How Do Time Dilation and Space Expansion Affect Gravitational Redshift?
70 replies · 16K views · last reply
mysearch
Based on the quote below and the link to Wikipedia, I believe the implication is that gravitational redshift will occur when a photon climbs out of the gravity well, while blueshift will occur when falling into the gravity well. However, I am trying to clarify whether both time dilation and space expansion have to be taken into consideration when an observer measures the frequency or wavelength of a photon at different positions in the gravity well.
"[URL
Gravitational Redshift:
When a photon is emitted by a given process, for example a transition of an electron from one specific energy level to another specific level in a specific element the photon is emitted at an intrinsic frequency irrespective of where the element is located in the gravity well. Say the photon is moving upwards, then measurements made further up, by clocks with faster coordinate time make it appear as if the frequency of the photon is getting slower but the coordinate frequency (and energy) remains constant and it is the wavelength (and coordinate speed of light) that is increasing. You could view the increasing wavelength as a gravitational length contraction effect. Local observers progressively further up the gravity well see the frequency as slowing down and so to them the photon appears to be losing energy and the wavelength increasing which is consistent with the local speed of light being constant for any observer. Depends on your point of view.
Not sure as to what is `intrinsic` to frequency as I would have thought frequency is subjective to an observer?
If the observer is collocated with the photon source within a gravity well, does local time define the frequency and therefore the energy E=hf?
To a distant observer, far from the gravity well, time ticks faster, so would the photon, when arriving, appear to have a lower frequency and energy?
However, along the way, space would have contracted as space is said to expand in the direction of increasing gravity. Therefore, would this effect cause the wavelength to shorten?
If [tex]c=f\lambda[/tex] and [c] is constant, would the shorten wavelength not cause frequency to increase and cancel the effect of time dilation?​
Clearly theory suggests that this is not the case, but then implies there is a different perception of the energy associated with the photon. Therefore, would welcome any clarification of these issues.
I think it would be the other way round. The wavelength would appear longer.
For light, frequency and wavelength are not independent, and so you can regard a red-shift either as an increase in wave length or a reduction in frequency.
Red-shifted light will deliver less energy. This is not a surprise because energy is not relativistically invariant.
Have you come across the Pound-Rebka experiment ? I guess you have since you quote Prof. Wiki.
en.wikipedia.org/wiki/Pound-Rebka_experiment
All that is neccesary is that time dilation is present, i.e, that g00 is a function of position. g00 depending on position does not imply that space is altered.
Pete
Mentz114: Thanks for the comments. I have attached a response against each below:
As you approach a large mass [M] doesn’t time tick more slowly and the radial distance [r] expand? If so, I was assuming a photon traveling away from [M] would perceive a contraction in unit space and therefore the wavelength would shorten, although this doesn’t seem to be the case.
I agree based on the assumption that [tex]c=f\lambda[/tex] and [c] is constant. This was why I was asking about the combined effects of time dilation and space contraction when the photon travels away from [M]. Pete in post #3 appears to be implying that time dilation alone causes the gravitational shift, which suggests that the frequency is fixed at N cycles per second, when initially emitted, but as the photon moves out of the gravity well, N cycles per second appears lower because time is ticking faster. What I didn’t understand was why the radial contraction per unit length didn’t not shorten the wavelength, i.e. increase frequency, and therefore cancel the effects of time dilation. Clearly, experiments suggest this is not the case, but I couldn’t really explain to myself why both time and space effects didn’t apply.
How does the conservation of energy get resolved if the photon appears to lose energy? In classical physics a physical mass can lose kinetic energy, but its total energy is conserved in its potential energy.
Actually I hadn’t, so thanks for the reference.
Pmb_phy/Pete: Thanks for the feedback, unfortunately I not that familiar with the meaning of [tex]g_{00}[/tex] notation. As I have tried to explain above, I don’t really understand why the changes in both time and space don’t cancel out. Most texts seem to simply quote the net effect without reference to the underlying physical cause, e.g.
In physics, light of a certain wavelength originating from a source placed in a region of stronger gravitational field will be found to be of longer wavelength when received by an observer in a region of weaker gravitational field.
You seem to suggest that time dilation causes the photon to have a lower frequency, i.e. longer wavelength, and that the effects of radial space contracting do not cause the wavelength to shorten, i.e. higher frequency.
The speed of light would have to change to accommodate a lower frequency with a shorter wavelength.
Pete is right, only [tex]g(r)_{00}[/tex] is used to calculate gravitational redshift. The radial component is irrelevant. This must be in the nature of light. A mass thrown up can lose velocity, light cannot.
Request for confirmation
Pete is right, only [tex]g_{00}[/tex] is used to calculate gravitational redshift. The radial component is irrelevant. This must be in the nature of light. A mass thrown up can lose velocity, light cannot.
As indicated earlier I have not really studied the vector-tensor maths associated with [tex]g_{00}[/tex], however looking around on the web I found one reference that suggested that [tex]g_{00}[/tex] is associated with time dilation where:
[tex]d\tau = \sqrt{g_{00}} dt[/tex]
This suggests that in the context of gravity only, i.e. no relative velocity, that [tex]g_{00}[/tex] might be related to the relativity factor [tex][\gamma][/tex], e.g.
[tex]g_{00} = 1-Rs/r[/tex]??
I mention this simply because I am interested in trying to resolved some physical interpretation that explains the effects under discussion. Therefore, I wanted to try to expand on your other comment:
While possibly over simplistic, I have described relativity in terms of its separate effects on space and time. Special relativity describes the effect of velocity, which remains invariant because time dilation and space contraction are equal and maintain constant velocity in both frames of reference. General relativity incorporates the additional effect of gravity, which also leads to time dilation, although space expands in the radial direction. As such, velocity cannot be invariant. As such, velocity is simply a concept of distance traveled in a given time, i.e. v=d/t, and this is all [tex]c=f\lambda[/tex] would appear to be saying. However, the assumption that v=d/t may be the issue that has misled me, because in the context of wave propagation, the frequency [f] is defined by the energy [E=hf] and the propagation velocity [v=c] is defined by the media, i.e. vacuum permittivity & permeability. As such, it might be more accurate to say that wavelength results from [tex]\lambda=c/f[/tex].
I not sure whether this is an appropriate physical interpretation, but it suggests that the wavelength of a photon, as measured by a distant observer, can only result from changes in [c] and [f]. If [c] is a constant in each frame of reference, then only the time dilation effects on [f] lead to the gravitational redshift observed by experiments. As such, the radial contraction that occurs when moving out of the gravity well would not directly affect wavelength as I had originally assumed. Is this a valid conclusion?
The frequency the distant observer measures depends on the curvature differential between the event of emission and absorption. In other words, f does not change in a gravitational field but the measuring apparatus changes in such a field. A measured blue shifted photon is really a photon observed by a red shifted apparatus.
Response to post #7
I accept that we could describe the gravitational redshift in terms of a differential curvature of spacetime. However, I would have thought this curvature would still correspond to the space and time effects relative to 2 positions in the gravity well. As far as I was aware, time dilation is a real effect against which we then subsequently define frequency. In this context, the real change in the perception of time appears to be more fundamental than the knock-on effects on the measuring apparatus. This is not being forwarded as a statement fact, simply the assumptions to which I was working
mysearch,
going back to an earlier remark,
Well, why should they ?
The 'cause' is the difference in gravitational field strength. This is measured by g_00. Actually it's a bit more subtle but without a full understanding of curved space, hard to explain.
This agrees with experiment. If you're looking for an explanation in terms of underlying structures, then you're into uncharted territory.
In post #6 you're making a mistake by trying to make analogies between the gamma of SR and gravitational effects. SR is formulated in the Minkowski space-time, GR extends this to a general spacetime where curved worldlines can be caused by geometry alone ( gravity) whereas in SR, a curved worldline always implies an external force. The conclusions of SR do not carry over to GR in a simple way.
One more thing. Suppose we have observers A and B, and A sends some light to B who measures the frequency. It is not possible to say whether any difference observed is a result of an 'intrinsic' change in the light or a difference in the measuring apparatus, caused by transporting it to another place. No experiment can distinguish these situations.
Response to #9
The 'cause' is the difference in gravitational field strength. This is measured by g_00. Actually it's a bit more subtle but without a full understanding of curved space, hard to explain. This agrees with experiment. If you're looking for an explanation in terms of underlying structures, then you're into uncharted territory.
A fully accept that I am on a learning curve and for those who have studied this subject in detail, it must be difficult to simplify some concepts to basic principles. It is true that I was hoping to rationalise, at least to myself, the basic effects of relativity in terms of time dilation and space expansion/contraction.
This wasn’t my intention; I was simple reproducing an inference in
https://www.physicsforums.com/archive/index.php/t-125057.html
This is a very good point and one also argued in post #7. However, I thought it was an axiom of relativity that everything is relative. As such, it seems to be a philosophical point as to whether the photon changes in transit or the observer/measuring apparatus changes with respect to the photon - see rationale below. From the perspective of the receiving observer, the photon has less energy than a photon from a comparable source emitted locally.
I accept that my attempt to rationalise an explanation in #6 may appear naïve, but it appeared to help clarify some important aspects of gravitational redshift. First, [tex]\lambda=c/f[/tex] seem to help explain why only time dilation affected frequency. Equally, it appears to provide a practical interpretation of the energy lost associated with a photon moving away from a gravitational mass. Based on the conservation of energy, this lost energy has to be accounted in some other form. In classical physics, the energy associated with a mass [m] can be defined in terms of its kinetic (Ek) and potential (Ep) energy that in-turn is linked to velocity and gravitation:
[tex]Total Energy (Et) = Ek + Ep =1/2mv^2 + (-GMm/r)[/tex]
At face value, this is more difficult for a photon as it is said to have no rest mass [m0]. However, if we link Planck’s equation (E=hf) with Einstein’s equation [tex](E=mc^2)[/tex], it suggests that photons have kinetic mass [tex](mk= hf/c^2)[/tex]. Now if time dilation causes frequency [f] to reduce, in the case of an outgoing photon, it also causes the photon to lose energy. However, the photon now has more potential to gain energy, i.e. increase in frequency, by falling back to a lower position in the gravity well. As such, mass and frequency act as equivalent concepts against which the total energy can be accounted in any frame of reference. It just seems easier to me to assign the changes to the photon coming into the observers frame of reference rather than assume the photon is unchanged, which then requires entire frame of reference to be `recalibrated` to some other arbitrary, but remote frame of reference.
The only problem I have with the localise perspective is that I seems to suggest that the energy of a photon falling into the event horizon would be infinitely blueshifted, implying infinite energy. Again, I am not making statement of fact here, simply outlining some assumptions on which I am attempting to learning more about this subject, so have much appreciated the help and feedback.
Consider the following example. There are 3 observers (A,B,C) at various heights in a gravity well. According to an observer at infinity the gravitational gamma factor [tex]g= 1/ \sqrt{1-Rs/R}[/tex] is 8, 4 and 2 for A,B and C respectively with A being the deepest in the well. Say a photon is emitted with a frequency of 1 and wavelength of 1 at location A as measured by A. The measurements of (frequency, wavelength, speed of light) made by the observer (D) at infinity at locations A, B, C, and D would be:
A' = (1/8, 1/8, 1/64)
B' = (1/8, 1/2, 1/32)
C' = (1/8, 2, 1/4)
D' = (1/8, 8, 1)
and the local measurements would be:
A = (1, 1, 1)
B = (1/2, 2, 1)
C = (1/4, 4, 1)
D = (1/8, 8, 1)
In other words the coordinate measurements according to the observer at infinity indicate the frequency remains constant and wavelength get longer by a factor of gamma squared and the coordinate speed of light also increases by a factor of gamma squared as the photon climbs out the well. To the observer at infinity the energy of the photon is constant.
To the local observers each observer measures a lower frequency and a longer wavelength locally than the observers further down and the same value for the local speed of light c.
That is my analysis that is consistent with the Schwarzschild metric. As with special relativity, it is not possible to state which observers point of view is the more "fundemental".
The radial distance effect is the other way round. Approaching a large mass, clocks ticks more slowly by gamma and rulers contract by gamma and the coordinate speed of light slows down by gamma squared, but the combined effects result in the local speed of light being constant for all observers.
Kev, thanks for the comments and especially the analysis in #11, as it is always helpful to look at the issues in terms of a practical example. I was in the process of working through your example, but then saw post #12, which has thrown up some doubts in my mind.
I accept I am no expert, but I was pretty sure that the radial distance expands under gravity as [r] approaches [Rs], i.e. its the opposite to special relativity, in which length contracts as [v->c]. This is why the (1-Rs/r) is the denominator in the [dr] term in the Schwarzschild metric.
It will probably be tomorrow before I can respond properly. Thanks.
Which of these statements do you disagree with?
a) Gravitational time dilation slows clocks by the gamma factor.
b) Coordinate speed of light slows by gamma squared.
c) Local speed of light is always c.
If you agree with statements a,b and c you have to come to the conclusion that length (rulers) have to contract by gamma aproaching a massive body.
The confusion may be the difference between "radial distance" for which there is no simple conversion factor and the length of local almost infinitesimal ruler.
Response to Kev #11, 12 & 14
Hi Kev
Saw your last post, so will start with the last point you raised:
This could well be the case, but I will try to explain my `frame of reference` then you can tell me if we are talking at cross-purposes. I have no problem with bullets (a) or (c), so maybe the confusion is with respect to bullet (b). I am only providing the following simplified form of the Schwarzschild metric as a reference:
[tex]c^2 d\tau^2=c^2\left(1-Rs/r\right)dt^2 - \frac{dr^2}{\left(1-Rs/r\right) }[/tex]
Without resorting to any derivation, the placement of the (1-Rs/r) terms suggests that the relativistic effects, under gravity, works in different direction for time and space. Also the equations for proper time [tex][d\tau][/tex] and proper distance [ds], given in various sources, appears to support this suggestion:
[tex]d\tau = \sqrt{\left(1-Rs/r\right)}dt[/tex]
[tex]ds = \frac {dr}{\sqrt{\left(1-Rs/r\right)}}[/tex]
According to the Schwarzschild metric, the proper radial distance, the actual distance measured by an observer at rest at radius r, between two spheres separated by an interval dr of circumferential radius r is [itex]\left(1-Rs/r\right)^{-1/2}dr[/itex], which is larger than the radial interval dr expected in a flat, Euclidean geometry
http://casa.colorado.edu/~ajsh/schwp.html
Before continuing, let me just clarify a few assumptions. I am assuming that the local observer/apparatus measures 1 second per second and 1 metre per metre. Therefore, the time and space effects are all relative to a distant observer, e.g. (D) observing (A). I am also assuming that both the local and distant observers are stationary, so no velocity effects. What I not too sure about is that if the local observer (A), in curved space around a black hole, measures the circumference, unaffected by gravity, and then divides by [tex]2\pi[/tex], would the radius calculated and the actual radius observed differ and allow the local observer to recognise he was in curved space?
Anyway, returning to your example, albeit in a slight different context, but using your values. The distant observer (D) is `conceptually` watching a `hypothetical` experiment in (A). The experiment consists of a photon being fired between 2 points, aligned on the radial axis, separated by 1 light-second. As the photon is fired, the source flashes a light, as does the receiver when the photon is received. In the context of (A), the flashes are separated by 1 second, as the local speed of light is always [c].
However, following your example, time in (D) is ticking 8x faster than (A) and therefore we might conclude the observed frequency was 1/8 as it is inversely proportional to time. Again, this aligns to your example. However, this would imply that the time, as measured by (D), between the flashes was 8 seconds. Of course, if we go with the previous assumption about radial space expanding on approaching [Rs], then observer [D] would measure the distance between source and receiver as 8 light-seconds, which would imply the photon was still traveling at [c]. I fully accept this logic may be flawed, but would like to understand why.
Just a few other points I want to highlight. When I originally raised the question about gravitational redshift, based on the assumptions above, it was because I couldn’t resolve why the gravitational effects on time and space didn’t cancel out. If time slows approaching [Rs], then it was logical to assume that the emitted frequency of a photon would be lower, in-line with experimental observation. However, if radial space contracts as the photon travels from (A) out to (D), then I initially assumed this would affect the wavelength, which in-turn would affect the frequency based on [tex]c=f\lambda[/tex]. However, I thought this might be resolved based on the fact that the physics of wave propagation only states the frequency [f] is defined by the energy [E=hf], whereas the propagation velocity [v=c] is defined by the media of propagation, i.e. vacuum permittivity and permability. As such, the wavelength [tex]\lambda=c/f[/tex] is determined by [c] and [f]. If [c] is constant in all local frames of reference, then the gravitational redshift would correspond to experiment and align to the effects of time dilation only. Again, I fully accept this might all be unsubstantiated speculation on my part, but my goal was to try to provide some physical interpretation of the relativistic effects. Many Thanks
Hi mysarch,
there is quite a lot in your post so I will address the first few points only for now and come back to the rest as time allows.
mysearch said:
... I have no problem with bullets (a) or (c), so maybe the confusion is with respect to bullet (b). I am only providing the following simplified form of the Schwarzschild metric as a reference:
For light dtau is zero. So we can say for a falling photon:
[tex]0 = c^2\left(1-Rs/r\right)dt^2 - \frac{dr^2}{\left(1-Rs/r\right) }[/tex]
Rearrange and simplify:
[tex]\frac{dr^2}{\left(1-Rs/r\right) } = c^2\left(1-Rs/r\right)dt^2[/tex]
[tex]\frac{dr^2}{dt^2} = c^2 \left(1-Rs/r\right)^2[/tex]
[tex]\frac{dr}{dt} = c \left(1-Rs/r\right)[/tex]
.. proving my assertion in bullet point b that the vertical coordinate speed of a falling photon in a gravitational field (as measured by an observer at infinity) is inversely proportional to the gravitational gamma factor squared.
the transformation for time and space in SR are in "different directions" too. Proper time is less than the time measured in the primed frame and proper length is greater than the length measured in the primed frame.
[tex]dt' = dt \sqrt{\left(1-v^2/c^2)}[/tex]
[tex]dx' = \frac {dx}{\sqrt{\left(1-v^2/c^2)}}[/tex]
Response to Kev #16
Realise you will need to consider my comments in #15. However, wanted to raise some comments against your initial response. I agree with your basic derivation of the observed photon velocity from (D), although I added the [tex]\pm[/tex] to reflect the quadratic solution:
Photon: [tex]\frac{dr}{dt} = \pm c \left(1-Rs/r\right)[/tex]
Simply for reference, here are some other solutions, starting with the observed free-fall velocity from (D):
Free-Fall Mass: [tex]\frac{dr}{dt} = c \left(1-Rs/r\right) \sqrt{Rs/r}[/tex]
The implication of this equation is that both velocities perceived by (D) collapse to zero at [Rs], presumably corresponding to time slowing to a halt at [Rs]. Of course, solutions with respect to proper time [tex][d\tau][/tex] suggest otherwise:
Photon: [tex]\frac{dr}{d\tau} = -c \sqrt{Rs/r} \pm c[/tex]
Free-Fall Mass: [tex]\frac{dr}{d\tau} = -c \sqrt{Rs/r}[/tex]
Now the speed of light [c] appears to maintain its value [c] with respect to the local observer (A), even when (A) is free-falling at [c]. To be honest I have never been able to resolve both outcomes from the Schwarzschild metric. At one level, time dilation with respect to (D) appears to be supported by experiment, but leads to a frozen star rather than a black hole. While the other solution, even taking into account arguments concerning coordinate singularity, seems to proceed through the event horizon but cannot seem to relate time back to (D). However, as far as I know, a series of local measurements in (A), (B) and (C) would all measure [c] as [c] and suggest the photon frequency was affected by the initial time dilation.
Sorry, I didn’t understand where your last 2 equations come from, as they do not seem to correspond to the Lorentz transforms:
[tex]t' = \gamma \left( t - \frac{v x}{c^{2}} \right)\rightarrow \gamma (t)[/tex] when x=0
[tex]x' = \gamma \left( x - v t \right) \rightarrow \gamma (x)[/tex] when t=0
Apologises for raising so many issues, but I would be interested how your position explains gravitational redshift. Again, many thanks.
One difficulty with using the Schwarzschild solution at exactly r=R_s is that no physical observer could remain stationary at the event horizon so the equztion is not physical at that exact point. However, there are other issues. In another thread we showed that the interior Schwarzschild solution shows that time reverses at certain coordinates below the Schwarzschild radius even before a black hole is fully formed (collapsed to a singularity) suggesting that physical process (time related) prevents a singularity forming and all the mass accumulates in the thin shell just outside the event horizon. This is consistent with the frozen star viewpoint. It is also consistent with the Hawking entropy formula that shows the entropy is proportional to the surface area of the black hole event horizon. Charge and mass accumulated on such a shell would appear to anyone outside the shell to be from a point source just as the gravitational effect of the Earth above the surface is mathematically the same as having all the mass located at the centre even though we know it is not really all located there.
That is exactly what I stated the local observers at A, B and C would measure. Is there measurement the only valid viewpoint? I think not. For example the local observers in Special Relativity can not measure length contraction and time dilation of there own rulers and clocks but that does not mean length contraction and time dilation do not exist. Similarly, the two observers with relative velocity each measure the others clock to ticking slower than their own clock and we know that each has a valid viewpoint even thought they seem contradictory.
x is the coordinate of a point. Length would be measured as the difference of two coordinates such as x2-x1.
For length:
[tex](x_2' - x_1')/\gamma = \left( x_2 - v t \right) \right - \left( x_1 - v t \right)[/tex]
[tex](x_2' - x_1')/\gamma = \left( x_2 - x_1 \right)[/tex]
[tex](x_2' - x_1') = \left( x_2 - x_1 \right)\gamma[/tex]
For time:
[tex](t_2' -t_1') = \gamma \left( t_2 - \frac{v x_2}{c^{2}}\right) -\gamma \left( t_1 - \frac{v x_1}{c^{2}}\right)[/tex]
Since x2 and x1 are not the same for non zero t we use the reverse transformation:
[tex]t = \gamma \left( t' + \frac{v x}{c^{2}} \right)[/tex]
[tex](t_2 -t_1) = \gamma \left( t_2' + \frac{v x_2'}{c^{2}}\right) -\gamma \left( t_1' + \frac{v x_1'}{c^{2}}\right)[/tex]
Now we can say x2' = x1' for the clock in the moving frame and it follows:
[tex](t_2 -t_1) = \gamma \left( t_2' - t_1' \right)[/tex]
[tex](t_2' -t_1') = \left( t_2 - t_1 \right)/\gamma[/tex]
Well, my position is that there is no single explanation. From the point of view of local observers frequency of the photon changes due to time dilation and the speed of light is constant. From the point of view of an observer at infinity (or at any constant non local location) the frequency remains constant, the wavelength is stretched as the photon rises and the speed of light increases. Both points of view are equally valid.
I have a different question related to Gravitational Redshift.
We know that the universe is loosing mass as the stars produce photons. We also know that photons are red shifted when moving away from a star, and blue shifted when moving to a star.
Let’s do a little thought experiment. If a photon leaves the sun at year zero and is red shifted as it leaves, and then travels a 100 million years and is reflected back; and then travels another 100 million years. When the same photon that left 200 million years returns to the sun, at what wavelength is it at?
That sounds contrived, but I’m trying to ask, how is mass lost by a star, related to red shifting of same photon created by the star, when reflected and lack of blue shifting when returning to the star. o:)
As the solar mass decreases, does that mean all reflected photons back to that star system have to return red shifted?
Anyone have the wavelength math for a one percent mass decrease and 200 million year round trip?
Hi sirxerp,
ignoring cosmological expansion the photon will red shift on its way out and blue shift on the way back so that it has exactly the same wavelength when it returns as when it it left. I am not sure what you are getting at here unless you are enquiring about the mathematical equations for what happens when cosmological expansion of the universe, during the travel time, is taken into account? In that case the photon will return redshifted.
kev said:
Hi sirxerp,
Sir, you are assuming the gravity well has the same mass the whole time.
Do you think the sun has the same mass as it did yesterday?
How about a 200 million years ago?
A returning photon from the past would be affected by a slightly a different mass, hence a different blue shift as it returned, correct?
OK, I see your angle now and basically agree with you. On its way out the photon would be on the surface of an expanding light sphere and the mass-energy enclosed within that expanding sphere would be constant on the way out because all the other photons leaving the star would still contribute to the gravitational mass of the star. On the way back the situation changes and the mass-energy enclosed within the radius of the returning photon will be continually decreasing and so yes, the photon should be blue shifted to a lesser extent than it was redshifted on the way out.
Response to Kev #18
I tend to agree, but I also think we still have a lot of gaps in our knowledge.
I have included links to some Internet articles that may be of interest:
http://www.physorg.com/news101560368.html
http://arstechnica.com/news.ars/post...s-paradox.html
The speculation of some of these articles leads to the idea that matter cannot exist at the event horizon and reduces to a more fundamental quantum/wave structure. I previously raised some questions about the implication of the Schwarzschild metric in another in another thread, although I am not sure that any satisfactory conclusion was reached:
https://www.physicsforums.com/showthread.php?t=225250
I have taken this quote out of sequence because I have a different perspective, which I would like to table before making any other comments. In terms of special relativity, I am not aware of any `twin paradox` that cannot be resolved. However, I believe this statement may lead to cases where an apparent relative velocity would not lead to any time dilation between the observers.
That is exactly what I stated the local observers at A, B and C would measure. Is their measurement the only valid viewpoint? I think not.
Yes, we are in agreement with respect to the local observer. However, the question of validity appears more difficult, at least, to me. As a broad generalisation, I don’t like paradoxes. It tends to say to me that we don’t understand everything that’s going on. In part, this is why I like to look for physical interpretation that supports mathematical conjecture. However, as outlined in post #17 and the thread above, resolving the apparent disparity between what is perceived by the distant (D) and local (A) observers does appear to be problematic. I guess I can sum up my reservation by saying that I can accept the relative nature of time, but not a contradictory nature. Therefore, if (D) sees time stop in (A), I don't how you can simply run time on in (A) disregarding the implications in (D)
For example the local observers in Special Relativity cannot measure length contraction and time dilation of there own rulers and clocks but that does not mean length contraction and time dilation do not exist.
Yes, I agree, but wanted to try and clarify a previous point. If (A) measures the circumference around the black hole, which is unaffected by space expansion, and then divides by [tex]2\pi[/tex], the implication is that the actual radius is larger due to the curvature of space at his position. So:
o If his ruler expands when orientated in the radial direction, (A) could never measure the expansion directly?
o If no, how do we define the radius [r] for any observer?
o How do you interpret the formal definition of a black hole as a region of spacetime that is not in the causal past of the infinite future?
I didn’t want to inject another derivation into this post, but it appears that you are presenting a derivation that contradicts the standard Lorentz transforms. Am I misinterpreting what you are actually saying?
http://en.wikipedia.org/wiki/Lorentz_transformation
While we agree on the local interpretation (A), as defined by the table in #11, which is verified by experiment, I still have difficulty with your interpretation of the distant perspective (D). At one level, we only have 1 equation we are trying to balance, i.e. [tex]c=f\lambda[/tex]. Your other table in #11 does this by changing [c] and [tex]\lambda[/tex], while my interpretation changes [f] based on the observed time dilation between (D) and (A, B & C). Of course, in practice, (D) cannot observe anything in (A) until photons emitted from (A) arrive at (D), which we have agreed will be redshifted to a lower frequency, but with velocity equal to [c]. I gave an example in #15, which suggested that conceptually the observed value of [c] would be [c] because the observe time to travel 1 light-second increases, but so does the radial distance. I also think the argument about the correlation between frequency-energy and wavelength-media to be more logical, but this doesn’t mean that it is.
As always, appreciate the injection of new ideas.
General Response to #18-#21
In #19, sirzerp asked:
We might wish to start with the general shift equation:
[tex]z = \frac{GM}{rc^2}[/tex]
My initial assumption is that given the outbound photon is traveling at the speed of light [c], any change in the mass/gravity in the first 100 million years would never catch up to the photon. Of course, the problem would be more complex on the way back. However, the general conclusion would seem to be that the photon would be subject to less blueshift in the second 100 million years that the initial redshift.
However, maybe this problem would be more meaningful from an energy perspective. While the inference appears to be that the photon losses energy, I believe the conservation of energy, i.e. total energy equals kinetic + potential, would be maintained. Sorry if I have missed the point of the question.
Delta Mass Shifts
Well, let's say you live in a low mass solar system (yellow dwarf) and you move to a high mass solar system (blue giant), then the universe is going to look a little more blue-shifted that what you were used to.
If you move from a high mass solar system to a low mass solar system, then the universe is going to look a little more red-shifted than it used to.
If you live in a solar system that is gaining mass over time, then each day the universe is becoming a little more bluer each day from your viewpoint.
If you live in a solar system that is losing mass over time, then each day the universe is becoming a little more redder each day.
Here is the surprising part. If you send a active radar ping from your solar system to another solar system and if your solar system is losing mass over time, then your return pong is red-shifted!
Think of the trip, an outgoing red shift (R1) and then an incoming blue shift (B2) when it arrives at the second solar system; and then a reflection, and then an outgoing red shift (R2) and finally an incoming blue shift (B1).
First thing as the mass changes over time, notice that R1>B1 and B2>R2 so the affect should cancel right?
I don’t think so because B2 and R2 are adjacent in time. R1 and B1 are not adjacent in time. Many millions of years could have passed between when the ping when out and the pong came back.
The mass change in the R1 & B1 events is most likely larger than B2 & R2 events do the inverse square nature of gravity, and the amount of time between incoming and outgoing.
On the energy side of things, it isn’t that the photon energy is changing; it is that time-space slope has changed at your location.
It’s like riding your bike to the top of a hill, with a road crew working on the road behind you.
Your return trip has a little less acceleration because of the slope of the hill being changed during your ride. o:)
Let me guess where this is going :-p
If we have two galaxies that are a fixed distance apart, then over time, the red shift due to loss of mass from the galaxies gives the appearance that the galaxies are moving apart and the apparent (accelerating) expansion of the universe that we observe may just be an illusion?
Without doing the calculation I guess the effect you describe is small and not sufficient to account for all the redshift we observe, but your observation is not without merit. Another difficulty is that we would require some mysterious force to counter the force of gravity in order that the galaxies remain a fixed distance apart. In fact einstein did just that, and called his mysterious force the cosmological constant, but later withdrew it. We can not rule out a mysterious force to keep the galaxies a fixed distance apart as cosmologists have no difficulty accepting a mysterious anti-gravitational force is accelerating the expansion of the universe. Without knowing the exact magnitude of the effect you describe, I can not give a definitive answer. There are some clever people here on this forum that probably are capable of doing the calculations :wink:
The derivations I presented were based on the ones shown here http://hyperphysics.phy-astr.gsu.edu/Hbase/relativ/tdil.html#c1 and here http://hyperphysics.phy-astr.gsu.edu/Hbase/relativ/ltrans.html#c2
I will come back to the rest of your post one bite at a time to avoid indegestion :P
General Response to #25/26
We seem to have got diverted from the original question, but its throws up some interesting thoughts that are associated with one further question I had. However, to briefly respond to Sirzerp example, it might worth getting the size of the shift factor into some perspective using the equation:
[tex]z = \frac{1}{\sqrt{1-Rs/r}}-1[/tex]
Please double check the calculation, but it seems that a photon falling into the surface of our sun (yellow dwarf) would only have a value of z=2.13E-6. On the assumption that our blue giant was 10x larger, it would have a value of z=2.13E-4 at its surface, because both radius are much greater than the Schwarzschild radius [Rs]. These figures are absolute shifts, whereas the example would only incur at differential shift between the two systems. Of course, the z-shift would be much less at a safe Earth orbit. So the implication is that the universe wouldn’t actually look that different, but I understand this was not the main point being raised.
However, to turn the question back to the original thread, it would seem relevant to ask what the blueshift-energy implies to an observer very close to an event horizon of a black hole? At r=3Rs, the shift would correspond to a 22% increase in [z], which I am assuming would translate to a 22% increase in frequency and energy. This would increase to 73% at the photonsphere (r=1.5Rs) and ultimately to infinity at r=Rs. However, I would question this implication and would like to hear if there is an alternative explanation.
P.S. Kev, please take your time and avoid indigestion by all means:smile:
Hi mysearch,
I hope we are now at the point that we agree with my statement in post #14:
The following list is a comparison of kinetic versus gravitational time dilation and length contraction of a single clock and ruler:
Transverse kinetic time dilation: t' = t*y
Horizontal gravitational time dilation t' = t*g
Transverse kinetic length contraction: x' = x
Horizontal gravitational length contraction: x' = x
Parallel kinetic time dilation: t' = t*y
Vertical gravitational time dilation t' = t*g
Parallel kinetic length contraction: x' = x/y
Vertical gravitational length contraction: x' = x/g
where y and g are the usual kinetic and gravitational gamma factors and the unprimed variables are proper times and lengths of measuring devices. The very nice correspondence between gravitational and kinetic relativistic effects is obvious. Do you agree with above list?
In another thread of yours https://www.physicsforums.com/showthread.php?t=227410 you stated:
o As velocity [v] approaches the speed of light [c], time slows and length contracts in the direction of motion, at least, with respect to a `stationary` observer.
o On approaching a gravitational mass [M], time slows and length expands in the direction of gravitational pull, as a function of radius [r], at least, with respect to a `distant` observer.
which indicates you do not agree with my list (at that time).
Your statement would be more accurate stated as :
o As velocity [v] approaches the speed of light [c], clock slow and rulers contract in the direction of motion, at least, with respect to a `stationary` observer.
o On approaching a gravitational mass [M], clocks slow and rulers contract in the direction of gravitational pull, as a function of radius [r], at least, with respect to a `distant` observer.
Do you agree?
Jorrie and I were of the opinion that the radius calculated by a local observer by measuring circumference would agree with radius measured by the observer at infinity. The localy measured orbital velocity would be less by gamma according to the infinity observer but the difference in clock rates between the local and infinity observer ensures they get the same result for radius. This is also corresponds with there being no horizontal length contraction in my list.
mysearch said:
... If (A) measures the circumference around the black hole, which is unaffected by space expansion, and then divides by [tex]2\pi[/tex], the implication is that the actual radius is larger due to the curvature of space at his position. So:
Yes, the local observer can never measure the change in the proper length of his ruler. I prefer to think that the observer at infinity sees the ruler as length contracted when orientated vertically. The length contraction and time dilation of the local observer's rulers and clocks ensures he always measures the local speed of light to be constant (c) while the observer at infinity see the speed of falling light to be slowing by gamma squared. If the local observer tries to measure radius directly using a ruler then he would measure a greater radius than the infinity observer and he would be of the opinion that the circumference is less than [itex]2\pi R[/itex]. (Curvature of spacetime?)
This post is just to check we are "all singing from the same hymm sheet".
If not, I hope we can identify where we differ and come to some sort of agreement.
Response to #29
Kev, just a quick reply to say that I fully occur with the sentiments of your last statement:
I will reflect on the details of your last post and review all exchanges in the thread and attempt to summarise any points of difference. Just my way of explanation, the reason I am doing this was to see whether a consistent model of relativity would fall out of a simple model that only considered relativity in terms of the time/space effects caused by velocity and gravity. Anyway, I shall try to post a more coherent response as soon as possible, which will probably be tomorrow. Again, thanks for your time and insights.
