How do I solve a trig equation with two functions on one side?
  • Thread starter Thread starter Hypochondriac
    Trig
10 replies · 6K views
Hypochondriac
I have to solve:
2sinx = cos(x-60), for 0<=x<=360
so far i expanded the cos part
2sinx = cosxcos60 + sinxsin60
as cos60 = 1/2 and sin60 = (sqrt3)/2
2sinx = (1/2)cosx + ((sqrt3)/2)sinx
sinx = cosx + sqrt3 sinx
(1-sqrt3)sinx = cosx
but here's where I'm stuck, i have 2 trig functions in one equation and therefore cannot solve.
Hypochondriac said:
I have to solve:
This line is incorrect. You have multiplied both sides by 2 to remove the factor of 1/2 on the right hand side, so the left hand side should be premultipled by 4.
ahh yes, how silly of me,
but even now i have:
(4 - sqrt3)sinx = cosx
i need it all in sins or cos'
Or, you could remember that tanx=sinx/cosx
but if i divide through by cosx, i'll loose that solution of x because the cos' will cancel, its an equation not an expression.
No you won't. There's only going to be one solution to that equation in the range specified.
the answer in the back of the textbook gave 2 solutions.
I was told to never divide through with an equation, only with an expression
perhaps you only got one solution because you divided through to solve.
Sorry, I am being really stupid! You don't lose a solution by dividing by cos(x), but of course the function tan(x)= 1/(4-sqrt(3)), is periodic with period 180 degrees. So, the solutions to this in the given range will be the principal value for arctan(1/(4-sqrt(3))) [the one given by your calculator], and this value with 180 added on.
ok so arctan 1/(4-sqrt3) gives me my principle 23.8, and then +180 to give 203.8, my secondary.
Solved!
cheers, I am a bit weary about dividing through but I am not going to argue with the outcome!
It's fine because you know that an x where cos(x) is zero can't possibly be a solution (otherwise you have 4 - sqrt(3) = 0).
If you really wanted to, when you had sin on one side and cos on the other side, you could square both sides (and possibly introduce extraneous roots), and use an identity for (sinx)^2 or (cosx)^2, changing it to a quadratic type. The method above is much easier.
