(x)[/tex]
#3[tex]x=b^y[/tex]
3. The Attempt at a Solution
Ok so let's solve using the formula #1:
So:
[tex]\log_{3}(x)(x-2)=1[/tex]
[tex]\log_{3}(x^2-2x)=1[/tex]
To make this simpler, let's make [tex]x^2-2x=w[/tex]
[tex]log_{3}(w)=1[/tex]
So use formula #2/#3 to get:
[tex]w=3^1[/tex]
[tex]x^2-2x=3[/tex]
Now I kind of got confused on what to do. I seriously don't know why I can't algebraically solve it, by trial and error I got x=3.. but perhaps its the excessive coke or sometihng that's blocking me from algebraically solving this. Help?
have you taken Chemistry II? it's heavily used for Acids/Bases and Reaction Rates, easier than this tho.
Nope.. I only took General Chemistry a year ago (10th)..
you're already at the 2nd to the last step
x^2 - 2x - 3 = 0
now solve for x
Have you learned how to solve quadratic equations?
OHH OK, I think I can solve that!
X=3 or x=-1
as (x-3)(x+1)=0
X=3 or x=-1
as (x-3)(x+1)=0
Yes, but x=-1 is an extraneous root... so your answer is just x = 3.
To clarify it's extraneous because
[tex]\log_{3}(-1) + \log_{3}((-1)-2)=1[/tex]
However we encounter a problem here since
[tex]log_{a}b = c[/tex], "b" must be >0
Clearly in this problem it's not and doesn't work.
Well, no, it's not. log3(-1) and log3(-3) are undefined and have no value- their sum is NOT equal to 1, it doesn't equal anything.
Yes, that's the reason -1 is "extraneous". It satisfies the equation x2- 2x= 3 but not log3(x)+ log3(x-1)= 1.
[tex]\log_{3}(-1) + \log_{3}((-1)-2)=1[/tex] was just to show an easy way to check -- plug the numbers into the equation. Doesn't match the domain of a log so it doesn't exist...
