Undergrad How do we divide one vector field by another?
Dividing one vector field by another does not have a standard definition, but it can be context-dependent. Typically, two vector fields can be divided if they share the same direction, particularly on smooth curves where tangent vector fields are involved. For instance, on a 1-dimensional manifold, division is feasible as long as the denominator vector field is non-zero. An example provided illustrates this with vector fields on the circle S1, resulting in a scalar field from the division. Ultimately, the division reflects a relationship where the product of the quotient and the denominator equals the numerator vector field.
tade
Let's say we have two vector fields, described by 6 functions: Ax, Ay, Az and Bx, By, Bz.
We want to divide field A by field B.
Do we take Ax/Bx , Ay/By and Az/Bz individually?
But in this case we might end up with Three different scalar fields.
What's the proper way to do this?
There is no standard definition of division of vector fields. But in a given context, for a particular purpose, there may be a use in defining something that shares some properties with division as defined for other algebraic objects.
The answer to the question will come from reflecting on why you want to do this.
Thanks. I've figured it out the context of the division.
you can normally only divide two vectors if they have the same direction, so on a smooth curve you can divide two tangent vector fields, since the tangent space is everywhere one dimensional. i.e. when one vector is a number times the other, then their quotient is that number.
Of course, two vector fields on a 1-dimensional manifold can be divided, as long as the denominator vector field is nowhere zero. Because, at each point they belong to the tangent space at that point, which is the real numbers.
For example, on the circle S1 parametrized by t, 0 ≤ t ≤ 2π, we could have the vector fields
V(t) = e d/dt = e1 d/dt​
and
W(t) = esin(t)2 d/dt.​
In this case, we have
f(t) = V(t) / W(t) = e1 - sin(t)2,​
= ecos(t)2
which is just a scalar field, or in other words just a real-valued function.
This is just saying that
f(t) W(t) = V(t).​
(The same thing is also possible if the space on which the two vector fields are defined is a Riemann surface M. Since then at each point of M the vector of each vector field lies in the complex numbers.)
Likes jim mcnamara
I am studying the mathematical formalism behind non-commutative geometry approach to quantum gravity. I was reading about Hopf algebras and their Drinfeld twist with a specific example of the Moyal-Weyl twist defined as F=exp(-iλ/2θ^(μν)∂_μ⊗∂_ν) where λ is a constant parametar and θ antisymmetric constant tensor. {∂_μ} is the basis of the tangent vector space over the underlying spacetime Now, from my understanding the enveloping algebra which appears in the definition of the Hopf algebra...
  • · Replies 33 ·
  • · Replies 16 ·
  • · Replies 0 ·
  • · Replies 16 ·
