How Do Lines and Planes Interact in 3-D Space?
  • Thread starter Thread starter spoc21
    Lines
12 replies · 4K views
spoc21
EDIT: Sorry I made a spelling error in the title: its supposed to be Planes
Recall that there are three coordinates planes in 3-space. A line in R3 is parallel to xy-plane, but not to any of the axes. Explain what this tells you about parametric and symmetric equations in R3. Support your answer using examples.
N/A
I know that if the line is parallel to the xy plane, it will have the direction vector:
[x,y,0]
To find the parametric equation, we need to pick a fixed point on the line
(x1, y1, z1)
Parametric equation are:
(note: t is the scalar)
x =x1+xt
y =y1+yt
z =z1
I am not sure what I need to explain here, any help is much appreciated
Thanks! :smile:
N/A
[x,y,0]
It's better to represent this as, for example, <A, B, 0>.
(x1, y1, z1)
x =x1+xt
y =y1+yt
z =z1
In your parametric equations above, to find x, you need to know x1 and x, and similarly for y. Instead of x and y on the right sides, use constants, such as A and B.
Thanks! :smile:
In the parametric equations, the only obvious thing I see is that the z coordinate is constant.
Where are your symmetric equations?
N/A
[x,y,0]
It would be better to write [a,b ,0]. You use x and y for the coordinate variables.
(x1, y1, z1)
x =x1+xt
y =y1+yt
z =z1
Right there is why. The x in xt isn't the same as the x on the left. Write it as
x =x1+ at
y =y1+ bt
z =z1
You are on the right track. You have taken care of the condition that the line is parallel to the xy plane. It also says the line is not parallel to any coordinate axes. What additional facts about the parameterization does that give you?
[edit] I see mark44 answered at the same time with similar comments
Thanks Mark 44, and LCKurtz
Parametric:
x =x1+at
y =y1+bt
z =z1
Symmetric equation:
t = (x-x1)/a
t = (y - y1)/b
0 = z-z1
So basically, the z value is constant? I came to that conclusion too, but what about it not being parallel to any of the axis? I am fine with the former, but very confused with the latter..Could you please elaborate a little.
Thank you.
If the line were parallel to one of the axes, only one equation would have a term with a t parameter. For example, if the line happened to be parallel to the x-axis, its parametric equations would be:
x = x1 + at
y = y1
z = z1
x = x1 + at
y = y1
z = z1
so basically, my equations are correct, as they demonstrate that the line is not parallel to any other axis..and could you please explain what you think this result means..
Thanks!
The condition that the line not be parallel to the x or y-axis gives conditions that a and b must satisfy (or not satisfy). You need to qualify your answers with those conditions. What are they?
Thank you,
ok, so the following are the parametric equations:
x = x1
y = y1
z = z1
Symmetric equations:
x-x1
y-y1
z-z1
Is this correct?, and what exactly does it mean in this context..
Thanks LCKurtz!
spoc21 said:
Thank you,
x = x1
y = y1
z = z1
No, this is just a single point. The parametric equations are as you had them in post 4.
No, these aren't even equations.
spoc21 said:
x-x1
y-y1
z-z1
Thanks LCKurtz!
Thanks Mark 44!
what would this result mean?, other than that the z is constant.. are there any connections between this, and the other two planes?
In x= x1+ at, y= y1+ bt, z= z1, saying that the line is NOT parallel to the x and y coordinate axes just says that neither a nor b is 0.
I notice that you still have not found the "Symmetric Equations". Just solve each of the parametric equations for the parameter, t, and set them equal.
In general if x= At+ p, y= Bt+ q, z= Ct+ r, then
[tex]t= \frac{x- p}{A}= \frac{y- q}{B}= \frac{z- r}{C}[/tex]
If anyone of those coefficients is 0, just do not include that fraction. Since, here, z is a constant, the "symmetric equations" will just set a fraction in x equal to a fraction in y.
Thanks!
So, for the example, could I use the following:
Point A (1,-5,0)
Point B (3,-9,0)
Direction vector:
[3-1,-9-(-5),0]
= [2,-4,0]
So therefore the parametric equation would be:
[x,y,z] = (1,-5,0) + t[2,-4,0]
x = 1 + 2t
y = -5-4t
z = 0
Is my method correct?
Thank you :smile:
HallsofIvy, you're obviously one of the old-timers around here, but I don't understand why you don't let the OP come to that conclusion either by himself or with leading questions.
