How Do I Solve Polynomial Problem #19?
  • Thread starter yungman
    Polynomial
22 replies · 3K views · last reply
yungman
I have problem solving this. The question is #19 in the first attachment. My work is in the second attachment
Textbook page showing exercises 18 to 21: a patio dimensions word problem, exercise 19 asking for values of t making 6x^2 + tx + 25 factor into two binomials, and factoring problems 20 and 21, with partial graphs above.
I work to this point and get stuck:
https://www.physicsforums.com/attachments/270843
Can anyone help me?
Thanks
How many roots does a parabola have if it can be written as product of two binomials? How many does it have if it cannot?
I really don't know, this is a question from my grand daughter and this caught me cold. I am ashamed!
I set the equation to zero to get two roots.
In the Quadratic Formula, if the discriminant (the expression under the radical, ##b^2 - 4ac##) is positive, there will be two distinct roots. If the discriminant equals zero, there is one repeated root. If the discriminant is negative, there are no real roots (two complex roots).
Can anyone help me?
Thanks
This appears to be from a set of exercises for a lesson on factoring.
There are several methods for factoring a trinomial such as this. What method or methods have your granddaughter studied?
I have to get hold of her. thanks
I made a mistake on the denominators in my first post, it should be 12 instead of 2. I tried to edit that, but it asked to put in the relevant formula. I can't find how to write formula here. I used to be able to write formula so I don't have to write on paper and scan it in. Seems like it changed since 10 years ago when I was active here.
Can anyone give me a hint how to look at it? I talked to her, she have not even learn the b^2-4ac stuffs. I don't know why she's even given this problem.
I am really not interested in this, I am drowning on my C++ programming already, just want to resolve this and help her on this one. I haven't even have a chance to work on my C++ today yet!
Thanks
I have been looking at the question, the only values of t to get 2 binomials is this:
Handwritten working on lined paper: for x = (-t ± √(t²-600))/12 to have real solutions, t²-600 must be greater than or equal to 0, so t ≥ √600 or t ≤ -√600.
Is this right?
I suppose that you are referring to the quadratic formula:
The solution to the general quadratic equation: ##ax^2+bx+c=0 ##
is given by ##x = \dfrac{ -b \pm \sqrt{b^2-4ac} }{2a} ##
So, yes, you left the factor of ##a## out of the denominator. In this case ##a=6##.
In addition to what @Mark44 said, if ##b^2-4ac## is a perfect square, then ##ax^2+bx+c ## can be written as the product of two binomials. For your (granddaughter's) problem, you need ##t^2-600## to be a perfect square, (as well as being positive, of course).
This problem may be done this way, but it will be quite cumbersome. There are at least 6 possible values for t.
Another way to do this is to systematically find all of the pairs of binomials product give ##6x^2## for the leading term and ##25## for the constant term.
For example: ##(2x + ?)\times(3x + ?)## gives ##6x^2 + ... ##
and ##(?x + 1)\times(?x + 25)## gives ## ?x^2 +?x + 25##
I use your logic to have this, but I have 4 variables A, B, C and D, and I cannot solve it.
##(Ax+B)(Cx+D)=6x^2 + tx + 25##
It would be nice to do this instead of using
She have not learn this formula, it would be nice to have a way to do this without
mfb said:
@SammyS: Why would you want it to be a perfect square? No one required rational roots or any other special requirement.
Looking at the other exercises in the image in the OP, I conclude that these exercises have to do with factoring trinomials into the product of binomials, all with integer coefficients.
Correct. You have ##(Ax+B)(Cx+D)=6x^2 + tx + 25##.
But A and C are related: ##A\cdot C = 6##. Also ##B\cdot D = 25##.
Now get systematic.
With A = 1 and C = 6, let B = 1 and D =25, and multiply ##(x+1)(6x+25) ## to get ##t##.
Then let B = 5 and D =5, and multiply ##(x+5)(6x+5) ## to get another value for ##t##.
Then let B = 25 and D = 1 ... . Don't forget, B and D can both be negative.
Now consider A = 2 and C = 3. Run through the cases for B and D again.
When can you stop?
Now get systematic.
When can you stop?
Ok, I expanded these out:
Handwritten notebook page listing factorizations of 6x^2 + tx + 25 with pairs of values for A, B, C, D, each expanded and matched to a middle coefficient t, with red lines connecting results such as 31, 35, 53, 77 and 151.
I see the relation, I connected the pairs with same value of t. These are all the combination. But what does these means?
Does this means t = 25, 31, 35, 53, 77 and 151 all work?
Does this means t = 25, 31, 35, 77 and 151 all work?
Yes. Also 53 .
Additionally, t can be the negative of each of these.
SammyS said:
Yes. Also 53 .
Thanks, I missed the 53 when I read my notes. It's there also. I put it back in the last post already.
Thanks
Just to be clear, you can also have binomial products such as ##(3x-1)(2x-25)##, which gives ##t=-77##.
I don't share that interpretation.
Thanks for the help.
Actually after sitting on it for a day, I really feel the answer in my post #8 is more accurate. I understand the answer in post #15 looks better with integer coef for x.
BUT, this is NOT the full set of answer. Remember, coef for both x and 25 can be fraction, the requirement is just to have the final coef of x to be 6 and final number is 25. Also, coef of x in the two binomial can be of different polarity also, that complicate the situation even more. The few values in post #15 is ONLY a very small SUBSET of the value t can take on.
I still believe the answer in post #8 is the ONLY correct answer. Grand daughter just has to learn the Quadratic Formula quick and use it.
Thanks
yungman said:
Any comment?
Since there isn't any restriction given in the problem statement about solutions being integers or rational numbers, the solution in post #8 looks fine to me.
However, I would simplify things a bit.
$$t \ge 10\sqrt 6 \text{ or } t \le -10\sqrt 6$$
If ##t = \pm 10\sqrt 6## then the binomial will have two repeated factors; i.e., it will have the form ##6(x - a)^2##.
Thanks, I'll tell her to read this thread.
