How Do Time Dilation and Space Expansion Affect Gravitational Redshift?
70 replies · 16K views
granpa said:
In other words you can not say with certainty who is really ageing faster when two observers have relative motion until they come to rest with respect to each other. Trying to do so is trying to introduce a notion of absolute time that does not work in relativity.
not sure what you are trying to say. what do you mean 'really' aging? it is a trivial matter to determine how fast a given clock is ticking in any given frame . it depends only on the relative velocity. its couldn't be simpler.
I am referring to the classic twins paradox where both twins measure each other's clocks to be ticking slower, but when they get back together they realize that only one has really been ticking (ageing) slower because one returns younger than the other. So basically they both determined each other's clocks to be ticking slower than their own but in fact one of them was not "really" ticking slower.
There are enough ongoing threads on the twin's paradox in this forum, that there is no need to discuss it in detail in this thread.
each sees the other do exactly what it would expect it to do. its only a paradox to those that don't understand how drastic an effect loss of simultaneity has. not sure why you think that means that one can't determine its rate.
by its 'real' rate you seem to be implying its absolute rate but then you say that such an absolute rate can't be introduced. if you don't mean the absolute rate then you must mean the relative rate and that is easily determined.
If you want a link to the speed of light change due to acceleration or gravity I can give you one. Also, based on the varying speed of light and Euclidian geometry, I have posted a new relativistic gravity law. The speed of light within the gravitationl field quantifies the change in total mass. The ratio of the speed of light at the end location to the start location is equal to the total mass ratio between the start location and the end location, so that in fact the frequency doesn't change within the gravitational field.
granpa,
the increase in time caused by the twin paradox is quantified by allowing the speed of light to change in an accelerating field. It turns out that the spatial gradient of the speed of light equals the force per unit mass experienced by the accelerating twin divided by the speed of light.
General Response to #59, 50, 61, 62
OK, I understand the argument that every triplet is in its own frame of spacetime, but it would seem that you could, at least, rationalise these different perspectives by mapping all of them into a `conceptual` frame of reference.
In the triplet `paradox` there is no ambiguity about the start/stop points in spacetime and therefore it would seems to provide be a reasonable definition of a ‘conceptual’ frame in this case. The triplets A, B & C all wear wristwatches that allow them to measure their own local ‘proper time`. As far as I can see, the watches of the 2 triplets in motion, e.g. B & C, always tick at the same rate, which is slower than A.
Footnote:
From #60: how fast a given clock is ticking in any given frame. it depends only on the relative velocity. its couldn't be simpler.
The reason for extending the twin paradox was to compensate for velocity & acceleration as both B & C undergo identical journeys - only the direction differs. As such, I am assuming the equations of special relativity given identical answers.
While the example given in the `Impure Twin Paradox thread#26` may mathematically resolve the ambiguity of time, i.e. time in B & C appearing to run slower from the other perspective, this description seems only to add to the confusion. Certainly, I cannot picture B and C both aging less/more than the other at the `same time` in any meaningful way.
Regarding the issue of space contraction. In order for the speed of light to be invariant, B & C perceive the distance covered to be less than A, although identical to each other. Of course, at the end of the journey, B & C must reconcile the distance with A. Again, this can be done by B & C recognising they were the ones moving at a higher relative velocity with respect to A and the conceptual frame of reference chosen.
While I am making no inference between the conceptual frame and any absolute frame, it would seem that the conceptual frame could be extended to any size, e.g. sun in the solar system or galactic centre in the Milky Way etc. So while the premise that all frames of reference are equally valid may be right, it seems that most paradoxes only arise when we swap between these frames. Therefore, would it not be sensible, from a teaching perspective, to first establish a more intuitive frame of reference and then subsequently discuss the relative ‘distortions’ that lead to `perceptual` paradoxes?
However, I would like to hear whether there are any major objections to this approach from people who clearly know more about this subject than me.
Quick Reponses to #63, #64
Yes, I would be interested. Forgive my ignorance, but where does this idea sit within the mainstream view of relativity?
mysearch
I have given a link in one or 2 previous posts on different threads, so you can just browse my last posts till you find it, because I think it is really against the rules for me to give links. As far as the speed of light change, I don't really know if it could be considered mainstream or not, but I think the answer may be not. It doesn't matter, because in the end it boils down to mathematics. It is always possible to view an accelerating observer from a non-accelerating reference frame. The accelerating observer will encounter photons or particles, and the relative velocity at the time of encounter determines what the accelerating twin experiences. It is possible to use a varying speed of light to satisfy this requirement.
As far as a varying speed of light in a gravitational field (your post #44) you must distinguish between the total mass and the frequency. The rest mass is multiplied by the Lorentz factor to give the total mass. The lorentz factor quantifies spatial frequency (ie wave crests per distance) not time frequency. To account for time frequency the Lorentz factor is multiplied by the speed of light. This is an important distinction when using a varying speed of light. In a gravitational field the spatial frequency changes, but this is compensated for by a change in the speed of light, so the time frequency does not change.
Response to #57: Part 1 of 2
This first part essentially introduces an example and its purpose, while the second part tries to provide a physical interpretation of the relativistic effects due to gravity.
Quote from #57
If you want a "physical image" of what is happening then you have to look towards something like Lorentz Aether Theory which is the same mathematically as Special Relativity but puts everything in a different philosophical and more physical context.
It is true that I am looking for a physical interpretation of relativity, but I do not see why sticking with the standard model should preclude this goal. Therefore, I have deliberately set up the following example in order to highlight some physical interpretations and to see what objections are raised. The example is only considering the relative implications of gravity between 2 stationary observers, i.e. no relativistic velocity complications. The attached diagram (ex68.jpg) represents our 2 observers (A) & (B), where (A) is deep within the gravity well, i.e. [tex]\gamma=8[/tex], while (B) is effectively infinitely removed from the central mass [M].
Note: the values of [tex][\gamma][/tex] are chosen to be illustrative of the effects on spacetime rather than necessarily being realistic.
o In Figure-1a, we see the photon path BAB. The photon emitted at (B) is ‘red’ but then blueshifted on the path B-A, while on the return; the photon is emitted as `blue` but then redshifted on the path A-B. The implication being that the frequency shift is essentially symmetric on the paths B-A and A-B.
o In Figure-1b, we see the photon path ABA. The photon emitted at (A) is ‘blue’ but then redshifted on the path A-B, while on the return; the photon is emitted as `red` but then blueshifted on the path B-A. Again, the implication being that the frequency shift is symmetric on the path A-B and B-A.
The inference of [tex][x_1..x_7][/tex] is simply that multiple observers can exist between A-B corresponding to each value of [tex]\gamma[/tex]. Each observer determines the value of [c=1] based on their own local measurements of distance and time [t], such that [c=s/t]. However, as reflected in Figure-2, the measurement of distance at each point needs to be physically interpreted, as does time, if the value of [c] is also to convey some physical meaning. This said, the local speed of light is always assumed to conform to:
[1] [tex]c = s_B/t_B = s_A/t_A = 1[/tex]
However, it is clear that the value of [c] determined by each local observer will depend on the value of and [t] inserted. While this may seem obvious, what is not always obvious is what the observer is actually measuring. As a very general statement of relativistic effects, elapsed time can either be shorter or longer, as can distance. As such, there are 4 permutations and therefore possible answers to equation [1], although not all may be physically meaningful.
Figure-2 reflects standard theory by illustrating that [ds] will expand relative to [dr] due the geodesic curvature of space as [Rs] is approached. The diagram is reflective of the range of [tex][\gamma=1..8][/tex] used within the example. As such, [ds] is 8x greater than [dr] at (A), but whether the observer at (A) physically realizes this aspect is tabled as an open question. Likewise, theory also predicts that time dilates as [Rs] is approach. As such, 1 unit of elapsed time in (B) would equate to 8 units in (A) given the relative values of [tex][\gamma][/tex].
While we are familiar with the relativistic curve ranging from unity to infinity as [Rs] is approached, it is useful to note that relative time and distance only change linearly with [tex][\gamma][/tex]. So, with reference to figures 1a and 1b, each segment of the path AB or BA that corresponds to a unit change in [tex][\gamma][/tex] will also cause a proportional change in time or distance. However, it is again highlighted that this may not be apparent to the local observer. Therefore, it is suggested that any physical interpretation needs to consider 2 frames of reference:
o Local Observer
o Conceptual Observer
The conceptual observer has the advantage of perceiving both [dr, ds] and [tex][dt, d\tau][/tex]. The physical interpretation is now taken up in part-2.
Response to #57: Part 2 of 2
Part-1 outlines the example, including reference diagrams, and its purpose; therefore it is the logical starting point of this discussion. Part-2 now considers what, if any, physical interpretations can be drawn. As previously introduced, the local speed of light is always assumed to conform to:
If we consider equation [1] with respect to observer (B), who is conceptually at infinity, i.e. no spacetime curvature, where [tex][\gamma=1][/tex], we might consider [c] expressed in unit distant and time producing a unit value of [c]:
[2] [tex]c = s_B/t_B = 1/1 = 1[/tex]
However, the suggestion is that if these unit measures were at [A] with [tex][\gamma=8][/tex], equation [2] would become:
[3] [tex]c = s_A/t_A = 8/8 = 1[/tex]
However, the values inserted in [3] are only perceived from the `conceptual frame` and not by the local observer at (A). Locally, at (A), time [tex]t_A[/tex] is still considered as unit time, as the `physical` perception is that the rate of time is still 1 second per second. As such, the local values of equation [3] would be:
[4] [tex]c = s_A/t_A = 1/1 = 1[/tex]
In sense, we are seeing the constancy of the speed of light in both the local frame and the conceptual frame, which might be generally written as either:
[5] [tex]c = dr/d\tau = 1[/tex] Local frame: min-r/min-t
[6] [tex]c = ds/dt = 1[/tex] Conceptual frame: max-r/max-t
What equation [5] implies is that if [c=1] in all local frames, then the local (proper) time is always dilated and the local perception of radial distance has also to be the coordinate-radius [dr] not [ds].
Interpretation?
The local observer doesn’t directly perceive the effects of relativity and therefore always measures the minimum value of space [dr] and time [tex]d\tau[/tex]
In contrast, the conceptual frame corresponding to equation [6] is referencing the maximum values, [ds] and [dt]. However, both appear to support the constant speed of light [c=1] based on equations [3] and [4]. At this point, we might try to imply some physical interpretation to the frequency of the photon emitted and absorbed at any point. The following interpretation is forwarded on the assumption that modern relativity replaces the description of Newtonian gravity as a force with the concept of spacetime geometry. As such, gravitational redshift has to be physically interpreted in terms of time or space changes.
Interpretation?
When emitted from (A), the photon was said to be blue, i.e. high frequency, but this was only with respect to the local dilated time at (A). As the photon moves toward (B), the relative rate of time ticks faster, redshifting the frequency of the photon. In contrast, a photon emitted at (B) was said to be red with respect to its local time, so as the photon moves toward (A) the frequency is blueshifted.
While I understand the maths that have led to the conclusion outlined in the following quote, it is suggested this conclusion can be also be interpreted from the conceptual frame to be physically more meaningful.
From #57: So only the conclusion reached by assuming the speed of light is constant everywhere in a gravitational field gives an asymmetric result that ABA>BAB.
With reference to the figures in the attachment in part-1, it is difficult to conceive that ABA > BAB, as to the photon(s), it represents the same physical path. Physically , the only thing that changes is the relative rate of time perceived by the 2 observers in (A) and (B) who may be determining the distance based on their local assumption that [c=1] and that the roundtrip elapsed time is either [tex][t_A or t_B][/tex]. It is clear that if [c=1] and ABA equals BAB, then the local observers would have to agree on the roundtrip time, which they do not given the relative time dilation. However, it will be suggested that we can use the conceptual frame to get a more meaningful resolution.
If we start with observer (B) and figure-1a, with each segment corresponding to [tex][\gamma=1..8][/tex], we may also considered each segment to correspond to a unit distance traversed in unit time, such that:
[7] [tex]c = s_{BAB}/t_{BAB} = 16/16 = 1[/tex]
However, we know that the observer at (A) must measure the roundtrip time against its local proper time, which the conceptual observer can see is related by:
[8] [tex]t_A = t_B*\gamma_A[/tex]
However, locally, observer (A) must still determine [c=1] therefore:
[9] [tex]c_A = S_{ABA}/ t_B*\gamma_A = S_{BAB}/t_B = c_B = 1[/tex]
If so, this suggests:
[10] [tex]S_{ABA} = S_{BAB}*\gamma_A[/tex]
[11] [tex]S_{ABA} > S_{BAB}[/tex]
This seems to confirm the conclusion reached in #57. However, how else might we physical interpret equation [6]?
Interpretation?
(A) and (B) disagree on the length ABA and BAB, not because the photon actually traversed 2 paths of different length, but rather the BAB has been calculated in terms of [dr], while ABA has been calculated in terms of [ds]. Therefore, from the conceptual frame, the suggestion is that ABA = BAB.
Finally, to be clear on one point, the conceptual frame is not inferring that any absolute frame exists; it is simply intended as a possible learning aid. While mathematically theorist may reject this approach, the level of debate over the meaning of relativity, in this forum alone, suggests that mathematical derivation alone is still subject to many different physical interpretations. As always, would appreciate any constructive feedback.
Hi mysearch,
..your conceptual reference frame seems reasonable. It seems to be the same as what I have been calling the coordinate measurements of the observer at infinity (observer D) Where I have been stating things like D says the speed of light at A is c/64 it is obvious that D can not make direct measurements of observations at A but by performing logical deductions of all the measurements made at A,B,C and D and builds up a conceptual image that seems to fit all the facts, that he then plots on a coordinate chart. References to the coordinate distance, time and speed of light are references to the conceptual reference frame you describe.
P.S
By the way I have you seen the thread I started on Bell's paradox here : https://www.physicsforums.com/showthread.php?t=236681 . Does it help?
P.P.S
Are you ready to go exploring event horizons yet?
Quick Response to #70
Guess the purpose of #68/#69 was to see if we could converge to some physical interpretation of the implication of relativity. Wasn’t sure whether you would agree with the ABA = BAB conclusion and that ABA > BAB was really an `apple and oranges` comparison.
Yes I had seen the Bell Paradox thread and was glad that you had raised it as a separate issue, because previously it seemed to be buried in other non-obvious threads. Unfortunately, I haven’t had too much time over the weekend to get into the details, but will add to the thread as soon as possible.
However, I did post a question in your Impure Twin Paradox thread. Hopefully, while you take a look at this, it will give me some time to get my ‘event horizon-hiking boots` on. Although I am not sure, as yet, whether I have yet got all the right equipment. :wink:
