How do I sketch a parametric curve in 3D?
  • Thread starter Gameowner
    Graph
Gameowner
Question attached
I have no idea at all how to start this, I've plotted all 3 separated as x=, y= and z=, which gave me 3 different curves, would I then just join them together?
any hint, tips would be much appareciated
  • Typeset problem statement defining r(θ, z) = (√z cos θ, (√z/2) sin θ, z) and the surface S for 0 ≤ θ < 2π, 0 ≤ z ≤ h, with a vector field F = (−z, −x, y²) and part (a) asking to sketch the surface.
[tex]x =\sqrt z \sin(\theta),\ y = \frac{\sqrt z} 2 \cos(\theta)[/tex]
Hint: Multiply the second equation by 2, square both and add and see if that helps.
yes! that has helped a lot, although when it came to plotting the equation, I was not sure about the domain of the graph. But this is what I got
I assume since the question specifies that theta is between 0 and 2pi, the maximum allowable value for x-axis and y-axis is -1/1?
As for the h, which is any number greater than 0, I just substituted an arbitrary point greater than 0.
  • Maple command implicitplot3d(z=x^2+4*y^2, y=-1..1, x=-1..1, z=0..10, axes=boxed) above a 3D plot of an elliptic paraboloid surface in a boxed frame, with axes labelled x, y and z.
Try this code for a nicer plot,which might help you with your domain. I used h = 10 for an example:
restart;
h := 10;
surface := [sqrt(z)*cos(theta), sqrt(z)*sin(theta), z];
domain := [sqrt(z)*cos(theta), sqrt(z)*sin(theta), 0];
plot3d({domain, surface}, theta = 0 .. 2*Pi, z = 0 .. h, style = patchcontour);
