How Do Two Applied Forces and Kinetic Friction Affect Crate Acceleration?
7 replies · 6K views
jarmen
The drawing shows a 28.8-kg crate that is initially at rest. Note that the view is one looking down on the top of the crate. Two forces, F1 and F2, are applied to the crate, and it begins to move. The coefficient of kinetic friction between the crate and the floor is k = 0.374. Determine the (a) magnitude and (b) direction (relative to the x axis) of the acceleration of the crate.
m=28.8kg
k(kinetic friction)=.374
F1=88N
F2=54N
fk(magnitude of kinetic friction)= (k)(Fn)
ax= (-fk)/m
I have tried a few things, but i am not sure really what equation to go after, since i feel i should be using something with the angles in it.
any help is appreciated.
Start by finding the net applied force. Add up the F1 and F2 force vectors. Don't forget that they are vectors, not just numbers.
so for getting the magnitude to the right, along the x-axis shouldn't i do
cos(55) (88) =50.47
then add 54
104.47
If this is right, then where do i go from here.
That's the sum of the vectors on the x-axis. To complete the vector addition you need to consider y-axis too.
jarmen said:
would that be (sin(55))(88) for Y vector?
That's correct. That's the y-component of the applied force.
Use the components that you've calculated for the total applied force to find the magnitude and direction of the total applied force. The direction of the applied force will also be the direction of the acceleration.
To find the magnitude of the acceleration you will have to include friction, which opposes the motion and acts opposite to the applied force. What's the friction force? What's the total force (not just the applied force) acting on the box?
Ok i got it,
thanks everyone i just worked it out and it was correct.
