How do I solve 3sin(x) + 4cos(x) = 1?
11 replies · 6K views · last reply
Bogrune
I took a test in my Precalculus class about 3 weeks ago, and the tests were handed back this week. I saw that I didn't do so well because I was stumped on this equation:
3sinx + 4cosx = 1
We were to use the following formulas to solve this equation:
sin(A+B)= sinAcosB + cosAsinB
cos(A+B)= cosAcosB - sinAsinB
sin2 + cos2 = 1
I tried to apply one of the formulas, but it just didn't make sense:
3sin2x + 4cos2x = 1
I then tried to use the addition identities, but it still didn't make sense since both expressions(3sinx + 4cosx) only have one term. Anyone know how to solve this?
3sinx + 4cosx = 1
sin2 + cos2 = 1
3sin2x + 4cos2x = 1
You can't do this. You are apparently squaring both sides, but to do that, you have to square the quantity 3sin(x) + 4cos(x).
If you had an equation a + b = 1, and you squared both sides, you would get
(a + b)2 = 12,
or a2 + 2ab + b2 = 1
You would NOT get
a2 + b2 = 12
Divide both sides of the equation by 5. There's a reason I picked this number, which I'll get to later.
This gives you
3/5 sin(x) + 4/5 cos(x) = 1/5
Since 3/5 and 4/5 are between -1 and 1, we can consider them to be the cosine and sine, respectively of some angle A, so let cos(A) = 3/5 and sin(A) = 4/5.
Now rewrite the equation above as
cos(A) sin(x) + sin(A)cos(x) = 1/5
You can use one of your relevant identities to rewrite the left side in terms of either sin or cos of something.
The reason I picked 5 in an earlier step is that I wanted to turn 3 and 4 into numbers that would be suitable values for a sine and cosine. What I did was take the square root of 32 + 42 = sqrt(25) = 5.
This gives you
I'm sorry, I'm known to be pretty slow. So am I to turn the equation:
cosAsinx + sinAcosx = 1/5
into
sin(A+x) = 1/5?
into
sin(A+x) = 1/5?
Yep, but you'll know what A is.
Okay, thanks. So will my solution (with the work shown, of course) be:
sin(A+x) = 1/5
A+x = sin-1(1/5) +2πn
x= 4/5 + sin-1(1/5) +2πn
sin(A+x) = 1/5
A is not 4/5. sin(A) = 4/5, so what is A? You also know that cos(A) = 3/5.
Oh, I think I get it now. So it's really
sin-1(4/5) + sin-1(1/5) + 2πn
since I believe that sin(A) = 4/5, A = sin-1(4/5)?
this has got rather confusing :confused:
you're rewriting the original equation as
(3/5)sinx + (4/5)cosx = 1/5 …
carry on from there :smile:​
sin(A+x) = 1/5
As I noted earlier, the equation above is wrong because you replaced A by 4/5.
The equation above it is correct, although I don't believe you're getting all of the solutions. If sin(x) = y, then sin(x + 2π) = y, as well. What you're forgetting is that it's also true that sin(x) = sin(π/2 - x), or angles that are symmetric around π/2 have the same sines.
It might be best to find a single solution for x, and then generalize to all possible values of x later on.
You have sin(A + x) = 1/5, so A + x = sin-1 (1/5), so x = -A + sin-1 (1/5).
Substitute in for A (it is NOT 3/5 or 4/5) to find x.
Please pardon me for saying this: I understand that part, but isn't sin(x) really equal to sin(π-x), since the function of sin(x) is an odd function?
yup! he meant "sin(x) = sin(π - x), or angles that are symmetric around π/2 have the same sines." :biggrin:
