How Do Proper Acceleration and Gravity Affect Time Dilation in Free Fall Orbits?
87 replies · 9K views
Dale said:
They are called "Christoffel symbols" (I know, it is a weird name). The lecture notes describe them in detail.
I've spotted them in the notes, but they are quite a few pages in. I have looked them up elsewhere and it is mentioned that they are used in the geometry. Do they offer a force that explains the lack of measurement of proper acceleration in an object showing coordinate acceleration though, or when the considerations of A, B, and C being at rest are compared, does only the consideration of C being at rest give a proper rotation for C in line with its coordinate rotation?
I can only also recommend to read a bit about differential geometry in Carrol's Lecture notes first. You just need Secs. 2 and 3 to answer all these questions.
Does proper acceleration appear in the notes at all, the term does not seem to be in them, and when acceleration is mentioned I am not clear that it is not referring to relative / coordinate acceleration.
I'm not sure that I understand what you need that for to learn the basic principles of pseudo-Riemannian (Lorentzian) differential geometry, but I'd define proper acceleration as
$$a^{\mu}=\frac{\mathrm{D} u^{\mu}}{\mathrm{D} \tau},$$
where
$$u^{\mu}=\frac{\mathrm{d} x^{\mu}}{\mathrm{d} \tau}$$
is the four velocity and ##\tau## the proper time (I assume you have a massive particle here; for massless particles the issue is a bit more complicated).
Written out the proper acceleration reads
$$a^{\mu} = \frac{\mathrm{d}^2 x^{\mu}}{\mathrm{d} \tau^2} + {\Gamma^{\mu}}_{\rho \sigma} \frac{\mathrm{d} x^{\rho}}{\mathrm{d} \tau} \frac{\mathrm{d} x^{\sigma}}{\mathrm{d} \tau},$$
where ##{\Gamma^{\mu}}_{\rho \sigma}## are the connection coefficients (Christoffel symbols) of spacetime.
where
Won't any change in x depend on what coordinate system (what frame of rest) you are using?
The ##x^{\mu}## are some coordinates, and all components given in my previous posting are with respect to the corresponding holonomous basis of the tangent spaces of the manifold, i.e., ##u^{\mu}## and ##a^{\mu}## are vector components with respect to the holonomous basis of the tangent space at the position of the point particle under consideration.
So if an observer was standing on the Earth and was using a coordinate system where they were considered at rest, then what would be the change in the x,y or z part of any coordinate point (at rest with respect to the observer) on the Earth over a period of time. Wouldn't only the time part of the coordinate be changing? So where would the acceleration of those points be using your equations? It seems to me that there would not be any, as they seem to represent coordinate acceleration. But (as I understand it) proper acceleration would be measured at any of those points on the Earth.
If I have misunderstood (sorry my maths is quite poor) then perhaps you could illustrate using a single coordinate ct = 0 x = 1, y = 1, z= 1 in your equations to show how it ends up with the measurable proper acceleration over 10 seconds perhaps?
Yes. Those intervening pages are important. I really think that you need to go through it. You are asking very haphazard questions because you need a systematic introduction.
Please don't try to skip ahead, but go through the material step by step.
Does proper acceleration appear in the notes at all, the term does not seem to be in them, and when acceleration is mentioned I am not clear that it is not referring to relative / coordinate acceleration?
He does not appear to use that term, but the quantity $$\frac{d^2}{d\tau^2}x^{\mu}(\tau)$$ in equation 1.102 is the proper acceleration in flat spacetime.
And the proper acceleration in curved spacetime is given by the left hand side of equation 3.47
One should note that (3.47) is only proper acceleration if ##\lambda## is normalized such that
$$g_{\mu \nu} \frac{\mathrm{d} x^{\mu}}{\mathrm{d} \lambda} \frac{\mathrm{d} x^{\nu}}{\mathrm{d} \lambda}=1.$$
The formula, i.e., the equation for a geodesic, parametrized in terms of an affine parameter ##\lambda##, is more general. You can also solve it if the tangent vector is null (world lines of massless particles or light rays in the sense of the eikonal approximation) or spacelike.
name123 said:
Consider satellites A and B, going at different velocities, in free fall orbit around a massive body C at different altitudes for a million years, then being brought together and the clocks on them compared. Presumably the bringing them together would become less significant the longer they orbited, and the amount of time dilation due to curvature would be frame of reference independent, but what about the observed velocities from the mass being orbited's perspective? If the satellites were labelled A and B and the mass C then would the clock comparison figure be correctly calculated no matter which you considered at rest?
Yes, two clocks that are in different orbits will show different amounts of elapsed time when they pass each other. You don't need to bring them together; instead you can put A into a circular orbit around C and put B into a very eccentric elliptical orbit. If you arrange things perfectly, then you can make sure that A and B pass each other with some regularity. I haven't done the calculation, but I believe that when they get back together, B will show more elapsed time than A.
As I mentioned earlier to Vanhees earlier
Could you possibly just use that equation (which would seem to show no change to the x, y, z coords) using a single coordinate (t=0, x = 1, y = 1, z = 1) at rest with the observer standing on Earth to illustrate how it shows proper acceleration?
Could you just use the equation with a single coordinate at rest with the observer on Earth to illustrate, as I mentioned in #67?
I am happy with them being brought together though, else there might be something to do with the elliptical orbit that has not been made clear. As you seemed to be able to conclude that B's clock would have gone faster, but in the bit you had quoted of what I had written, I had not mentioned which was in lower orbit, or their respective velocities. Any affects of bringing together tends to insignificant the longer A and B orbit anyway. If B's clock was in the lower orbit then time dilation due to gravity would slow B's clock relative to A's, and presumably that affect is invariant across frames of reference. So would there not just be the kinematic time dilation left, and would not A think, using the metric of A's clock, that B's clock had ticked less than would have been expected (taking gravitational time dilation into account) if it had been in A's rest frame, and B, using the metric of B's clock, think that A's clock had ticked less than would have been expected (taking gravitational time dilation into account) if A had been in B's rest frame?
To a pretty good accuracy, the elapsed time [itex]\delta \tau[/itex] on a clock in orbit is given by:
[itex]\delta \tau = (1 - \frac{GM}{c^2 r} - \frac{1}{2} \frac{v^2}{c^2}) dt[/itex]
where [itex]t[/itex] is coordinate time (using the most natural coordinate system). For a perfectly circular orbit, we have, approximately:
[itex]\frac{v^2}{c^2} = \frac{GM}{c^2 r}[/itex]
So [itex]\delta \tau = (1 - \frac{3}{2} \frac{GM}{c^2 r}) dt[/itex]
So higher orbits correspond to smaller [itex]\frac{1}{r}[/itex], which correspond to more elapsed time. You can think of the factor of [itex]\frac{3}{2}[/itex] as being a sum of a factor of [itex]1[/itex] due to gravitational time dilation and a factor of [itex]\frac{1}{2}[/itex] due to velocity-dependent time dilation. I don't know if that answers the question, or not.
name123 said:
As I mentioned earlier to Vanhees earlierCould you possibly just use that equation (which would seem to show no change to the x, y, z coords) using a single coordinate (t=0, x = 1, y = 1, z = 1) at rest with the observer standing on Earth to illustrate how it shows proper acceleration?
I could, but it would be more productive if you did it yourself. The metric and the Christoffel symbols for a Schwarzschild spacetime are given in the text.
Would you mind answering the question that I gave?
Also with the equation you gave, is GM the gravitational mass? And r the radius from the mass? Also I did not understand the step you made where you said that for a perfectly circular orbit you have approximately
Because would that not depend on the velocity they were orbiting at relative to the gravitational mass being orbited. With that equality the equation could be written as
[itex]\delta \tau = (1 - \frac{3}{2}\frac{v^2}{c^2}) dt[/itex]
But consider where the mass was large, and the velocity of the orbiting object low. Where is the gravitational mass taken into account in the version I just gave, and where is the velocity taken into account in the version you gave?
Could you perhaps give a simple worked example, because my maths is quite basic, I have to often look up the symbols, and I am not currently clear how the equation you gave works.
I think it would be easier for me (and other readers at this basic level) if you just gave the simple worked example. Lots of people I am sure find worked examples an aid in understanding. And I cannot understand how with the equation you gave there would be any change in the x, y, z coordinates in the example I gave. Regarding working through it myself, I am not clear on what equation 1.13 means for example. There are two new symbols introduced, and I am not clear what they mean. Is T and exponent, or a superscript? Is η another matrix?
Even in 1.1 I am not clear why it is not written as
[itex]{(∆s)^ 2} = {(∆x)^ 2} + {(∆y)^ 2}[/itex]
Reading through myself I have to try to work out what the symbols are referring to. A simple worked example makes it clear, and then I (and others) can use the equations to work out other things ourselves, once we are shown how they are used.
That's not an orbiting object. That's a falling object.
I am not sure what "that" refers to, something in the equation, or something in the example I gave. In the example I gave the satellites are in free fall orbiting a mass.
If they're moving slowly near a large mass, they're not orbiting, they're falling. If you want to consider objects in circular orbits then they have to be moving at orbital speed - the formula that Steven quoted.
Well slow is a pretty relative term (given the speed of light), and they can be in free fall and orbiting can they not? Can you explain how the orbital speed is worked out using that equation, and perhaps explain how it relates to this question:
Ibix said:
You could always look up orbital velocity on wikipedia. The derivation is about two lines long...
I didn't see the relevance of orbital velocity to the question (which Steven was replying to), (I thought his equation was to do with elapsed time on a clock):
Could you explain its relevance, and if not perhaps give your own answer?
If you don't understand why the velocity is relevant you need to read stevendarryl's last sentence. If you don't understand why orbital velocity is relevant you need to read your own posts where you talk about the satellites being in orbit.
If you do both those things you can answer your own question from Steven's post #76.
I was not saying I did not know why the velocity the satellite was orbiting was relevant (I assumed it would be involved in the kinematic time dilation calculation). I just did not understand why the minimum velocity it could orbit before it would no longer be in free fall orbit, but just falling towards the mass was relevant. It could have just been assumed it was above that.
I explained in post #78 why I did not understand Steven's answer, and you seemed to bring up the minimum velocity it could orbit before it would free fall into the mass, which I did not understand the relevance of. The question below
Is simply a "yes" or "no" answer, and it has been asked on this thread before (it can be seen in a different form in #1). Could you possibly give a "yes" or "no" response to it, and perhaps some explanation if "no" (given that the kinematic time dilation would as I understand it be like that in flat spacetime)?
